Question about ScanSoft PDF Converter Professional 3 for PC
ZDplus.exe application error
When I launch PDF converter Professional 3.0 I get this error pop-up that indicates ZDPlus.exe application error. then in the dialog box it indicates "The instruction at....The memeory could not be read. This started last Friday. Has been working for over a year previous.
  • 323 Answers
You are either running out of virtual memory or Zeon DocuCom PDF Plus needs to be reinstalled to fix the error.
Posted on Feb 06, 2009
C++ error is appears
Error "Microsoft Visual C++ Runtime Error..." appears on launch
Problem:
When launching PDF Converter Professional 4, a Visual C++ error may occur which refers to autoupdate.exe.
Cause:
This issue may occur if there is a conflict with the Auto Update tool.
Solution:
In order to resolve this issue, we recommend using either of the following solutions:
Option 1 - Edit the system registry
  1. Click on Start > Run.
  2. Type "regedit".
  3. Navigate to HKEY_CURRENT_USER\Software\ScanSoft\PDF Professional 4.0\Config\
  4. Click on AllowWebUpdateOnInit = 1
  5. Change the 1 to a 0 (zero).
  6. Navigate to HKEY_LOCAL_MACHINE\Software\ScanSoft\PDF Professional 4.0\Config\
  7. Click on AllowWebUpdateOnInit = 1
  8. Change the 1 to a 0 (zero).
Option 2 - Disable automatic updates.
  1. Disconnect the network connections by doing the following:
    1. Click on Start > Control Panel > Network Connections.
    2. Choose each, right-click and chose "Disable".
  2. Try to launch the program.
  3. Disable the automatic update by clicking Help > Nuance on the Web and uncheck the Automatic Web Update entry.
Jul 21, 2011 | Computers & Internet
Tip
Operating System Error FIX
Operating System Error: Error (16291.103.506-73172312.80040154.FFFFFFFF.80040154) is a common problem that pops out before installation of an application which indicates that the system is having a corrupt registry entry. Most of the time, this error affects Adobe Acrobat Reader and Flash installation. <br /><br />The Fix<br /><br />You have to clear the system of the corrupted registry. We recommend using a registry cleaner like CCleaner. CCleaner is a safe and freeware that cleans unwanted files, scans and fixes corrupt registry. You can also use this application to remove programs.<br /><br /> 1. Download <a href="http://download.cnet.com/ccleaner/">CCleaner</a>.<br /><br />Here is video tutorial on how to download CCleaner.<br /><utube src="8wqegYPb_Ms">
<br /> 2. Once installed, launch the application.
<br /> 3. On the left menu, click REGISTRY. Check all boxes.
<br /> 4. Click Scan all issues
.<br /> 5. Click Save for BACK UP CHANGES TO REGISTRY.
<br /> 6. Click Fix all selected issues.
<br /> 7. Once the fix is completed, you can now download the application you were trying to install.
I hope this helps. Cheers!
on Nov 10, 2010 | Computers & Internet
Sir my pc ms office excell and word files not opened some errors came
Click on Start button and click on RUN command. If you don't see RUN command then right-click on the start button and select Properties and select Classic Start menu and Apply and Ok. One you see the Run command, type in winword.exe or word.exe and press ok. If this command doesn’t launch your word application then files might have corrupted. Therefore, you need to repair the whole office suite. To do so, type appwiz.cpl in the Run command box. Locate Microsoft Office program and right-click on the program and select Change and then repair. This may take some time and once this is done, restart your computer and your application should be running up smoothly.
Aug 25, 2010 | Microsoft Windows XP Professional
Missing pdf maker files
Solution Remove Adobe PDF from the Disabled Items list in the Microsoft Office application. To manage your Disabled Items list in a Microsoft Office application:
  1. Open the Microsoft Office application (Word, Excel, Publisher).
  2. Choose Help > About [the application name].
  3. Click Disabled Items.
  4. Select Adobe PDF from the list, and then click Enable.
  5. Quit the Microsoft Office application, and then restart it.
View an Adobe Captivate demo of this procedure
If the error message continues to appear after you enable Adobe PDF, then check the security level for macros in Word:
  1. Choose Tools > Macro > Security.
  2. In the Security dialog, click the Security tab.
  3. Choose Medium or High.
  4. Do one of the following:
    • If you chose Medium, then click OK.
    • If you chose High, then continue with steps 5 through 7.
  5. Click the Trusted Publishers tab.
  6. Check Trust all installed add-ins and templates.
  7. Click OK.
PDFMaker and the right-click context menu should function again.
http://kb.adobe.com/selfservice/viewContent.do?externalId=329044
Thanks
proton
Apr 02, 2009 | Adobe Computers & Internet
Converting from to pdf from the web and won't open
If you are using acrobat professional, uninstall the application completely.clean the registry using some registry cleaning software (tune up utilities for example). Restart the machine. Reinstall acrobat professional.
May 23, 2008 | Adobe Acrobat 6.0 Professional for PC
How to convert jpg to pdf file...
Start your graphics processing software ( for example google picasa or as im demonstrating mircrosoft pait.
2. Open a JPEG picture document
3. Select from main menu "File"->"Print"
4. Select Printer "Virtual PDF Printer"
5. If you need to adjust PDF generation options, click the "Property" button on the right
6. Click "OK"
7. A dialog will pop up, assign the folder and file name of the PDF document to be generated
let me know if this helps
Feb 03, 2008 | ScanSoft PDF Converter Professional...
PDF Converter Professional error
Your converter preferences may have to be changed to allow this document to be opened.
Apr 03, 2007 | ScanSoft PDF Converter Professional...
Computers & Internet Logo
384 people viewed this question
Top ScanSoft Computers & Internet Experts
vsri9
Are you a ScanSoft Computer and Internet Expert? Answer questions, earn points and help others
