Question about Xerox Phaser 3450DN Laser Printer
Xerox 3500 blank pages xerox 3450 display flashes
Phaser 3500, customer says it is the second one new out of a box that is printing blank pages, also they have a phaser 3450 that the light just blink, no error code and it never goes into ready mode I have not seen either machine yet.
  • syedmuneer06 May 15, 2009
    text size problem
    Scholar:
  • 92 Answers
Clear all memory under maintenance will solve this
Posted on Aug 27, 2010
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox phaser 8200 laser printer leaves 2" blank strip on left hand side of paper, Fix?
Try a brand new document and cover the page in characters and test print. If the issue persists, then please call for service.
Nov 03, 2013 | Xerox Phaser 8200 Laser Printer
I have just bought a Xerox Phaser 6500. Prior to this I had a phaser 6125. The problem im having happened with both printers which makes me think somewhere along the line my settings are wrong. If I...
You may have the "separator page" option turned on in your print driver. This option will insert a blank page after each print job to separate one print job from another. Simply uncheck the box by the separator page option and you should be back to normal !
Oct 21, 2013 | Xerox Phaser Office Equipment & Supplies
I have a Xerox 3450 printer. Everytime I print a paper jam occurs. I fix the paper jam and print and it happens again.
i think you have to replace the fuser assembly. 126e02480 is the part number it will
hope that it will help you
Feb 06, 2013 | Xerox Corporation Phaser 3450 Laser...
Xerox 3500 config page
To print a configuration page from a Xerox Phaser 3500:
- Press the Menu button
- Information will be displayed on the screen -- press OK
- Go to Info Pages, and press OK
- Go to Config Page, and press OK
To get configuration page instructions for other copiers, printers, or fax machines, go to How to Print Configuration Pages.
Nov 10, 2010 | Xerox Phaser 3500/DN Laser Printer
How do i get a network configuration page for a xerox phaser 3500
1. On the control panel, press the Menu button, then press the OK button to select
Information.
2. Select Info Pages, then press the OK button.
3. Select the appropriate information page, then press the OK button to print.
Note
Print the "Menu Map" to see other information pages available for printing.
Hope this helps
Kevin
XEROX PHASER 3500 ERROR CODE TSK-ROOT 1087
most possible cause is the Memory added above the 32MB base is failing. if thats how you have it setup.
Remove the additional memory module from the machine and test the machine. If the machine powers up and prints correctly this confirms the additional memory has failed. Insure the memory removed form the machine is the correct memory for this product and that it was installed correctly. Replace the defective memory if it is Xerox memory. If the memory was purchased by the customer and is not Xerox memory they will need to file a warranty claim with the company they purchased the memory from.
Dec 23, 2009 | Xerox Phaser 3500/DN Laser Printer
PCL5 OUT OF MEMORY Phaser 8860
After reading some similar stories, I simply restarted the Xerox Phaser printer via the menu on the physical printer. I theorize perhaps the Phasers on board memory could have been bogged down from all the pictures involved in the problem documents and all the size problems associated with large files.
thorntravis
Oct 07, 2009 | Xerox Phaser 8860MFP/D - Multifunction -...
Xerox 6360 control panel blank
If your Xerox Phaser 6360 has either garbled characters, inverted or upside down display, or no display, the control panel is most likely bad and must be replaced. Here's a video on how to do it and where to get it. Hope it helps!
Mar 30, 2009 | Xerox Phaser 6360 Laser Printer
Xerox Phaser 3450DN Laser Printer Logo
644 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
