Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Arc or hump on bottom left of tv and color is faded bad.
The tv started with a big hump on the bottom left side and the color started going out. I unplugged it overnight and that fixed it. turned it off again and it came back bigger than it was and now wont go away. the picture distorts around the hump and the color is shot. everything is pink or just plain faded out. thanks for any help you can give me.
    President:
  • Philips Master
  • 1,779 Answers
Your convergence Ic's have gone bad. Most likely a few small resistors with them. It's really not a job you should try and takle if you haven't done it before. Not a major deal for a svc co.
Posted on Feb 05, 2009
Color fading from left to right
I'm sorry to hear that you're having this issue with your TV. It may be an inverter board, or something internal having to do with the backlighting of the unit. I would recommend having the unit inspected by a technician.
Nov 06, 2013 | Philips Televison & Video
Red lines on Samsung UN46B7100. Is this the TCON board or the panel?
Have you checked all cables first? Color fluctuations and problems of this nature can be caused by a bad VGA/HDMI/Component cable. Try plugging your source device into other inputs and see if you get the same result. If that happens you more than likely have a bad video card.
Aug 31, 2012 | Samsung UN46B7100 45.9 in. LCD TV
White arcs across screen when the screen is dark or black.
Replace a color gun in your KP51HW40. Then adjust the picture brightness to eliminate these rings by turning a little button behind the front (cloth like) panel (the one covering the front bottom half of the set). You may have to to dim the lights to be able to do that properly. The little dial button as is in the middle.
Jul 03, 2010 | Sony KP-51HW40 51" Rear Projection...
Blue arc and ghosting across middle part of screen.
Replace Both of your convergence ICs they are big Black ICs will have STK on them! Use STK392-150s or the 180s Better ICs Call Mats Electronics 1-800-628-1118
Dec 21, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
RCA P52754AT POPPING SOUNDS. COLOR FLICKERS AND
It sounds like your high voltage block is arcing and causing the TV to go into protection shutdown temporarily. If that's the case, you'll most likely need to replace that HVB.
The other thing it could be if you're hearing "popping" (snapping ?), is that one of the CRTs could be arcing to ground, maybe the green one since you're getting too much green.
Good luck.
Nov 28, 2009 | RCA P52771AT 52" Rear Projection...
Kines on Screen and Fading
Open up the front of the set by removing the speaker screen and the black piece of particle board. on the bottom right you will see 4 knobs. Turn those knobs slowly till the arcs go away. The 3 knobs on the bottom are for color. the 3 on top are for the focus.
Jun 30, 2008 | Sony KP-51HW40 51" Rear Projection...
Faded left hand copies
Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
Jan 23, 2008 | Konica Minolta magicolor 2400 Laser...
Faded colors
moniter colours changed what prabulem
Nov 22, 2007 | Samsung SyncMaster 793MB 17" CRT Monitor
Arcing noise in big screen tv 1996 rca
Probable bad HV block Part # 205064
Possible bad CRT = disconnect HV leads one at a time from
HV block until arcing goes away
Please rate this solution..........
Nov 14, 2007 | Televison & Video
Color off
You need to have the pins of your convergence IC's checked for ring cracking. That cooling-off period is probably just enough to bring the crack(s) back into contact with each other and as they heat up they separate. It doesn't sound like a IC or component failure, at least not yet. But if it's ring cracked that arcing that happens is placing stress on the Ic's and they could eventually fail... Good Luck Bill
May 24, 2007 | Samsung HCL552W 55" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
