Question about HP Photosmart C5180 All-In-One InkJet Printer
HP Vivera printer won't print
Error message says carriage cannot move, to open doors and remove paper jams or packing material. There are no obstructions and the carriage can move. Still I get the error message
I had a paper jam from a label coming off while it was printing. I was able to
clear the lable out by taking the pack panel off. Now the printer makes all the noises it should, but doesn't pull any paper threw. Help
Posted on Dec 10, 2011
    Genius:
  • 1,847 Answers
Take the cartridge out and clean the head with dry cloth and reinstall than then try.
also go to menu on the printer and out it back to factory settings.
Kevin
Posted on Feb 15, 2009
Paper keep jamming
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 29, 2010 | HP Officejet 5510 All-In-One Thermal...
Printer carriage jam and then locks
Dec 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
My Hp 1320 is printing previous jobs on current print outs and is jamming paper
Nov 25, 2010 | HP LaserJet 1320 Printer
Paper jam light on permanently, printer is jammed
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 25, 2010 | HP DeskJet 970cxi InkJet Printer
The problem is cartridge error.I cannot print.what will i do?
Nov 24, 2010 | HP Officejet 4355 All-In-One InkJet...
I have paper jammed in my HP DESKJET PRINTER D2260. Tried to pull it out but paper ripped off and can still see other end still in there. Been advised to open back door and clear it but cant see how back...
Nov 18, 2010 | Office Equipment & Supplies
My printer isnt feeding paper in straight and it keeps on jamming and saying that there isnt any paper.. is there anything i can do to esay fix it???
Oct 25, 2010 | Office Equipment & Supplies
Our HP Office Jet Pro 8500 printer has a message stating there is a paper jam when there is no paper jam. How can this be fixed?
Check the following Steps for fix Hp printer carriage Jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Carriage Jam
If either a paper jam or blocked carriage error message appears on
the control panel display, there might be some packing material inside the HP allin-
one. Lift open the print-carriage access door. The orange shipping lock might
still be in place on the left side of the HP all-in-one. Pull out the orange shipping
lock and throw it away
Jan 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Not printing
in the front panel display there might be some packing material
inside the HP Officejet. Lift open the print-carriage access door to
expose the print cartridges and remove any packing material or
other items that do not belong there.
Jul 28, 2008 | HP Officejet 4215v All-in-One Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
1,806 people viewed this question
Seeker5211
Seeker5211
