Question about Ingersoll Rand 3/4" Super Duty Extended Anvil Air Impact Wrench
IR 261 air wrench vanes sticking
I use IR 261 guns. We tighten 1000 1/2" bolts a day per gun. I cannot keep a gun running for more than a few days before the vanes stick into the rotor and you can't get the gun to start. It just puffs air. I'm running 100-120 psi, filter, oiler. I have put in new vanes, have run them dry, wet, very wet, and have tried every combination possible. We even buy new guns that only last a few weeks before they start doing the same thing. I have also had the same problem with 271 guns. I'm at my wits end!
  • joebob101 Feb 26, 2009
    Thanks for your suggestions. I'm going to try them. I do have clean air (filter/drier) and an in-line mister. I changed the air pressure to 90 psi per factory reccomendations. The comment you made about the vanes absorbing oil was interesting. When I have the problem, a few vanes always seem a little tight in the rotor. I use limited oil, but ususally am pretty liberal with the oil during assembly. I might be getting oil absorbtion problems on those fiber vanes. I found a place yesterday that makes polycarbonate vanes and have ordered some of them to try. I'm using this big gun because it drives the nuts much faster than a 1/2" wrench. We have it suspended from the ceiling with a tool balancer so the weight isn't a factor.
  • 32 Answers
NOT exactly a solution, but may help you with your problem: I'm also a Owner of a 261 ( In fact 90% 0f all my Air Tools are IR) that I used everyday when I was working on Terex Equipment & EMD Locomotives. I "Upgraded" the Major Parts inside my Gun to the "Industrial Line" rather than the Automotive Parts since the 261 is classified as a Automotive Tool..and Installing an Adjustable Regulator on the Gun Helped a Lot too...by "tweeking" my Gun out, I was Pumping almost as much torque as some of the 1" Guns...
FYI: Don't Over Oil as the Oil will absorb into the Vanes, causing them to Expand in thickness "Permanently"...just 2-3 drops of a Hi-Grade Air Tool Oil before starting the Day is enough...sounds to me like your Picking up some contamination someplace??
Posted on Feb 21, 2009
  • Rick Wymer
    Rick Wymer Feb 26, 2009
    Follow-Up:
    I checked with my Local Authorized IR Repair Center about your Problem. We both agreed that you should install new Vanes(make sure to Wash Out the Parts with Hi-Grade Clean Solvent & Air-Dry), making sure the work area is completely Dust free when you put it back together. Just 2-3 "Drops" of a Hi-Grade Air Tool Lube every 2-3 Hours of Use is Plenty, But a Compressor In-Line Mister is a Superior remedy to adding Lube.
    You didn't say "IF" your Compressor(Main-Line) has a Oil/Lube Mister In-Line??
    Are you getting Condensation in Your Main Supply Line, may want to add a Air Dryer if Not.
    "Auto-Drain" on your Compressor?? I run Auto-Drains on the Compressor Main Drain & on my Main Regulator.
    At the End of a Day of Use:
    I Like to Add a Couple of Drops of Lube, and Run the Gun in Forward and Reverse a Few times (No-Load), before putting it away....
    Hope this Helps You!
    If your ONLY doing 1/2" Bolts(?) won't a 244 work for You, 261 seems a Little Heavy Duty for that
Impact turns but no tork why
An impact wrench works by directing air into a chamber where a hub with sliding vanes turns to do your work for you. If any of the five or six vanes are damaged the tork value will go down. It is possible for the hub to turn freely however the more air that gets past the vanes, instead of pushing on them, the lower your tork value will be. The bearings for the hub could be damaged or seized but that usually affects free spinning speed more than tork. The insides of an impact wrench are fairly simple, take it apart and check the vanes and bearings. Ingersol Rand makes rebuild kits for most of their impact wrenches.
Aug 17, 2012 | Ingersoll Rand Ir 2131qt 1/2 Impact Wrench
I have the titanium 1/2 impact gun and in foward or reverse the gun some times stops working and just blows air like a bad o-ring but i really dont know thanks
The vanes in the air motor are worn. There is a flat spring that pushes the vanes against the cylinder to maintain a seal... They go weak after a while
Aug 15, 2011 | Ingersoll Rand 2135PTI Pneumatic Titanium...
When the trigger is pulled air blows out a vent at the bottom and the anvil doesn't rotate.
If debris enter the gun, over time the vanes will not move into proper positon and react to air-flow. Vanes can become stuck if stored for long period of time. Pour small amount of diesel fuel into the gun and activate the trigger. The fuel should come out clean, if however black gunk comes out, keep adding fuel until gun is clean. Eventually all the the debris will be washed out and restore function. Good luck
May 31, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
I have model 261 3/4 in drive impact gun. When in tighten mode it doesn't work all the time. It does work and then it doesn't, all you hear is air.
Air motors have plastic fins in them that make it turn. They slide in and out of slots on the motor. You can tear it apart and clean them, but if you don't put all parts back in just right, gun will not work at all. I usually try to run wd-40 thru the gun. It is messy, but the more the better. You can also use carb cleaner (brake cleaner will eat paint, rubber, anything pastic) and then oil with air tool oil. Careful of the cleaner it is flammable!
Feb 24, 2011 | Ingersoll Rand - Rand IR - 252 3/4'' Heavy...
I have a 1/2") Air
Does the drive move if you try turn it manually, if it does not strip the unit and check the bearings. If the motor and vanes are seized the air will just vent out of the exhaust. If it turns, Dismantle the trigger and air inlet valve and check that for sticking, leaking or broken parts.
Jan 29, 2011 | Garden
Older Pl1502 professional - relatively light usage but suddenly will not loosen my Chevy half ton lugs. Unit - doesn't spin up - very low torque. Other guns I use behave as they should. vanes appear...
The inlet air valve the trigger operates. Revisit the vanes. Look for cracked or chipped corners. The spring behind the vane can be weak too. The overall depth of the vane can be worn enough that the vane leans in the groove allowing air to escape lowering the power applied to the vanes.
Dec 04, 2010 | Campbell Hausfeld 1/2" Impact Wrench
My 772h is running low power i pulled it apart and everything looks great a few light scatches in rear cyl .can i just polish it 320 grit or ??
you need a new rebuild kit with O rings and gaskets,take gun completely apart and make sure you get new air vanes too,the scratches dont make that much difference,but old seals will rob power from gun
Jan 11, 2010 | Chicago Pneumatic CP772H - 6 3/4" Heavy...
I get no movement on the socket just air blowing out of the bottom of the gun
The air motor is probably shot. Turn the socket a few revolutions by hand, and see if it frees up and starts working. A couple of firm raps on the workbench might help. Otherwise take it apart and see whats up. You'll probably find worn vanes or a vane stuck in the rotor. There will be several vanes, and they must slide in and out of the rotor easily. If you arte lucky you'll just have to clean out, lubricate, and reassemble.
Dec 12, 2009 | Craftsman 1/2" Impact Wrench
It does nothing
Make sure that you have at least 50 psig of air pressure before you attempt to troubleshoot your impact. 70 is better, 90 is perfect. Impact wrenches are powered by internal sliding vanes, which can sometimes stick. There are a couple of ways to get it going again. Try 1 before going to 2, etc,:
1. Spray W-D 40 or a similar oil into the impact, while you are holding the trigger down. Give it a good shot. Connect the hose and pull the trigger. Tap the sides of the gun with a plastic hammer to help free up the vanes. Repeat. Normally, this is enough to get you back running.
2. Place it in a bucket and cover the gun with W-D 40. Work the anvil end and trigger to work the oil deep into the gun. Ley it soak 1 hour, and repeat the process, working the oil in, and the air out. Remove it from the oil, and drain the oil back into the bucket by holding the trigger down. Hook up the air, and blow it out.
3. Remove the cover on the head that covers the vanes. Make sure that the vanes will slide freely, and that all gaskets and "O" rings are in good condition. If you note any dry areas in the inner parts of the impact, lubricate with W-D 40, and reassemble.
4. I'm all out of ideas.. If that didn't fix it, I'd go get a new one.
Best of luck, --W/D--
Aug 13, 2009 | Air Tools & Compressors
Ingersoll Rand  3/4" Super Duty Extended Anvil Air Impact Wrench Logo
1,675 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
