Question about Zyxel P660HW-D1 Router
Nat type changes back on ps3
Hi ive done that thing with my ZyXEL router where you turn on all the upnp features and then yes it changes to nat type 2 on my ps3 happy days but then soon after for some reason it changes back to nat type 3 then the only way to get it to nat type 2 again is to reset the router and turn on the upnp features again and it works again but then soon after for no reason it changes back to nat type 3 again any ideas
  • 30 Answers
You need to make sure that when you change it that you apply in your modem setup page that bridge mode is activated so that it turns it into a dumb unit allowing just to pass through the internet stream thus allowing constant nat 2 connection
Posted on Aug 10, 2010
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
My nat type is strict and when i try to play my PS3 i have connection issues. How would i get my nat type to be open?
Zyxel routers don't support Nat 2 confirgurations for the PS3 software. You can fix some issues by powrforwarding the speciffic ports that the PSN uses. To do so follow this ismple guide:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/PlayStation_Network.htm
It may vary from game to game so you should choose what speciffic product are you trying to use here:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/P-660HW-D1index.htm
Mar 06, 2011 | Zyxel P660HW-D1 Router
Hi there! i have a zyxel ph660-f1z and since it doesnt suport dmz i get nat type moderate on my ps3 so it gives a lot of trouble.... i have tried port fordwarding,upnp,default server but nothing seems to...
Sometimes not just the dmz or port configurations cause your nat settings to be other than open, you may not have good internet connection, the better it is the more you will open. Most routers are open by default, and those others need to be forwarded(like you wrote) with the upnp open and specific ports for xbox/ps3 servers opened. You seem to know a little already, maybe time to get a new router?,I recently upgraded myself due to problems with configuration.
Dec 15, 2010 | Zyxel P660HW-D1 Router
Ive connected my xbox 360 through wired connection to my modem/router and it tells me my NAT settings are strict and to enable upnp but i dont know how to enable it?
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Jul 30, 2010 | Zyxel Prestige 660HW Wireless Router...
Change nat type
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Mar 31, 2010 | Arris WR850G Router (DHWR850G)
Hei! Can`t switch from Nat-Type 3 to Nat-type 2! Pliz help!
Wow talk about a head scratcher. Going to suggest this and i will most likely be wrong, but here goes.
This problems sounds more like it's in the settings on your ps3 then it is the router settings. You might want to check with the ps3 settings before you go any further with the router, also and i'm nor sure about this in your part of the world. Most routers now have a port setting that you can setup for your game systems. I know several that i have setup for people have had msn game zone, battlenet and a few others already setup on them iin the router you just had to put a check mark beside the one you wanted and you were good to go.
Hope this helps, but like i said, most likely dead wrong on this one.
Jan 13, 2010 | Zyxel Prestige 660HW Wireless Router...
Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
May 05, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Hay me again
to enable your upnp you need to "log into your router" the all your settings will be there for you to change such as enable upnp tutorials for this can be found on youtube
Jan 27, 2009 | Sony Playstation 3 (PS3) Console
PS3 NAT type problem using Zyxel P-660R-D1 series DSL Modem
thanks for help , the error was from user that have viruse on his pc , thanks again
Nov 11, 2008 | Zyxel P660HW-D1 Router
NAT 3 in PS3 Router Zyxel P-660HW-T1 v2
Yeah I had this problem but she's fixed. No need to upgrade the firmware me thinks.
1) Type in "192.168.1.1" into the address bar of your browser. The log in page for your browser appears.
2) Enter your password - by default this is "1234", but you might have changed it. If you have changed it before log in with that new one.
A page should load with a lots of boring information. On the left side there should be a panel of stuff, what you want is "advanced settings". If advanced settings IS there on the left go to step "a" below. If advanced settings (or in fact anything) IS NOT down the left proceed to step "b" below.
a) Happy days. All you have to do is click the "+" beside advanced settings to expand it, then select UPnP. Then just click ALL of the boxes (there's 3 of them I think). That's it.
b) You are logged into some sort of stupid mode where you can't change anything. All you can do is refresh the page or log out. This is probably because you entered "1234" as the password, but in fact this password has previously been changed by you or someone else. So go back to the log in screen (192.168.1.1 in the address bar) and put in the one you changed it to, if you can remember it. If you do remember it and log in successfully (successfully being that you can see "advanced settings" on the left), go back to step "a" above. If you still can't get to that page it means you don't know your password. So you're going to have to reset your router. Go to step "c".
c) Resetting your router. Turn the router off. Then hold the reset button for 30 seconds and power on the router at the same time. Now I think you'll have to set up your router again like when you got if first, to connect to the internet, so do it. Then log in to 192.168.1.1 again. This time the password "1234" should bring you to the proper screen with advanced settings. If it does go to step "a". If it doesn't go to step "d".
d) You'll have to default reset your router. Turn it off. Turn it on and hold reset for 15 seconds. Some light will flash. Release button and let it reboot. Now log in to 192.168.1.1 again. If it works and you can select "advanced settings" go to step"a". If you STILL can't see advanced settings you're at the end of the line and I don't know what to do. Contact your provider or something.
If you haven't done this already...on your ps3:
Open up network >> internet connection. Choose wireless/wired - whichever you want. Choose "Address settings" - "custom", "IP address" - choose manual.Enter these:
IP address - "192.168.1.50"
Subnet Mask - "255.255.255.0"
Default Router - "192.168.1.1"
Primary DNS and Secondary DNS same as default router.
Then enter than. Don't know what MTU is (it'll come up next). You're done.
Sep 21, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Logo
1,932 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
