2006 Ford F-150 Logo
Posted on Feb 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reverse lights not working on 1993 Ford Ranger
I have replaced the bulbs, light switch on transmission, and check the fuse. My reverse lights still will not work.
Need help....Thank U.
  • Anonymous Mar 19, 2014
    Reverse lights not working on a manuel
Anonymous
Level 3:
President:
  • Ford Master 783 Answers
  • Posted on Feb 05, 2009
Anonymous
Ford Master
Level 3:
President:
Answers
783
Questions
0
Helped
713309
Points
4089
Not sure what transmssion you have but basically it goes from fuse on P/O wire to either the MLP switch on automatic or just a backup lamp switch on manual and leaves the switch on BK/PK wire to the bulbs. Should be easy to trace with a 12v test light.
1helpful
1993 Ford Taurus LX V6 3.8, where is the reverse light switch located ?
Standard Motor Products NS58 Neutral Backup Switch
This is what it looks like, it should be located where the shift cable attaches at the transmission
Backup lights don't work on my 1997 Ford Ranger
Have you checked the reverse switch on the transmission? Fuse in the fuse box?
1helpful
2004 Ford Escape BACKUP LIGHTS both are completely not working. We have new bulbs and the fuse is new what could be the problem for the lights not working?
My guess would be the neutral safety switch on the transmission.
The switch also acts as a backup light switch when the shifter is in reverse.
I would check for power at the switch for the reverse light circuit.
1helpful
Reverse lights not working on 1988 ford bronco 2
Look on the transmission and there is a sensor that hooks to the reverse lights and is threaded into the transmission. First check the bulbs and then check the fuse to the reverse lights and then the actual switch on the tranny.
5helpful
Reverse lights will not work and I have replaced the bulbs and the fuse
There is a switch that controls the Neutral Safety Switch, and the Back-Up lights with the automatic transmission.
Manual trans usually have a single switch mounted where the shift rail inside the trans causes a switch to turn on the Back-up lights when you shift into reverse. Just a Back-up switch @ 15.00 + Ship on eBay for this type.
good luck
4helpful
2answers
Backup lights don't work Bulbs are fine and fuse is fine
check the reverse switch as it's most likely failed. It'll be on the side of your transmission with several wires sticking out of it
2helpful
2007 ford e350 van, reverse lights wont work
On the side of your transmission will be a switch with several wires coming out of it. This is your reverse switch that turns on your reverse lights and most likely needs to be replaced
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
