Question about NRS SPO Medical 903036 Check Mate Pulse Oximeter
No reading for the blood oxygen level
I have just replaced the battery in my Chckmate oximeter. When placing my finger into the monitor, I see the following: SPO, then a beating heart, then a pulse rate which is much higher than the actual rate, then a correct pulse rate, then with two dashes in the Oxygen level indicator and then almost immediately followed by 3 dashes in the pulse rate indicator. The back up light is working. I do not have the manual that came with this product so I don't know what the 3 various symbols at the very top, which appear, are indicating. Can you help??
Thank you. Blanche Matthews
  • rjqman Feb 23, 2009
    I have the same problem, except that I did not replace the battery, Thie indicator says the battery is fine. I cleaned the inside as best I could without any swabs or alcohol, and tried it again, and it worked ok - once - then it started to do the same thing you descirbe - the heart flashes, the pulse rate reading jumps around and is obviously wrong, and the oxygen does not indicate at all. The indicator at the top, when on, says it means a 'weak signal.' But there is no clue how to make the signal strong. I plan to use alcohol tomorrow and swab out the finger insertion area and see if that fixes it or not. I do not have any with me - I am traveling and in a hotel. I think that something needs cleaning in there, but it is just a guess. the instructions can be downloaded easily and they say how to clean it, so I will try that.
OK - I had the exact same problem. I cleaned the inside of the oximeter with a cotton swab and denatured alcohol. Then tried it. It did not work. Darn. But I tried it an hour later, and suddenly, it started to work perfectly. I do not know what went wrong, and why it did not work immediately after cleaning. Maybe it was still damp from the alcohol? Unlikely, but I cannot figure out anything else. Anyway, try that and see if it solves the problem for you, and if the oximeter does not work for the first hour or so after cleaning, don't give up on it. Good luck.
Posted on Feb 24, 2009
What is Err 7 on the medline Finger SAT Pulse Oximeter
Error7" displayed on screen Error 7 means the emission LED or reception dioxide is damaged. Check the emission LED and reception dioxide.
Jul 22, 2015 | Medline Onepiece FingerSAT Oximeter
What does a pulse oximeter measure?
the pulse oximeter measures the oxygen saturation of your blood without having to take a blood sample
Jan 30, 2013 | Health & Beauty
What exactly is a pulse oximeter?
A pulse oximeter is a medical device that indirectly monitors the oxygen saturation of a patient's blood (as opposed to measuring oxygen saturation directly through a blood sample) and changes in blood volume in the skin, producing a photoplethysmogram.
My mother has a Digit Pulse Oxymeter and I was wondering how one knows if the %oxygen is reading correctly. Lately all her readings are always 97%. Very little variation.
The normal oxygen saturation in the body read by the any pulse oximeter whether it is portable or built in type is 95%-100%. If ***********'s oxygen reading as you have said is 97% definitely it is within the normal range. You can also check and make sure that your oximeter is working by placing the oximeter to your finger. If the pulse read by the oximeter is the same with your heartbeat it means that is working alright and the oxygen reading would fall between 95-100%. I hope my answers will help you.
Aug 26, 2010 | Probasics Digit-Ox Finger Pulse Oximeter
Directions on replacing battery
Found manual online and found page with replacing batteries instruction
Feb 04, 2010 | Probasics Digit-Ox Finger Pulse Oximeter
While connected it says "please check connection and try again"
A few things could be going on.
First the unit
1. Remove and replace the battery to "reset" the unit.
2. If the batteries are old, they might need replaced.
3. If it has been used and is dirty, clean the sensors.
Second the finger
1. If there is poor circulation from: low heart rate, poor circulation, or cold fingers, the unit will have difficulty.
2. Dark pigmented skin can cause errors.
3. Fingernail polish will cause errors.
Here is some more info for your finger oximeter
Sep 27, 2009 | NRS SPO Medical 903036 Check Mate Pulse...
Torn yellow ribbon - Model 950 Respironics Oximeter
I sounds like the wire that connects on of the sensors is severed. If your still under warranty, I would contact respironics for a replacement or repair. The wires are normally soldered to the sensors so if your have the equipment and ability, you can try to install new wires. Look for a red light if you don't see it where the finger goes, your suspicions are probably confirmed. Most the time we find it easier to replace the oximeter. Here is a site that allegedly has all the finger oximeters available
Aug 09, 2009 | Respironics Finger Pulse Oximeter 1 year...
Blood pressure measurements support
There are two positions for taking your blood pressure measurements: Sitting down - Place your elbow on a table. Using a flat object as support, position your wrist at heart level. Your blood pressure measurement will be too low if you hold your hand too high, or too high if you hold your hand too low. Lying down - Lie on your back. Rest your wrist on a support or cushion with the palm side facing up, position your wrist at heart level. On both of the positions you need to open and relax your hand with the palm facing up (closing your hand will cause inaccurate readings). Do not bend your wrist inward, as bending your wrist will cause inaccurate readings. If possible, empty your bladder before measuring your blood pressure, for a more accurate reading.
Aug 27, 2008 | American Diagnostic Corporation 6016...
NRS SPO Medical 903036 Check Mate Pulse Oximeter Logo
725 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
