Question about Sony Playstation 3 (PS3) Console
Ip address when i test the connection the ip adress keeps on timing out.
  • shorty_boi Feb 06, 2009
    ok , when i first got my ps3 i tryed it on automatic and it didnt work so i tryed it on manual and still not working , i made sure i typed the wpa key in correct. how do i check the modem connections?
  • 39 Answers
Check your ip configuration again if you set it up manually, set everything to automatic for easiest setup. If it continues to time out check you modem connections, and make sure if you have a router that you are entering any wep keys that are setup for the router.
Posted on Feb 06, 2009
I have been having issues with my internet connectivity for a while - its been fix after fix and i feel like im slowly fixing the problem but adding more onto it. The exact problem from the top - Spee
Problem is that ipv4 config.
For any computer on a home network an automatic IP-address is handy. So the ipv4 config should be set to DHCP.
But then there should be a router that hands out IP-addresses and the IP adress of this router should be given in the ipv4 config as Standard gateway.
That is for home, but to resolve internet adresses your computer needs DNS, you can use common dns servers, or the ones given by your internet provider.
Fill these in under DNS in the config.
Aug 23, 2014 | Microsoft Windows 7 Home Premium 64BIT...
My ip adress on my xbox keeps failing the test. what should i do?
Try setting them up with a static IP address. Meaning set it manually including the IP address, DNS servers, subnet mask, gateway.
May 19, 2010 | Microsoft Xbox 360 Console
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
What is it?
default is, but you can check by ip gateway (modem adress), on your computer.
check your local network connection:
if your modem is directly connect your computer, by usb or LAN the gateway adress is the same, you can test if go to the webrowser and type the same adress as before.
Attempt to obtain IP adress failure
contact your internet provider and have them unlock your IP address
Aug 24, 2009 | Dmm Call of Duty: World at War
Router wont let ps3 have ip adress
you need to open a incoming port for the ps3 on your router all you have to do is use the computer to go to your router settings then use whatever ip the ps3 is using and open a port for that ip address that should work but i dont have a ps3 so i dont know you could try that
May 09, 2009 | Computers & Internet
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Right ip adress in xbox360 but it keeps failing..?
You don't set the IP address (You can but that's a whole nother story, IP address' have to be unique to the device), you need to let your router assign one automatically. Two devices on the same network can't have the same IP address or it will fail to function completely.
Dec 30, 2008 | Microsoft Xbox 360 Console
Xbox 360 live
find the IP adress on ur router if its wirless
May 16, 2008 | Microsoft Xbox 360 Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
