Question about Averatec 3200 Notebook
Black Screen I replaced the screen on my averatec I us instuctions from the net. My old screen had cracked and was hard to use. I replaced screen and heard the computer bootup but the screen remained BLACK. I check connections with no success I tried to revert back to the crack screen but it will no longer works either. What the issue please HELP.
  • 2,229 Answers
The first thing I would do after turning the computer on is check to see if the video output is being directed to the LCD screen. The output can be directed using the Fn key along with the key with the picture of the 2 monitors on the Function keys at the top of the keyboard. Hold down the Fn key and tap the other key once or twice,
Next, hook the computer up to an external monitor. Do the same thing with the Fn key to see if it's the LCD screen.
If the external monitor works, then you haven't correctly hooked up the LCD screen or it's bad.
Posted on Feb 06, 2009
Replace a broken screen on a pn60f5500
It will be best to buy a new TV; instead of replacing its LCD screen; as it might cost 2/3rd of the total cost of a new TV.
Feb 25, 2015 | Samsung 60" Series 5 Plasma HDTV -...
Black spot appeared on the screen on bottom left side how to clear it
A large black spot usually means the LCD screen is damaged. It may have fine cracks around the black spot. In this case the LCD screen needs to be replaced.
A replacement screen maybe available for your laptop from this WEB site.
LCD screens and Inverters www.lcdparts.net
Feb 12, 2013 | Lenovo Computers & Internet
My net book's screen is not cracked on the out side but i see a shattered black screen
Screens are delicate and easily damaged, and area's that are black are unusuable. The only fix is replacement of the LCD screen.
Apr 07, 2012 | Toshiba Computers & Internet
I have a hp dv6 laptop the inside of this screen looks cracked on the inside with ink leaks,outside is not cracked,i canot plug another moniter in as it says very faint in left corner windows canot...
If the screen looks like black ink on the screen then the screen is broken (ie cracked on the inside).
LCD screens and Inverters maybe available from this WEB site.www.lcdparts.net
Mar 11, 2012 | Computers & Internet
My averatec will not turn on
Open it again and make sure you connect all the devices and such ..It seam to be like a clear case of a disconnected cable ..If the system boot up ..and seam to run ..try to see if the vga secondary monitor brings anything to a screen ..if it does it means you messed up with the monitor connections ..cause you changed the hard disk ..you don't have a operation system to boot into and try to make an idea..but its a start ..
Other things to check is the fan connections and cables ..
If the screen is totally blank I think is like I said just a bad connection to the monitor or a damaged cable in the process of opening it .In any other case you would have at least a warning on screen even without hard disk it should boot to BIOS ..
Dec 07, 2011 | Averatec Computers & Internet
Hi my original problem of black screen turned out
Well... if your target is the motherboard replacement (and nothing else is going wrong except of your motherboard),
you don't need to reinstall the OS again (op hard disk).... if your new motherboard is axactly the same brand/model as the old one, nothing more you need to do, but only the to replace the old motherboard by the new one!!!
Apr 14, 2011 | Acer Aspire M5641 PC Desktop
I repaired the female power jack in my Averatec and must have compromised something else in the process as now my screen has two large black quarter sized black spots, on quarter of the screen at upper...
If you put any pressure on the screen while repairing the power jack then yes, the LCD will need to be replaced. If you are certain that you did not physically damage the screen during the repair then it is possible that you damaged the motherboard (which houses the video processor). If the motherboard was damaged I would say it's time for a new laptop.
Aug 24, 2009 | Averatec 3200 Notebook
Cracked screen on nokia 6220 classic
minta unlock key buat IMEI 352922021139844
May 15, 2009 | Nokia Cell Phones
My averatec 7100 series laptop don't work. you turn the power on and the lights come on but you don't hear nothing and the screen is black.
I have the same problem with one of my 7100's I can get the screen to come on if I hold the delete key when powering on.Sometimes takes more than one try... and doesn't fix the problem. F2 will take you to the BIOS to see if it is detecting your hard drive. Hope this helps....
Aug 26, 2008 | Averatec Computers & Internet
Black LCD
Sounds like you have a bad backlight, the backlight shines light through the translucent LCD layers to give you your picture in the same way you hold slides up to the light
Oct 08, 2007 | Averatec 3200 Notebook
Averatec 3200 Notebook Logo
119 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
