Machine will not start, has anoise when I lift the lid and has DE
Machine will not go to any cycle and has a funny noise comming from it. DE on display. Have cleaned filter and checked drain pipe.
  • JOYCE BROOKS May 11, 2010
    This is joyce
    I need to know what model # your machine is and some more information about what the machine is doing or not doing please.
    thanks
    joyce
  • onthethejob1
    onthethejob1 May 11, 2010
    what unit is this,,post model please...
  • 15,935 Answers
DE = Door Error.
Latch, sensor or similar has failed.
See this link:
LG - http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
In the spin cycle it makes a loud banging noise and vibrates uncontrollably. when u raise the lid it stops spinning right away. is it worth it to fix this or replace it?
You may have to lift the lid and rebalance the wet clothes inside
make sure that the machine is level and the bowl supports or in good condition as an off level bowl will go to unbalance on start of spin
Apr 13, 2015 | Washing Machines
I have a fuzzy logic 8.2kg top loader WF-8071TTP. We had a power failure while the machine was in a washing cycle. Now I start the machine fills with water and when the wash cycle must start it give a DE...
'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 13, 2011 | LG Washing Machines
I have a GE WJRE5550K2WW top load washer that we recently bought. This last weekend my daughter ran an experiment for a science class where she ran the wash cycle several times without letting the rest of...
yo creo que no puede ser el control puesto que no guarda memoria de los siclos me parece mas bien que pudo ser que se desmonto o se desgasto alguna piesa interna del mecanismo de la lavadora por el uso execivo al que fue expuesta para el experimento
Oct 05, 2010 | GE Washing Machines
Washer stops during rinse cycle
if unit is stoppin in rinse cycle and not advancing into drain/spin mode. you lift the lid and its stalled full of water??? clos the lid again and listen for a slight "clicking" noise, chances are you lid switch has gone bad, and the machine does not recognize the door being closed, and for safety reasons will not drain/ and or spin..very common issue!
Jan 27, 2010 | Kenmore Washing Machines
Washer will spin but won't drain automatically
are you sure it spins? usually something is in the pump like a sock. You could remove the front and take the hose off the pump to see if its clear. It also sounds like it could be the lid switch. if you have to close it make sure you hear a clicking noise from the lid switch.
May 14, 2009 | Maytag Washing Machines
F1 comes on 2to3 times a wash
CHECK THESE:
lid flashes when the following conditions occur:
➔ User presses START with lid open.
➔ User presses START after 2 consecutive machine cycles
without opening lid.
➔ The machine/motor control cannot detect the lid switch
opening and closing properly.
BOYNISMO@YAHOO.COM
Jan 18, 2009 | Kenmore Oasis HE 27087
Washes but dosen't drain
you having an issue withthe lid switch not activating, either a bad lid switch, or the "arm that hits it simply not making connection and needs adjusting.. chances are you cant hear a "clicking" noise when the lid is lifted and lowered... if this is the case its a lid switch issue... for safety reasons, the machine is not recognising the door closed so wont enter a spin cycle. will hawever wash and fill
Jan 03, 2009 | Estate TAWS800JQ Top Load Washer
Roper 7 cycle
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch part number3949247
Mar 04, 2008 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
