Question about Bernina Artista 180
Bernina 830 stuck
My 1981 Bernina 830 was serviced, then stored for a year. Today I found it is stuck. The motor works but the needle doesn't move. It filled a bobbin just fine. Suggestions?
    Problem Solver:
  • 5 Answers
You probably have a crack in the cam gear.
Posted on Jul 25, 2009
    Problem Solver:
  • 9 Answers
Okay, my first take—because it fills bobbins "just fine"—is that the needle bar may be loose. You didn't specify what the service was for: was it just a clean and lube, or did you have a problem? Even with just a clean and lube, the needle-bar height may have needed adjusting, and the tech may not have tightened it securely. Does the needle bar move at all? even just a quick **** or two? If it acts like it is trying to move, but doesn't, that is probably the problem.
Now, here's the bad news (always seems to be some of that with these kinds of things, eh?): That needle-bar height is critical, and it's not something I can just tell you how to do here. The second bit of bad news is that the problem wasn't discovered for a year, so any service warranty is long expired, by now (unless the owner or manager of the store is your bosom bud, or, you are one of his/her best customers).
The good news is, if the shop is reputable, you could return it to them, explain what happened, and ask how much they would charge just to adjust and secure that needle bar (although the machine could probably use some more oil, by now—because it has just been sitting, which is harder on them than if you use them regularly). If they are like the shop I worked for, they will be glad to give you a slightly discounted rate to preserve their reputation, and hopefully, your business relationship with them. They may even throw some oil on it for the same price.
One more bit of good news, the Bernina 830 is one fine sewing machine. It is worth fixing, if any machine is.
Hope this is helpful, and happy sewing!
Ken
Posted on Feb 06, 2009
Needle threaded is stuck in up position will not return 830 bernina
Bernina 830 Record??? Or newer Bernina 830 computerized?
If it's a Record, could very well need a good cleaning and oiling. Older mechanical machines need periodic lube to keep them running smoothly and quietly.
Wheel on right side that controls the needle up and down is very tight...
Feb 11, 2017 | Bernina Sewing Machines
Cant get benina 830 to turn on
take it in for a service
could be foot pedal problem or motor problem
Dec 16, 2016 | Bernina Sewing Machines
Concerning 1970s 830 Bernina. There is no motor sound..nothing. Are the carbon brushes in the pedal?
The 830 models varied so I'm not sure. My machine looks like this:
Bernina 830 sewing machine feet pedal accessory box table instruction...
If you scroll over to the photo of the motor, there is a white plug which pulls out. Underneath, there is a screw. The carbon brush may be there. However, some 830s had the speed switch on the machine (right above the knee control) and others have it in the foot pedal.
I found the following information in my computer files that may be helpful: Bernina 830 Motor Brush Replacement
My machine is actually a Bernina 830 (mechanical 34 years old) I need to know how to get the housing off the motor so my hubby can replace the brushes
Re: sewng machine motor housing
DISASSEMBLY TO INSPECT OR CHANGE BERNINA 830 MOTOR BRUSHES:
Remove the big plastic cover piece on the bottom of the machine with the single screw in the center.
Remove the machine's end panel by removing the single silver screw from underneath the bottom middle of the side panel. Pull the bottom of the side panel out and down to remove it. It comes off easily.
Remove the two screws under the motor assembly (silver screws with black washers).
Swivel the motor assembly enough to remove the belt.
There is a another plastic panel on the motor assembly over the motor itself. Remove the two phillips head screws to remove this panel.
At this point you can see the commutator and inspect the "business" ends of the brushes. (In our case, one brush was almost gone and there was nothing left of the second brush except the spring!)
You can then slide the motor out of the housing. I pushed on the motor pulley and pulled on the other end of the motor with pliers. The motor comes out rather easily, but be careful not to disturb the wires any more than necessary.
With the motor exposed, unscrew the caps over the brushes and remove the brushes.
Our motor's commutator looks significantly worn and the motor may need to be replaced.
FWIW, if your machine hasn't been oiled for a long time, you should probably take time to do that. When the old oil solidifies, it sticks the moving parts together. Forcing the motor to try to run the machine can damage the machine. Use fresh good quality sewing machine oil or (I use) liquid Tri-Flow Synthetic Lube and apply a couple drops every place metal rubs on metal. (Wiggle the handwheel and watch where things move.) Do NOT oil belts, synthetic gears, cams.
Oct 22, 2016 | Bernina Sewing Machines
My old Bernina 830 has ceased after not being used for 8 years what can I do?
I have resurrected several older Berninas with lots of patience and elbow grease. Here's how:
Bernina 830 Record oiling points:
Dec 29, 2015 | Bernina Sewing Machines
I need a wire diagram for my bernina 830, please help I am out of commission until 8 get this back together! ! I have the original machine manual but that doesn't go into the wiring of course! I had to...
You will have to deal with this site being in German but it's not difficult to get to grips with. The site is a bit randomly disorganised (much better than it used to be). You'll find lots of other information scattered about the site.
Try the following links:
S21 Elektrik 1 Herzogenbuchsee Info BERNINA Service Tipps Lenco Switzerland
S22 Motor Service Herzogenbuchsee Info BERNINA Service Tipps Lenco...
and here:
830 Record Serie Herzogenbuchsee Info BERNINA Service Tipps Lenco...
I hope this all helps.
Mar 17, 2015 | Brother Sewing Machines
Need to download a free repair/service manual for a Bernia 830
Request the repair/service manual directly from Bernia (Bernina?). It may or may not be downloadable.
Jan 04, 2015 | Sewing Machines
I have a bernina 740 semi-industrial it just came to a halt and wont move
check with bernina to see if the machine has a hidden fuse & if it doesn't then the machine needs to be serviced
May 19, 2012 | Bernina Sewing Machines
Bernina 830 stopped running
Motor brushes are usually the problem
Jan 03, 2009 | Sewing Machines
My machine Bernina 830 does not run.
Hi Rose Mary,
I'm assuming you are talking about the original Bernina 830 (their newest machine is also an 830!)
If you've not had your machine professionally serviced in awhile, it could be as simple as a good, thorough cleaning and adjusting. Your machine should be professionally serviced about every 1-2 years....not a bargain service that blows out the dust and puts oil on the hook, but a service that checks all the gears for wear, adjustments, hook timing, feed timing, grease for the gears (if required), removes lint build-up deep in the machine - very thorough.
There are various gears in the 830 that control these functions. It sounds as if one of the gears may be either broken or jammed. Unfortunately, unless you are trained in machine repair, this isn't something you should attempt. When gears are replaced or adjusted, generally the timing of the machine must be reset as well.
We would recommend that you take your Bernina to your nearest authorized Bernina dealer (they'll be trained on your specific machine and have easy access to any parts that may be needed).
If you do not know a dealer in your area, you can search on the Bernina website.
The original Bernina 830 was one of the greatest models Bernina has made and is well worth putting the money into keeping it running. Great machine!
Hope this helps narrow down what may be happening.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Nov 29, 2008 | Sewing Machines
Sewing Machines Logo
841 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
