Question about Canon iPF700 InkJet Printer
Hardware Error message
Printer says there uis a harware error- turn off- then on- this does nothing?
  • 1 more comment
  • sgt c Feb 10, 2009
    what is the hardware error 03130031-2f1f
  • dumi_id Mar 13, 2009
    I have the same problem with my Canon ipf 700
    Error code is : 003130031-2F13 and 2F26
  • sandy_menane Mar 31, 2009
    doesn't print error message 03130031-2F13
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
Loose the 3 screws that hold the purge unit (beware of the ink) then remove the black plastic cover that is under the purge unit.
Check the white gear that transmit move to the wiper system and moves up and down the absorvers,some times the gear is loosing his position and you have to put it back also there is a spring that helps the gear to remain steady.
Check the normall move of the purge unit by moving the big white gear on the right of the purge unit.
Posted on Mar 17, 2009
I get a message that the ink system has failed and error message 0xc18a0001. I have turned it on and off again, also tried the suggestion on the HP web site - didn't work.
Please remove off your printer and uninstall the printer. Later reinstall the printer software and then connect the printer. Your harware- printer- will now be detected and installed into the PC. Now check and make a test print, the printer must work right now . If it is still showing an error of the Ink , use the maintenance key for ink chane before you remove the cartridge. Change and check . Good day
Aug 16, 2010 | HP Photosmart C7180 All-In-One InkJet...
We have a Rizo 220 ui with an error message
The rear cover may be off. Or you may have a bad cover switch.There are two switches at the top of the back coverone on the left and one on the right. Hope this helps.
Jul 14, 2010 | Riso RZ220 Duplicator
Error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
My cx3200's control panel reads scanner error. I unlocked the transportation lock, turned off, turned on. It stayed off for about 2 minutes then came right back on. While the error light was off tried to...
The only things that can cause a scanner error on this unit is a complete scanner harware failure or the scanner lock. With the unit on lock the transport lock and unlock it a few times quite forcibly. Then leave it in the unlocked position and power off and on again. If the light returns then at his point I think a new printer will be needed.
Jan 18, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Hp 2355 internal error
try to boot in safe mode windows,, and then uninstall the hp drivers,, and again install.
Sep 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
Kodak AIO 5100 won't work
Hi Kat. Can feel your frustration. Sorry.   The OS (Windows etc.) opens the UI file but I could not find out who provides it. It is a DEVELOPER file.  It is a little over my head but I f you have the VISTA install disk. Save all of your important files, then have Windows reinstall itself. It wil tell you that "their is already a version of Windows installed , do you want to fix it" Say yes. Aftwer that I would again download the files and software I pointed you too and reinstall it. If it still doesn't work . I woudl take the printer back where I had purchsed it from and demand my money back as irt is not a compatable product as you were led it to be.
UI file is a document that implements a single, specific ruleset API for a single, specific client type. For example, one UI file might allow text-based clients (such as Friv to play rock, paper, scissors, while another lets SVG clients (like Gamut) play chess.Clients locate and download UI files through the UI finder.
UI file logic is generally written in ECMAScript according to the ECMAScript API.
Feb 18, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer error 502
Shut down the printer, check whether the printer has peripheral devices such as a stabilizing power supply, and disconnect them.After five minutes, restart the printer to see whether the fault corrects itself. If the fault persists, the heating component may be faulty and the printer will need to be repaired.
Thanks for using FixYa.
Jan 26, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Canon iPF700 InkJet Printer Logo
871 people viewed this question
old marine
old marine
