Question about Zenith ZN110 Remote Control
Monster CAble Coding Y CB CR
How does the Y CB and CR on Monster cables relate to Left and Right audio and Video?
  • bill90803 Feb 06, 2009
    Thanks, I think this will help a lot.
  • 48 Answers
Http://en.wikipedia.org/wiki/YCbCr
I dont quite understand it all but, it works somehow.
Posted on Feb 05, 2009
Cb cables ,Cr cables and the y cables is one to hooked to video and the other two to audi
No. Those are the component video connections. Use the connection labeled "Video" (usually yellow) and the connection labeled "Audio" (usually red (for right) and white (for left).
Feb 04, 2015 | Televison & Video
What is Y.Pb/Cb.Pr/Cr can i us these as right and left speaker and a signal wire
Its for component video input. The cable has three connections, one red, one green and one blue. This is the highest quality connection for video you can get without HDMI. The audio will be run on a different cable
Sep 01, 2011 | Computers & Internet
HOW DO I CONNECT TO TV
There are many methods to do this.
If your cable are ONLY RED,WHITE,YELLOW
1 Plug the red white and yellow cables to there corrosponding jacks on your DVD player
2 Plug the red white and yellow cables to jacks labled video IN, Audio IN. They will be colored on the back of your Tv
3 Plug in the power cable.
4 Turn it on and flip through the inputs on your tv until you see the picture
IF your cables are RED, GREEN, BLUE, RED, AND WHITE
1 Your are using what is called conponent video. This is a high definition video.
2 Three of your plugs are for video. They are Red(Cr) Green(Y) and Blue(Cb)
3 Plug the GREEN into the Y jack
4 Plug the RED into the Cr jack
5 Plug the BLUE into the Cb jack
6 Plug your power cable int o the wall if you havent alredy done so
7 Plug the other red cable into the audio right jack
8 Plug the white cable into the audio left jack
9 Turn it on and surf through the input until you find it
If you have a BLACK, RED and WHITE
Do the same as RED WHITE and YELLOW but
1 Put the black cable into the s-video slot
2 Surf through the inputs until you find the picture
If you have ONE BLACK CABLE
1 This is called HDMI(High-definition multimedia interface)
2 Plug one end into the tv and the other inte you dvd
Thank you for your time, Good luck and I hope this works
Jun 08, 2011 | Televison & Video
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
I plugged in the normal 3 Video inputs and it still doesn't work.
More info is needed, please. When you say 3 video inputs, what are you referring to? I believe the Sanyo has the HDMI, RGB/YPbPr component video, S-video component, RCA composite video and Coaxial connections, though I'm not sure how many of each. So lets start with the best quality to least.
HDMI: This is one cable that provides both audio & video and produces the best picture quality. It comes in different lengths and is a wide, flat connection. A must for 1080p resolution signals.
Component video, RGB or YPbPr analog component cables: 5 separate RCA cables, 3 of which are video that separate the video signal & 2 audio cables. The 3 video cables are generally red, green and blue (RGB) or marked individually with the letters Y, Pb/Cb & Pr/Cr . The audio cables are red & white. You may see these on the back of DVD players often. They will carry a signal up to 1080i but not 1080p.
S-video component: One cable for video, it is a round connection with several pins in it and will only plug in one way. You must use 2 RCA cables for audio with this cable, red & white again.
Composite video: 3 separate cables; Red, White & Yellow. Red & White are audio, left and right while yellow is video.
And finally there is coaxial which it the cable that is identical to the cable from the pole/ cable box or your dish. It is the poorest quality.
What can happen is you are using 3 standard RCA cables and have them plugged into the component input & they will not carry the signal, or one end in component input and the other end in the composite output or vice versa. Another is that you have the wrong input selected on the menu. Check all your cables and connections, plus the input you have selected on the TV itself.
Dec 09, 2010 | Sanyo 42 in. LCD TV
Cant get the wiring figured out.........
TV is HD correct? Use the Y/CB/CR from the Sat to the TV. Use the Digital optical cable for sound from the sat to the receiver. Use the s-video from the dvd player to the tv and the l/r to the receiver for sound. I would suggest upgrading to another set of Y/CB/CR cables to connect your dvd to the TV and benefit from better picture. Also, buy another optical cable for dvd sound (so you can enjoy surround sound). Your receiver has two optical inputs so youre covered there.
Sep 03, 2008 | Kenwood VR-407 Receiver
Monster Component Cable labled Y/Cb/CR to TV that has Input Y/Pb/Pr
Y PB PR is the analog version of the Y CB CR color space; the two are numerically equivalent, but Y PB PR is designed for use in analog systems whereas Y CB CR is intended for digital video.
Aug 31, 2008 | Televison & Video
Need help setting up dvd player
if you have three cable----y---cb------cr.confirm that you connect it in similar places in receiver video in(video 1---or---video 2)-then select the right input source----check that your cable is good and working.
Jan 05, 2008 | Denon AVR-1803 Receiver
Zenith ZN110 Remote Control Logo
511 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
