Question about Atlus Hotel Dusk: Room 215 for DS
Opening suitcase I cannot get into the suitcase in chapter 2 of Hotel Dusk, I have tried the paperclip and thought about the coat hanger but cannot get it off the wall. Any ideas of what to do?
  • jagbird70 Mar 19, 2009
    I have the wire cutters but cant cut the coat hanger. Is there is a specific place to cut it in ???
Yes, on the second floor there is a linen closet. Then you must go into the locker right next to the door and get the wire cutters from the tool box on the top shelf. I hope this helped. If you've moved past this point and you figured out a way to use that pen after dinner please sent me a tip.
Thanks!!!!
Posted on Mar 10, 2009
Uninden uho65sx keylock off
you have 2 options or a) call locksmith b) follow the steps mentioned.
Instructions
    • 1 Unwind the metal coat hanger so it's straight. Bend the end of the hanger so the tip resembles a hook.
    • 2 Slide the hooked end of the hanger between the window and the door frame right in front of the side of the door handle that is closest to the side mirror. Push the hanger down 1 1/2 feet and make sure the hook is facing you.
    • 3 Pull up and down on the coat hanger until the hook grabs the metal lock arm. The door lock handle will start to move once the hook has grabbed it. Pull up on the coat hanger until the door lock releases, then open the door.
    GOD BLESS YOU
Oct 05, 2012 | Cars & Trucks
I locked keys in pergeot 206 sw is there any way of opening with code or other answer
no way with any code or anything what you do is to wind the rear window down with a coat hanger and a thin metal rod ,manual windows on rear only will this work or try pulling the internal door handle levers with a coat hanger
Aug 26, 2011 | 2005 Peugeot 405
I opened the door before the self cleaning cycle was finished? It was blowing and I thought my husband left it on when he left. I came home and walked past it and felt the air, so I pushed oven off and...
You have most likely caused one or more fuse relays to blow.
The self-clean operation can not be interrupted before the cycle is complete without causing issues.
There is the main fuse inside the control panel and 2 fuse relays on rear of the oven.
In order to access these fuses you must open the door,then remove the mounting screws to remove the oven from its cabinet..
Use a wire coat hanger bent into a "U" shape on one end.
The door latch is in the center of the door on the top oven.
Slide the bent wire coat hanger between the door and the oven opening.
The "U" of the coat hanger will be right center of the door latch.
Slowly pull the "U" to the left until it catches the latch.
Then pull steady and forcefully to pull the latch mechanism to the left while putting pressure on the door to open it.
Once the door is open you can begin to access the parts for diagnosis and repair.
Nov 28, 2010 | Whirlpool RBD305PD Electric Double Oven
Door Wont open on my Samsung J845 washing machine
yes its the door mechanism Unplug the machine for 4 hrs the try opening the door.Don't try to force it you will make matters worse
Sep 07, 2009 | Samsung WF203ANW Front Load Washer
No book
go to www.replacementdocs.com for manual.
Apr 01, 2009 | Atlus Hotel Dusk: Room 215 for DS
I'm trying to replace the factory tape deck in my hyundai lantra 1996 but i cant seem to get it out can anyone help!
it should have 2 holes on each side take a coat hanger and bend it into a u make two of them push it into each side untill it clicks push outwards on each coat hanger u and pull out
Mar 03, 2009 | Hyundai Motor 1996 Elantra
Keys locked in car
Your message is already old so you surely have gotten into your car by now but for future problems, I'll post this anyhow.
Coat hangers may work but if you can find a friendly cop, they often carry 'slim-jims' which is a thin, flat, flexible piece of steel that slides easily past the gasket and has a hook-like opening on one end to catch the mechanism.
Sep 13, 2008 | 2002 Ford Taurus
Philco suitcase turntable / cd belt drive
Place the rubber band around the turntable and put a paper clip, bent up behind the rubber band. Start the turntable on it's spindle and you will be able to view that drive spindle on the right side, slowly pull the rubber band with the paperclip and drop over the drive spindle. remove paperclip and push turntable down seating it and replace the lock snap.
Jan 27, 2008 | Philco (R) Suitcase CD Shelf System
Atlus Hotel Dusk: Room 215 for DS Logo
193 people viewed this question
Top Atlus Video Game Consoles & Games Experts
Frank Zabroski
Frank Zabroski
Josh Whitehead
Josh Whitehead
Rhonda Webster
Rhonda Webster
Are you an Atlus Video Game Console and Game Expert? Answer questions, earn points and help others
