Question about Lexmark X3550 All-In-One Printer
Lexmark x3550 will not scan 'Downloading Application List" and "
I have this following printer and my printing is fine and copying. but I am trying to scan either doing it manually on the scanner/printer itself or with its software Lexmark Imaging Studio.
Doing it manually with the software running, pressing the button on the machine, the scanner reads
"Requesting Scan" after sometime a box appears and reads
" Scan was Not Succesful Try these options: Make sure printer is powered on and ready. Disconnect, reconnect USB cable and printers power cable and restart your computer"
I do these with no result.
Doing it with software loaded with clicking scan button the same happens and same boxes pop up.
I have repeatedly uninstalled my all in one printer and scanner drivers and software, reinstalled it but nothing is seeming to work.
I recently just upgraded my system, and before this upgrade everything worked perfectly, it could scan, print do its job. but now with this A7XMX-K Foxconn motherboard it doesnt want to work.
http://www.foxconnchannel.com/product/motherboards/detail_overview.aspx?id=en-us0000373
Any help?
I'm running:
Windows XP
4gig RAM
AMD 5000+ Dual core
Had the same problem. Installed the most recent drivers. OK now. Good luck. - Kakou
Posted on Mar 06, 2010
My Printer Lexmark X4580 will not scan. I get the following message-Cannot retrieve Application List. Printing and copying works fine.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via the USB cable, disconnect your printer from your computer. Reboot your computer. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to scan again.
If that doesn't help, try to reinstall the printer software on your computer. This will help repair any corrupted files necessary for scanning or printing.
Jun 27, 2011 | Lexmark X4580 InkJet Printer
I've installed the software for my x3550 printer, and when I try to scan a picture via wireless, I select my laptop and it shows on the display: "Downloading Applications List". After that it displays:...
Hi. This printer is wireless for the print function but not for the scan function, go figure. In order to scan you must hook up the printer to your puter via a USB wire.
Aug 11, 2009 | Lexmark X3350 All-In-One InkJet Printer
Lexmark X5650 cant scan
TRY TO REINSTALL THE SOFTWARE AND A DRIVER FOR THAT MODEL DRIVER
Aug 06, 2009 | Lexmark X5650 All-in-One InkJet Printer
Device monitor application problem
Make sure that the Lexmark Imaging Studio program is running. This was installed when you set up your printer.
If you see the multi-colored icon in your task bar for Lexmark Imaging Studio then try pressing the scan mode button twice. You should be able to scan then.
Sep 28, 2008 | Lexmark X3550 All-In-One Printer
When trying to use the lexmark scanning program, press the scan mode it states it's downloading Applicaion list but when finish it says Cannot retrieve Application list.
If you originally installed from a CD, try uninstalling (should be a shortcut in the Start menu) and then downloading and installing the latest driver from the web. Lexmark had this problem with some products and the web driver may have a fix for it.
  1. Go to the Lexmark Find Drivers/Product Selector page.
  2. Enter your model number (for example, X3550) under "Search by Model", and click the Search button.
  3. Select your OS from the dropdown (XP, Vista etc.).
  4. Click Download Now.
  5. If you're asked to Save or Run, choose to Run (it keeps you from having to go find the file and double-click it later).
Aug 06, 2008 | Lexmark Office Equipment & Supplies
Lexmark x3550
Is your scanner connected DIRECTLY to the port on the computer or is it going through a docking station or usb hub?
if it's the latter I suggest you try direct connection and also try different USB ports on the computer after a REBOOT each time.
Jul 28, 2008 | Lexmark X3550 All-In-One Printer
Scanner
Reinstall the software/drivers and try again.
May 23, 2008 | Lexmark X3550 All-In-One Printer
Lexmark X3550 All-In-One Printer Logo
720 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
