Question about Panasonic KX-TG1033S Cordless Phone
2 Problems: #1Volume fades out. #2No caller ID on Call Waiting
#1. Volume of voice at other end fades for a second or two and then returns.
#2. Caller ID does not work when a call is received on Call Waiting. Caller ID is displayed on the first call; only a beep sounds to notify a call waiting for a second call, howver no Caller ID number is displayed.
  • Anonymous Mar 26, 2014
    Caller display works but not calls list
  • 514 Answers
1. move closer to base
2. you must have call waiting ID for that to work at all and most of these phones don't use it during active calls.
go to page 21 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
Posted on Feb 22, 2009
How do i turn the voice off n my panasonic 6.0 phone
How do I turn off the Talking Caller ID on my phone? To turn off Talking Caller ID on the base;
  1. Press [MENU] [#] [*] [1] [6] [2]
  2. Press the [?] or the [?] button to turn the base Caller ID on or off.
  3. Press [ SAVE ]
To turn off Talking Caller ID on one of the handsets;
  1. Press [MENU] [#] [1] [6] [2].
  2. Press the [?] or the [?] button to turn the handset Caller ID on or off.
  3. Press [ SAVE ]
Note that the base and each handset are programmed individually.
Jan 16, 2018 | Panasonic Lands Phones
How do i. Turn the voice off on my panasonic 6.0 phone
  3. Press [ SAVE ]
  3. Press [ SAVE ]
How can i turn the voice off on my panasonic 6.0 plus phone
Press [ SAVE ]
Press [ SAVE ]
How to set date and time
Voice Time/Day Stamp
1. Make sure the answering system is ON.
2. Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confirm the setting.
8. Press Caller ID-Volume to set Day
9. Press #Pause to Confirm
10. Phone will then Announce the Day & Time
Feb 02, 2009 | GE 25932 Cordless Phone
Visual message waiting indicator
Press the mute/program button, then press the caller ID-volume button to select handset setup. Next press caller ID-volume until you get to Default settings. Use the caller ID-volume button to select 1yes. This will return the phone to the factory settings and for took care of the blinking blue light, however you will loose any custom setting or numbers you entered.
Sep 16, 2008 | GE 28112EE2 Cordless Phone
Caller id
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
Feb 01, 2008 | Uniden TRU9480 Cordless Telephone
Caller id setting
even I am waiting for this answer
Dec 28, 2007 | NorStar T7316E Corded Phone
Coller ID Inoperative
Here is the tip directly from the manufacture vtech. Tip 1 of 1 Caller ID and Call Waiting ID are subscription services, available from most local telephone service providers. You must subscribe to these services in order for the features to work on your phone. Contact your local telephone service provider for more information. In addition, your caller must be calling from an area that supports caller ID. Both you and your caller?s telephone service provider must use compatible caller ID systems. Caller ID and Call Waiting ID may not be available for every call. Common reasons are incompatibilities between your and your caller?s service, transmission errors and answering calls before the ID data is received. They state that if you have further problems, to contact customer support at 1-800-595-9511. Also, who is your phone service provider? And who is the manufacture of the old phone? If this does not help, please post further. Also, please rate this solution through fix-it. Thank you.
Jun 30, 2007 | Vtech ia5854 Cordless Phone
Validation
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
Caller id
This is a feature from your phone company you may have to pay extra for. Caller ID information is normally transmitted just after the first ring. When you are using call waiting there is no ring.
Jun 19, 2007 | Uniden DCX640 Cordless Expansion Handset
Panasonic KX-TG1033S Cordless Phone Logo
375 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
