Toshiba Satellite A105 Notebook Logo
Posted on Feb 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My bottom task bar periodically disappears
I have a toshiba lap top
I use window vista home premium
about once per week, my bottom task bar disappears. The only thing remaining is the windows start icon. The clock and all else is gone. I have to restart and then I loose everything that I had minimizede prior.
Thanks
Anonymous
Level 3:
Genius:
  • Master 1,605 Answers
  • Posted on Feb 05, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1605
Questions
Helped
746879
Points
3939
Right click on the butttom tool bar, select properties.
uncheck the auto hide the tool bar.
close the properties page.
David Shaub
Level 3:
President:
  • Master 2,994 Answers
David Shaub
Master
Level 3:
President:
Answers
2994
Questions
Helped
1153341
Points
8370
When you see the task bar, right click on it and set it the way you want it to work.
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
I have acer asprse 5315 i just put windows vista home premium .. and it work for 1 week then my computer shut down and its appear on the screen you need a product key ... then i put my lap top product key...
Unfortunately, you have to have/purchase a product key for each copy of the Windows OS, in this case Vista. The XP key will not work. And the key has to be for that particular version ie: Windows Vista (TM) Home Premium.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Scroll bar disappeared in Windows Vista e-mail
1. click on the 'Tools' menu then the 'Options' option.
2. click on the 'View' tab.
3. - in 'Window Options' section, ensure that the 'Horizontal
scroll bar' and 'Vertical scroll bar' options are selected.
-- PowerPoint - in the 'Show' section, ensure that the 'Status bar'
and 'Vertical ruler' are selected.
4. click OK.
3answers
The sound icon is no longer on the task bar. I can't control the sound.
Click Start
Click Control Panel
Click Classic View
Click Sounds and Audio Devices
Click Place Sound Icon on the Task Bar
(so that the check-mark is removed)
Click Apply
(so that the check-mark is restored)
Click OK
Done.
The battery icon has disappeared
Did you inadvertently move the task bar below the bottom of the screen per chance?
If you are plugged in, the battery icon will be replaced with a plug.
If you need addidtional help with this, let me know. I want to help you
a
2answers
Windows vista home premium taskbar troubleshooting
dear sir
please click on the task bar drag it & drop it on the bottom of the desktop
regards
murali
Disappearing icons in notification area of taskbar
Open task bar properties, from control panel, choose taskbar and start menu. Uncheck the check box at the bottom of the window.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
