Question about Hitachi 53SWX12B 53" Rear Projection Television
Close caption never leaves the screen
When I turn on the tv I can't get the close caption off the screen. How do I turn it off?
  • 360 Answers
This link is a download of the user manual for your tv. it is a pdf file. you can view/save it on your computer of print it for future reference.
http://www.hitachionlinestore.com/manuals/61SWX10B.pdf
Closed captioning is explained on page 55 of the manual.
I hope this answers all your question. Thank you for using Fix Ya
Please take the time to rate this Fix Ya solution.
Thanks,
clarkco
Posted on Feb 05, 2009
    President:
  • Hitachi Master
  • 1,779 Answers
Go into your MENU most likely under Audio and look for Closed Caption, it should say on the screen which controls on the remote to navigate with. It might also be under Features you will then be able to turn it off.
3 Suggested Answers
SOURCE: Closed Caption will not turn off
Did you check your cable box or satellte box set-up? I thought I had the same problem on my Hitachi 46F500 but it ended up being my Comcast box was set-up to display closed captioning on the component video output ONLY. Hope this helps...
Posted on Oct 31, 2007
  • 286 Answers
SOURCE: CANNOT TURN OFF CLOSED CAPTION ON 52" JVC TV
Does it use a cable box or are you using the tuner in the TV?
If you're using the tuner in the TV, try unplugging it for 5 minutes and then plug it back in, do a new channel scan and see if the CC goes away. If not, contact JVC to find out how to reset it. If it still does not work, you might need to have your main board replaced.
If you're using an external tuner plugged into a video input port (such as a cable box or satellite box) then the external box is at fault since TVs don't have CC available through their composite or component or svideo or hdmi ports.
Posted on Jun 19, 2009
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
How to turn off the close caption on tv
Hello
Not all TV programs and product
commercials are made with
Closed Caption (CC) information
included. Neither are all Closed
Caption modes (CC1, or CC2) necessarily
being used during the transmission
of a closed caption program.
Refer to your area's TV program listings
for the stations and times of
Closed Caption shows.
To close the close caption display from screen; press "CC" button on the remote control.
Jul 08, 2011 | Philips Magnavox 20MT133S 20" TV
Cant turn off closed caption
sherrillbrom
With our VIP receiver models, you have an option to turn on/off closed caption through the receiver. Press the Menu button on the remote, which will display the Main Menu on the TV screen. Press 8 (Preferences) and then press 6 (Closed Caption). On the Closed Caption screen, press 1. On the Closed Caption On/Off screen, select CC Off and then press Done from the TV screen (using your DISH remote). This will turn the feature off on the receiver. Test to see if it is turned off by watching a program that has CC. If it still appears, then the feature is activated through your TV. Please refer to your TV manual to turn the feature off. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
JVC tv caption box will not leave screen
Go into the setup menu and choose OFF for closed-captioning
Mar 21, 2010 | JVC HD-56G787 Television
I HAVE A JVC TV AND I WAS SETTING THE COLOR AND THERE I GOT A BLACK SQUARE IN THE CENTER OF MY TV I CHANGE TO STATION IT GOES AWAS THEN IT RETURNS
Check your Close captions and text1 options in the close caption menu screen, turn all off..
Please leave comment thanks....
Oct 12, 2009 | JVC AV-27D302 27" TV
Black square on screen of 19 inch TV
Check your closed-caption settings and be sure they are turned off. If captioning is set for text mode you can have this trouble. The TV blanks out a part of the screen for the text it never gets to display. Once captioning is shut off (or set for normal caption mode if you want to use it) the black box will be gone.
Feb 04, 2009 | Konka K1938U 19" TV
Closed caption
Are you talking computer or TV?
Closed caption on a TV is when the volume is muted and it prints the speech in a box on the screen. You have to turn it on in the menu.
Nov 27, 2008 | Computers & Internet
Tv PROBLEM
The black box your are seeing on the screen is the box to display text. It is listed under your "cc" closed captioning setting as T1, T2 etc. Go into your closed captioning and shut off the text. You can still leave closed captioning on or off. The text system was never really used but they put it on all of the TV's.
Feb 05, 2008 | JVC AV-27D303 27" TV
Adjusting
You have the closed caption turned on the set. Since you did not leave a model number, I cannot tell you the procedure on how to turn it off. Sometimes there is a button on the remote marked CC or closed caption, and sometimes it is switched on and off through the on screen menu. Good Luck
Jan 04, 2008 | Televison & Video
Closed Caption won't turn off
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
Dec 08, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Hitachi 53SWX12B 53" Rear Projection Television Logo
111 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
