Question about Char-Broil 463220004 Grill
RIGHT KNOB MELTED .WHY
THE RIGHT BURNER KNOB HAS FLAMES COMING OUT.
  • mnwild1 Apr 25, 2009
    all the knobs melted on my grill and it is only 2 years old!
  • 257 Answers
Hi, Sorry but nobody wants to give bad news. There is a tube that comes from the control knob to the orifice that controls the amount of gas to the burners, my guess without being able to look at it is that the orifice broke at the connection to the tube and the flames are shooting back toward the knob. However it is possible that the venturi opening ( the screened part on the burner tube that sets on the orifice ) became dislodged. Either way you need to remove the grate, remove the burner assembly and then look ( under the cart from the back) at the tube and orifice for damage. You do not indicate how old any of this is and they do rust out. Parts are available but you have to determine if based on age and damage you want to replace any of it or all of it. If you inspect it and find something that you think you can fix you can get back to us for more help. If it is as simple as the dislodged tube and the parts are OK, reseat it and check it out. I wish you the best of Luck!
Posted on Feb 05, 2009
Pull the ***** out of your *** and go buy a damn WEBBER grill
Posted on Apr 13, 2009
  • KAYSHABUDDY Apr 13, 2009
    OR DO WHAT THE GUY BELOW SAID AND CHECK THE INSIDE OF THE TUBE FOR INSECTS AND SPIDER WEBS.
Tip
How to diagnose a propane BBQ flaming at control knobs
WARNING: this test can be dangerous; do it only if you know what you are doing!
I turned on my two burner propane BBQ. The left side worked OK but flames started coming out of the control knob (front area) on the right, and the right side burner was not lighting.
This is obviously gas leaking out of the front area. If the flames go out when you turn the knobs off then the leak is after the valves, controlled ny the knobs. If the flames stay on and only go out if you turn gas off at the tank then the leak is at the pipe entering the controls. In my case the flames went out with the controls, so I looked underneath. I slowly turned the knob down and saw that the flames (therefore the gas) was coming out of the air regulator/entry hole. I knew at once that the pipe going to the burner must be blocked. Sire enough, when I removed the burners I saw that an insect built a cocoon in the pipe. Clearing it solved the problem.
on Jun 11, 2015 | Cuisinart CGG-200 All Foods Propane BBQ...
Orifices burner flame adjusted
Most burners have an adjustment under the knob. Pull off the knob and use a slender flathead screwdriver. Turn burner down to low, insert screwdriver into knob shaft and rotate internal screw until flame is at "simmer" height. Can adjust each burner separately this way.
Jan 17, 2014 | Kenmore 71042 / 71044 Gas Kitchen Range
Gas flame shoots out of one of the valves when I attempt to light the burner, How do you remove the valve knob. There is a small hole at the bottom of the knob.
I'm assuming it isn't on a riding mower. Is this on a outdoor gas grill? That little hole, by the knob (usually two) is where the mixing air enters the burner. Most likely that burner's openings (holes the flames come out of) are clogged, preventing the gas from flowing to burner. Then it comes back out where the air is supposed to enter. Remove burner and either ,clean or replace.
Oct 28, 2010 | Garden
Viking grill burner is clogged and fire is shooting out of knob. How do I clean my grill from excessive grease.
Is it still under warranty? I'd call Viking or a qualified repairman to fix it. If your burners are clogged, the flames should be coming out the venturi tube and flaming towards the gas valve knob. If the flames are coming out of the gas valve itself, then it will need to be regreased. If the burners can be removed without too much trouble, soak them in the sink with hot water and dishwashing detergent. Be sure to remove the knobs, so no one turns the gas on without the burners connected. If it's difficult, call a repairman.
May 12, 2010 | Grilling
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Spurting flames from my right burners temp knob.
The tube is worn out and probably has a large hole in it. Replacement is easy.
Apr 11, 2009 | Ducane 436 inch 2 - 2 burner Grill
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Char-Broil 463220004 Grill Logo
684 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
