Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
Dampness atound casing on frezzer
Hi
My frezzer works fine but the out side of the frezzer which is incased in foam and then teak becomes damp on the outside of the teak which is ruining all my swaps.which **** up on one side to the teak which the frezzer is incased in .
this is a tricky one .
Cheers Kevin
email platterz@ihug.co.nz
    Sniper:
  • 50 Answers
Inside the refrigerator is a small switch which has energy saver and another side that differs with brands put the switch on the other dide (not energy saver) and this will energise a mullion heater which runs around the frame under the plastic mouldings. what causes the dampness? the difference in temperature between the fefrigerator and room temperature
Posted on Feb 06, 2009
Will not start when its damp out. when not damp starts right away thank u mike
Astro won't start or very hard to start when damp or rain ...
www.topix.com > Chevrolet Astro
Aug 24, 2007 - Posted in the Chevrolet Astro Forum. Leave a ... 2000 astro, Hardstarting or wont start when wet, once started its fine. I replaced the cap, rotor, gas filter, next rain was hard to start but did after about 10 tries. ... I have a 2000 astrocargo van. 4.3 v6. ... look for a faulty coil. mine passed out in a rainy day.
Van won't start in wet weather - Chevrolet Forum - Chevy ...
chevroletforum.com > ... > Past Chevy Truck, SUV & Vans > Astro
Sep 22, 2007 - I have a 1999 Astro Van and nearly everytime it rains or sometimes when I wash it, it will not start. ... I really like my ASTRO for everything from carrying family, boat, trailer, etc. but if it is not resolved its going before someone gets hurt. ...When it was damp out, the coil case would become wet, and the ...
Jan 18, 2016 | 1987 Chevrolet Astro Cargo
Bose 321 gs II
Probably you need a replacement remote
Mar 23, 2008 | Bose (321GS) System
How can I prevent paper jam 0207 on canon 2230
Although paper jams occur because of dirty pickup rollers I have found that jams occur frequently because of solenoids in the paper feed mechanism (the assembly that the paper trays fit into). There are two of them and over time the damping foam on the levers get sticky causing the lever to operate late which causes the jam. As a fix I remove the damping foam and put insulation tape on the lever making sure the solenoid works by using a 12v bench psu before reassembling. You will need service manual because Paper Feed mechanism removal is a little complex.
Paper feed problems in Canon Laser Jet Printers are caused by these solenoids mainly in Duplex mode. P3005dn's etc.
Hope this helps solve yr problem.
Jul 29, 2014 | Canon Office Equipment & Supplies
I have got damp in the boot of my car from washing the car can you suggest anything?
i had this problem with a vectra turned out just inside the boot door channel there is water drainage holes and sometimes they fill up with moss and leafs ect. unblock the drainage holes also have u checked under the carpet mine did the same and in the sparewheel compartment underneath was a puddle of dirty rain water in the end i drilled a 5 mil hole just to drain it and incase the drainage holes wernt the prob worked for me took months to get the damp smell out tho yuk if not the problem only other to things i could think it could be is the rubber seals failing that on some cars petrol cap can cause it hope this helps goodluck
Mar 24, 2012 | Volkswagen Polo Cars & Trucks
We have a 1990 lebaron 56000 miles when it gets cold outside,like35 degrees sometimes the headlights will not go on until after the car is fully warmed up. the hi beams will always work but the headlights...
the old chryslers were very suseptable to dampness esp at 35 deg after car warms up the damp wires would dry off and the problem would go away some time this also affected the ignition and car would not start on damp or rainy days as well
Dec 15, 2009 | 1990 Chrysler LeBaron
Screen is white when i turn camera on
hi there this is a good question but theres a good chance its fixable i have repaired two camaras with white screens this is when the ribbon cable in the cam has become damaged or not conected properly if the screen is in one peice there a good chance the screen isnt damaged , the only other problem is it could have liquid ingres this is where damp gets inside the camera from taking if out side in the cold from a warm room and vise versa and the components in the camera have become damaged by dampness which will prob lead you in bying a new cam
hope this helps Thanks For Using FixYa
Feb 07, 2009 | Kodak EasyShare C533 Digital Camera
Starting in damp weather 1993 240 wagon, auto/od, 235k miles
perhaps you need a new cap and roter a new spark plug wire set. they don;t like moisture. also check to see if you have any broken or leaking vacuum hoses. the worse case senerio would be that your head gasket is leaking--at cold temps a little antifreeze will enter until everything warms up and it seals shut due to metal expanding. but since you say it's cold weather only--this probably wou;dn't be the case. good luck.
Dec 27, 2008 | 1993 Volvo 240
Cleaning Laptop
You can buy specialist screen cleaning wipes (but I don't know if you can get them in Kuwait), otherwise a damp cloth should do the trick just fine.
Avoid using everyday cleaning chemicals or anything abrasive.
Matt
Feb 29, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
GRDVX707EK
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
May 29, 2007 | JVC GR-DVX707 Mini DV Digital Camcorder
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
