Dewalt 18v Cordless Impact Screw Driver Drill Dc825 Logo
A
Anonymous Posted on Feb 08, 2013
Dewalt DC 988 drill smells nasty! (It's from 2005/Lowe's- out of warranty)
I hate to throw it out because it was expensive! Diagnosis anyone?
3 Related Answers
Anonymous
  • 313 Answers
  • Posted on May 24, 2008
SOURCE: dewalt dc 988 cordless drill
posible motor problem, the built in magnetic ring in the motor may broken inside or just to much dust in it. advice when replacing motor also replace th switch for the cost $132.00 plus tax canadian. thanx
stug_57u
Stuart
  • 99 Answers
  • Posted on Feb 12, 2010
SOURCE: Hi i have a dewalt DC 988 combi drill, 4 years
It all depends on what is burning I'm afraid. When in use, run your hand around the back of the machine and handle area to see if anywhere in particular is getting hot. On the older versions of these (DW988) the leads leading from the switch to the brush holders would overheat and burn, also causing damage to the brush holders themselves. Is there any smoke coming from the rear vents, if so you wil probably find it is a motor problem and the smell would be the insulation burning off the armature. The only other thing to check would be to make sure the battery isn't shorting and getting hot, as this could also cause damage to the switch and vice versa.
Anonymous
  • 2176 Answers
  • Posted on Oct 23, 2010
SOURCE: How do i remove a dewalt chuck in the DC 988
go to the tip section and I left detailed instructions on how to do this, or try and go to my profile page under tups. Let me know if you still need more help
Is there a diagram to repair the 18volt drill
Yes, All diagrams are available at http://servicenet.dewalt.com/Home
Just put your model number into the search box. Have the type number handy too as it will ask for that. You can view and download the manuals and diagrams from there.
1helpful
Using a garden auger with the torque set to the highest setting the clutch broke and started to slip. Is this too much for the Dewalt 720 cordless drill? Dewalt is repairing it under warranty.
Yes, luckily Dewalt is taking care of you. You might want to look into a 1/2' drive electric model (sorry with a cord) Alot depends on how hard the ground is but in the long run the big electric will handle about anything you throw at it. Check Sears or Home Depot both good sources for good tools
How do i remove a dewalt chuck in the DC 988 drill ?
1helpful
Hi i have a dewalt DC 988 combi drill, 4 years old. its starting to have a burning smell when used what are possible problems and solutions?
Dewalt dc 988 drill housing
If you are in America/Canada go to dewalt service net http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1. make sure you check the type number as there are some variations across the model range. You should find the type number either just after the model code or on the top right of the rating plate.
If in U.K. then go to https://service.toolcommerce.com/products/HomePage.aspx?BrandId=2&language=en-GB&country=GB.
You should be able to ID the part and find a dealer from these sites.
Oct 25, 2008 • Drills
2answers
Dewalt dc 988 cordless drill
We.ve the same problem with those Chinese batteries and find that this problem is quite wide spread with many brands using these batteries. I'm speaking from experience with our battery factories. No quality control!
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
