Question about Buck Car Audio & Video
Radio wireharness for 1993 cadillac sts
I cant find the correct harness to hook up the radio, is there another one I can use?
    President:
  • 1,990 Answers
You can locate your Harness Here Schoche.com Please Rate My Response! Thanks!
Posted on Feb 05, 2009
My cts 2005 wont start but it will crank
private sale or from a used car lot if from lot call and advise should have a limited warranty ---if private call and ask about non start --try to get vehicle scanned and check for any codes previous may have cleared codes to make sale --check fuses/relays -if have starter fluid give shot if starts check fuel pump -possible fuel filter-if pump good will need to check ignition system ,check for spark,and or certain sensors like the crank position sensor------- the following post is from caddyinfo forum Subject: Multiple Electrical System Malfunctions, Engine Will Not Start, Engine Will Not Shutdown, IP Gauges/Lighting Inoperative, Radio Inoperative, HVAC Display Erratic, Loss of Rear Door Functions (Inspect Both Rear Door Harnesses and Repair, if Necessary)
Models: 2005 Cadillac STS
Built Between and Including VIN Breakpoints 50112423 and 50133076
Attention: This inspection should be performed on all vehicles currently in your inventory prior to sale or delivery.
Condition
Some customers may comment on one or more of the following conditions:
• Engine Will Not Start
• Engine Will Not Shutdown
• IP Gauges/Lighting Inoperative
• Radio Inoperative
• HVAC Display Erratic
• Loss of Rear Door Window/Lock Functions
These conditions may occur intermittently.
Cause
These conditions may be caused from the rear door wiring harness being misrouted causing the harness to contact the metal door bracket. This contact may cause a rub through to the wires enclosed in that harness.
Correction
Inspect both rear door wiring harnesses. Repair any damaged wires and reroute harness to correct location. Use the procedure listed below.
Make sure the ignition is off.
Remove both the rear door trim panels. Refer to the Side Rear Door Trim Panel Replacement procedure in the Doors sub-section of the Service Manual (SI Document ID #1465575).
2005 STS electrical problem NO START
Jul 19, 2016 | 2005 Cadillac CTS
I need the radio security code for a 1999 cadillac sts
You will need to contact Cadillac service at your local dealership. Give them the serial number on the radio. They can then pull the anti theft lock code from their companies archive. The serial number on the radio is typically tied to a VIN, but since you bought just the part, they can't search that way. Hope that helps.
Sep 16, 2012 | 1999 Cadillac Seville
Put new radio in now battery keeps draining whats wrong?
The new radio has been wired incorrectly. Pull it back out, and check that your radio wiring harness is hooked up correctly with the car's radio wiring harness.
Jun 21, 2012 | 2000 Cadillac DeVille
1993 cadillac seville sts error code 1039
1039 = (4.6L engine) loss of road sensing data.
1039 = (4.9L) engine) SSS (speed sensitive suspension)signal loss.
The 1039 code requires extensive diagnostic testing.
Feb 06, 2012 | Cars & Trucks
Need to hook up a new radio but cant find the hot wire
your best solution is go to a junkyard tell them you need the radio clip for the factory radio splice them back together buy colors go to your local radio shop and get a wire harness so u can hook up a after market radio good luck
Jan 22, 2011 | 1998 Cadillac Eldorado
Wire diagram for a 1993 cadillac eldorado radio
Easiest way. Go to any auto store, Pep Boys etc, locate the book for the year of your car and write down the wire diagram.
Sep 10, 2009 | 1993 Cadillac Eldorado
Can you hook up an iPod to a Cadillac STS 2005
2005 STS4 In the center console there are audio video jacks. Go to radio shack and grab a cable with audio/video one side headphone the other. Plug into your iPod and put the touchscreen setting on AUX. It's on the screen getting to bluetooth
Mar 24, 2009 | 2005 Cadillac STS
Need To Wire In A Aftermarket Radio In A 2008 F-150
Easiest way is to go to Crutchfield.com web site, When you order a radio face plate or factory wireharness they give you a free installation kit which shows the color codes of each wire for the radio. Also, when you get the wireharness you don't have to cut any factory wires, it just plugs into your factory harness and you connect the open ends to your new radio.
Dec 18, 2008 | 2008 Ford F 150 2WD
1993 seville automatic transmission V8 4.9 liter?
neither the 93 seville is just that it's the 4.9 liter before the northstar sts 4.6 came out in same year
Jul 31, 2008 | 1993 Cadillac Seville
Car Audio & Video Logo
97 people viewed this question
Top Buck Car Audio & Video Experts
xxxxxx xxx
handygirl911
handygirl911
Steve Sweetleaf
Steve Sweetleaf
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
