Question about Dell PowerEdge 2450 Server
Flashing orange light & diagnostic cd will not load
Orange light flashing on poweredge 2450, have tried running diagnostic cd but it will not run just crashes i am also running windows server 2003. I have updated bios and firmware and thats made no difference but everytime i start the server i get a single beep also says no system drives installed before it loads to windows.
Any help would be great as i have tried everything i can think off.
  • Rooiehaha Feb 08, 2009
    I have managed the install, its telling me there is a problem with the backplane +3.3v its running at a critical state.
    I have tried looking around on google but can not find much information out on it or what i need to repair it.
    Everything thing else on the server runs perfect.
    All help is appreciated.
    Thanks
  • Rooiehaha Feb 09, 2009
    What Server are you running and os ? Have you got system administrator tool installed ?
  • 73 Answers
Posted on Feb 07, 2009
  • 1 more comment
  • Matt Barr Feb 08, 2009
    Can you give a little more detail about where I could find that on one of my servers? I tried to find the same thing and could not.
  • Matt Barr Feb 09, 2009
    I have server 2003. and yes i have the tool installed. I cannot find the backplane voltage in mine.
    Server 2003. I have the admin program installed. i cannot find the backplane voltage.
Luz naranja parpadeante?
That depends on what is flashing orange. Please be more specific, and please post in English. In general, flashing orange lights on Dell servers mean something is wrong. Installing and running Dell OpenManage System Manager will usually tell you exactly what is wrong.
Jul 28, 2014 | Dell PowerEdge T110 II
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Orange light flashing below the dell logo
This means something is not right. If you are running a Windows OS, you should have the Dell Server Manager installed. Go into this application and check what it says. The problem may be very minor, such as the cover not being completely closed, to something as severe as a failing hard disk.
Jun 29, 2010 | Dell PowerEdge 1800 Server
Dell poweredge 830 server orange flashing light instead of solid blue. No fault on screen. any ideas?
its the cover switch. there is a small push switch on the front panel that detects if the front cover has been removed, either the switch is defective, or the cover is not seating properly to close the switch.
Jun 09, 2010 | Dell PowerEdge 830 Server
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Canon i950 flashing orange green orange green
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Aug 22, 2008 | Canon i950 InkJet Photo Printer
Orange light
This sounds like your "check engine" light. Best bet is to take it to your mechanic where they should have the right diagnostic tools to find where the problem is. - Neil
Jun 10, 2008 | 2004 Ford Focus
Power edge system are having two power input check the cables from the power outlet may be one is in contact otherwise one of your power supply gone means not working. Check the wires first then the power supply units
Nov 26, 2007 | Dell PowerEdge 1800 Server
Dell PowerEdge 2450 Server Logo
570 people viewed this question
Alun Cox
