Question about Onkyo TX-SR606 Receiver
Amp turns off after about 20 mins of bluray playback
I have had a 37 inch phillips plasma for 4 years,since then i have upgraded my amp to a onkyo tx sr606, pioneer bluray etc. i have just purchased a panasonic viera 46 lcd 1080p.when watching bluray discs,the amp now seems to turn off after about 30 minutes of being on.all connections remane the same in the back of the onk.all connections are correctly installed??any ideas?? thanks
  • blueduce04 Feb 12, 2009
    I have had my 606 for 2 weeks, everything worked fine till to day after a few minutes of watching my new blue ray the receiver turns  off, it works fine in cable mode and I watched a blue ray movie the night before with out a problem, what to do?
  • 27 Answers
Your amp is overheating. Provide better ventilation or rig up some fans. Onkyo amplifiers are known for getting hot.
Peace.
Marco
Posted on Feb 05, 2009
Onkyo tx-nr509 Receiver not talking to Panasonic TV TX-L42E31B
Hello, I am sorry about your issue. If the cable is long from the receiver to the TV it may cause video issues. Please try a reset of the receiver by pressing and holding vcr/dvr and then on/standby. When display shows clear let go. The receiver will shut down. Turn back on and test. This procedure will take the receiver back to factory defaults. Thank you, CB
Mar 24, 2017 | Onkyo TX-NR509
Want to purchase a blue ray player. is there one that is compatable, and easy to hookup. I have an onkyo txds 555 reciever and and old apex tv. Want to up grade to a blue ray player( ill get the hd tv...
All of them will work just fine audio-wise with the Onkyo and on some level just about any TV made in the last 20 years if it has s-video, composite video, component video or HDMI video inputs (google them).
Choose one and follow the manuals for connection.
Here's yours...
http://www.retrevo.com/support/Onkyo-TX-DS555-Receivers-manual/id/365dj180/t/2/
Keep in mind that no video must necessarily pass from the the BluRay to the receiver but it MUST find its way to the TV. It's best to have any audio or video signal go directly to the best electronics that handles it. That's one reason they can be routed separately.
Sep 20, 2011 | Onkyo TX-DS555 Receiver
ONKYO TX8522; Using it as a 2nd receiver to push zone 2 (4 speakers) in basement. When TV, LG BluRay, iPod, or radio selected for receiver 2 zone 2, it works great! When I select Padora thru the same...
I've seen some posts that talk about an incorrect or too high digital audio bit rate causing this. If it's only digital sources I'd look at that.
Feb 04, 2011 | Onkyo TX-8522 Receiver
I need the remote control code (for onkyo receiver
Philips Blu-Ray player codes for Onkyo universal remotes are: 33007, & 33016.
You can download Onkyo universal remote codes with instructions here.
I hope that helps.
Jan 23, 2010 | Onkyo TX-SR605 Receiver
My Onkyo TX-SR606 will not turn off, will not adjust volume, will not change modes, will not do anything but stay "stuck" on cable/satellite at volume 33. It will not reset. I unplugged it, waited, and...
contact onkyo and ask for a disc that you use threw the cd player via a toslink . The disc will upgrade your avr ,thus overwriting any problems you had. My tx-sr705 had an issue with popping during blu ray playback while the dts-master audio was being used. I got a disc that upgraded the chip that utilizes the codec's.
Aug 14, 2009 | Onkyo TX-SR606 Receiver
Connecting a wii to an Onkyo TX-SR607 7.2
I am experiencing issues like this although with a VCR connected with analog video. I added a BluRay DVD player and all of a sudden I lost my video upconversion from my VCR. I am going to try to reset the receiver to see if this fixes the problem. If not, I don't think it is the receiver issue, I think it may be the fact that enorder for video to pass through HDMI, allot of criteria needs to be met. Certain Handshakes need to happen, especially with the HDCP issues. Most likely I will connect a separate video cable to my Plasma and use a secondary input on the Plasma for the VCR signal. You may want to purchase the Component Video adapter for the wii system as this will provide you with at least 480p and your receiver should not have an issue passing the signal over the HDMI output. Good luck and give me an update.
Jun 06, 2009 | Onkyo TX-SR606 Receiver
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Connecting blu ray to surround sound receiver to tv
Hi, I have just completed this installation myself.
You are correct, HDMI to Amp Input from Bluray and then HDMI from Amp output to TV. Coloured cables are not required to operate the bluray now.
Good luck
Jan 02, 2009 | Onkyo TX-SR606 Receiver
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
Onkyo TX-DS575 turns off after about 10 min.
it could be a failing speaker causing the fault. Disconnect one speaker and run it to see if the problem persists and repeat with a different speaker until all speakers have been disconnected and the unit run to failure. If it stays ok, with a particular spkr off, it's the speaker. If it shuts down no matter which ones disconnected, it's probably a crack on the PCB which expands as it heats and causes shutdown.
Dec 16, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-SR606 Receiver Logo
179 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
