Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba L300D-18E... won't load up past splash screen
I start my computer as normal and i get to the windows splash screen with loading bar, all looks normal but just hangs there... then eventually restarts. I've just had the laptop back, with a new hard drive for two weeks and now it's doing this. The Laptop isjust under four months old. Can anyone helo? thanx!
    President:
  • 778 Answers
Less than four months old (still in warranty), just back from hard drive replacement (recent service issue). Take/send it back as this is a warranty issue.
Posted on Feb 05, 2009
Toshiba satellite problems L775 can't get past "windows is loading files"
First restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
Jul 03, 2013 | Computers & Internet
TOSHIBA L300D
if your laptop doesn't find your drive it won't be the lens.check in your device manager and see if there is any drive showing and if there is a problem with the driver.
Sep 13, 2012 | Toshiba Satellite Computers & Internet
Will turn in but won't really start up, message pops up sayin I have problems on my laptop but it can't fix them? Read description
When your toshiba splash screen is showing on startup, press F8 continuously, then you should get some options, go to the one that says safe mode. After loading windows in safe mode click start, search, and type system restore. Open system restore, find a date where your pc was working correctly and click restore. If this doesn't do it on the toshiba spash screen (if you have a new enough laptop) there will be an option called system recovery usually f11 key, this will restore your pc back to its factory state and should resolve any problems your having. If you don't have that option go to https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp and see if you can order a set of recovery disc's for your model, they usually run from $25-$30. Hope this helps.
Mar 01, 2012 | Toshiba Computers & Internet
Won't find solution to problem and start up
While booting up you should try holding f8 right after the manufacturer splash screen the select safe mode with networking once in there you will want to restart the computer if all is well it will boot into windows! hope i could help =]
This morning I turned on my laptop and all it is trying to do is load the microsoft page. All I see is the rectangle bar with the lines going through trying to load.... Please help, important documents...
restart the computer. when the splash screen comes up that says TOSHIBA keep pressing esc or F8, then open in safe mode. copy the files onto usb so you dont lose them. then reload windows.
May 11, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L300D Start shows the Toshiba screen except BIOS hotkeys are not listed at the bottom.. then a black screen with a white bar at the top left freezes and thats it. Taking the battery and...
Black Screen with White bar is when Windows Vista loading. So it seems there is maybe problem with Windows.
When your Toshiba is starting up - try press F12 to enter Bios, to check if everything is OK.
If you have Vista on CD/DVD - you can try press "C" on keyboard when Toshiba start, to boot from CD/DVD and start to repair your OS, or reinstall it completely.
Here - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/globalEntitlement.jsp you can find repair centre for Toshiba near you, so they can help you.
Support Contact Numbers:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=su_contact&pf=true
Or use their forum
http://laptopforums.toshiba.com/t5/System-Recovery-and-Recovery/bd-p/brd_recovery
Sep 21, 2010 | Toshiba Satellite A60 Notebook
Cant get past microsoft windows loading bar
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 26, 2010 | Toshiba Satellite L355D-S7809 Notebook
Wont get past Microsoft Windows XP loading screen on Acer Aspire1
Feb 17, 2010 | Acer Aspire One AOA150-1126 Notebook
I got a virus, removed it with anti virus and malware removal tools. When I tried to defrag would stop at 14% saying it was done, but still many fragments. Screen went blank, restarted but cannot get past...
Hello
Thank you for using
FixYa for your problem
Have you done a repair with the XP discs
Also there is a disc called techey tool kit, in this there is a HDregeneration program, run this to scan and repair the HD
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Toshiba Satellite Pro L300 Notebook
Icons and start lost
If you're looking for the quick launch icons on the task bar, right click on the task bar, click properties, then check the box that reads show quick launch, apply, and they should return.
Jun 12, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
208 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
