Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
Installing wireless adapter for xbox 360. Asks for wep code
I have comcast internet service. Can I use this and how to find wep code.
    Brigadier General:
  • 8,619 Answers
Hi!
You can see this link for the procedure--
Xbox Connection settings
Also see this link for details---
Xbox wireless
WEP code will be provided to you by your comcast. Check this link for wep key---
Comcast
and
WEP Code
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Posted on Feb 05, 2009
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
Tip
How to set up WiFi on XBOX
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
on Feb 07, 2010 | Video Game Consoles & Games
Can't get my wireless adapter to get connected to then wireless network
Hello
Go to your pc and get on internet explorer.Type 192.168.1.1 in the address bar.Hit enter
Username is admin
Password is password or admin
Once in get the wireless code or wep code and write it down.
Start x box,Go to network settings or wireless settings and put the wep code into the x box.
This should get you going.
Jan 08, 2011 | Microsoft Wireless Network Adapter Xbox...
My black wireless adapter is contiuesly disconnectiong from xbox live and is always lagging in games with other people
Hello
Probably not the adapter.
Try rebooting your router/modem
1 unplug all cables and shut router down.
2 Find reset button,usually small button behind router.
3 Hold in reset button with a pen tip or paper clip for one minute.
4 Reconnect router and power up,wait for all lights to come back on.
5 Try x box or internet again.Double check your wep or wire less code in x box internet settings.
Jan 04, 2011 | Microsoft Wireless Network Adapter Xbox...
I have a used xbox 360 wireless adapter. Where do i find the WEP key?
the WEP key is found on the wireless page of the router's setup interface.
Dec 26, 2010 | Microsoft Wireless Network Adapter Xbox...
How to hookup wireless internet
XBOX 360 WIRELESS ADAPTER
I assume the wireless router is configured correctly and the PC can connect to the wireless router and the Internet.
Follow these instructions to configure the XBox.
  1. In the Xbox Dashboard, go to My Xbox and open System Settings.
  2. Select Network Settings, Configure Network.
  3. On the Basic Settings tab, select your wireless settings.
  4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
  5. If your network has wireless security, enter your WEP or WPA key.
  6. Try to connect to Xbox LIVE again
Dec 23, 2009 | Microsoft Wireless Network Adapter Xbox...
My wireless has a WPA key and Abox is asking
  1. Plug in the Microsoft Xbox 360 Wireless Adapter to one of the USB ports on the back of your Xbox 360.
  2. Turn on your Xbox 360 and navigate to "My Xbox" and then "System Settings."
  3. Go to "Network Settings" and then "Configure Network."
  4. Select the appropriate settings for the wireless network you will be connecting to on the "Basic Settings" tab.
  5. Enter the name of the SSID of the wireless network you will be connecting to. If the SSID is not broadcast, select "Specify Unlisted Network" and enter in the SSID of the network manually.
  6. Enter in the wireless security key (WEP or WPA) so that your Xbox 360 can access the network.
  7. Select "Test Xbox Live Connection" back on the "Network Settings" screen to verify that your Xbox 360 is now connected to the wireless network and ready for use.
Should work for either WEP or WPA
Sep 24, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
I got a new xbox 360, and i need to connect my xbox back
you need to go to your xbox settings and your network settings, find your network and put in the wep key for your router. If you don't know your wep key for your router, the easiest way to find it is to go on your computer, open a browser of some kind (e.g. internet explorer, firefox, safari etc.) and type in the ip address. The most standard ip address is 192.168.1.1 or something close to that. It should bring up the settings for your router and you can find the wep key usually under the wireless tab and then wireless security and your wep key should be right there! enter it into your xbox and have fun gaming. =)
Jun 16, 2009 | Microsoft Wireless Network Adapter Xbox...
I am trying to set up xbox live for my son but when i try to go live on the xbox dashboard it says that wireless network not connected but i have a wireless network running in my house and need to know how...
Tips:
What You Need:
  • Active Xbox Live subscription (to access services)
Source: About.com
Sep 29, 2008 | Computers & Internet
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
1,663 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
