Question about HP DeskJet F380 All-In-One Printer
Non transfer scan to pc
I have HPall in one f380 deskjet. should i be able to scan docs. on my printer and they transfer to my pc. scanner light flashes when i press '' printer works in other ways.
  • Anonymous Feb 14, 2009
    i have the same problem. Have you found a solution?
  • suetwelbie41 Feb 18, 2009
    suggestion from rahman br200 . cd reader hp printer deskjet f360 needed. have not yet tried this solution. ray-pc
Cd reader hp printer deskjet f 360 to be work
Posted on Feb 18, 2009
HOW DO i SCAN A DOC.AND SAVE IT TO A FILE
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
Dec 07, 2010 | HP DeskJet F380 All-In-One Printer
My hp dekjet F380 all-in-one
Do not place any paper on the scanner and open the lid and press scan button and check if the light glows and moves forward and backward. If the light does not glow its a problem with scanner light.
Also try to uninstall and reinstall the printer drivers.
Else please refer the weblink given below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=us&lc=en&dlc=en&product=1128296
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
How do i scan using a HP desktop F380
Deskjet F380 features a scanner within the upper portion of the device. "Scanning" an item describes the electronic process of converting pictures or text to data, then transferring that data to the computer as an image. Scanning an item into the computer is a simple task with the F380, the only limitation is the size of the item,
follow the steps below
Step 1
Turn the unit on by pressing the "On" button located at the top control panel. The control panel is located on the left side of the unit. The "On" button will illuminate to indicate that the unit is receiving power.
  • Step 2 Load the scanner with the item to be scanned. First, lift the lid of the F380 to the upright position to reveal the scanning surface. Place the item to be scanned face down onto the scanning surface. Position the item so that the edge of the item rests squarely against the front left-hand corner of the scanning surface, then close the unit's lid.
  • Step 3 Press the "Scan" button located at the lower left-hand corner of the F350's control panel to start the scan. If necessary, the scanning process can be stopped by pressing the "Cancel" button located just to the left of the "X" on the control panel.
  • Step 4 Save the scanned image to the computer when the scan is complete by clicking the "Accept" button on the window that appears on the computer's monitor.
  • Dec 29, 2009 | HP DeskJet F380 All-In-One Printer
    Scan drawing to WORD doc
    i think you can't scan a drawing to word because it's not correspond any character on the computer system or word program..
    May 17, 2009 | HP DeskJet F380 All-In-One Printer
    F380 hp all in one
    This issue occurs if the scanning files are not installed properly. Once search for the hpqscnvw.exe file and try to scan from there and check for the result. If you are able to scan then download scan diagnostic utility from the hp.com and run it. If the issue persists reinstall the software.
    May 20, 2008 | HP DeskJet F380 All-In-One Printer
    F380 all-in-one scan problem
    I have this problem w/a different printer adding it to a computer w/OS Vista. Go to Start, All programs, Accessories, Paint and open that program. Click on File and then From Scanner or Camera. Make sure your all in one is turned on. Unfortunely, there is no fix to make the scanner button work if it is not compatable, such as my 'all in one' w/Vista. Hope this helps. Linda
    Oct 25, 2007 | HP DeskJet F380 All-In-One Printer
    HP DeskJet F380 All-In-One Printer Logo
    217 people viewed this question
    Vinaya Kumar...
    Vinaya Kumar...
    Seeker5211
    Seeker5211
