Question about Konica Minolta DiALTA Di200 Copier
Minolta DI200 Error Code 00070
I turned the machine on and it immediately goes to the error screen which gives the code 00070. Does anyone know what this code means and what it would take to fix it?
Thanks
  • 145 Answers
Try and take the toner bottle out and turn machine on and than put the bottle back.it;s bottle sensor problem.good lock
Posted on Feb 28, 2009
  • Konica Minolta Expert
  • 1,326 Answers
Have you just added toner to your copier. That code means that the toner bottle is not finding Home Position.... Try this, remove the toner bottle carefully, with the opening hole facing upward. Next turn the copier Off and close the front door and wait for the copier to warm up. Once it has warmed up, make a few copies.... Has the code gone away???? If so, reinstall the toner bottle back in and that should do it for you. If not you may have a bigger problem... Good Luck...
Posted on Feb 06, 2009
C-of24
no such code for this machine
Jan 14, 2014 | Konica Minolta DiALTA Di200 Copier
I have a problem whith minolta dualta di200,the problem is "error code c0500,can somebody help me?
C0500
The temperature of the Fusing Rollers does not reach
the required level even after the lapse of a given
period of time during a warm-up cycle.
There should be a small opening or hole on the right of the operation panel, use a paper clip to press the button inside. This will reset the machine. If the error code was a glitch or a false code the machine should operate. If the code comes back you will need to have a technician replace the fuser assembly
May 14, 2010 | Konica Minolta DiALTA Di200 Copier
ERROR OF C-F024
Sir,
have you replaced the image unit recently.Mite need a new Image Unit. Try turning off then on the machine, to clear the code first.
Apr 01, 2010 | Konica Minolta DiALTA Di200 Copier
I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
Jan 24, 2010 | Konica Minolta DiALTA Di200 Copier
Minolta EP2100 Copier - Error Code C5
Mite try amozon/craigs list for parts, The machine is legacy system
Jun 15, 2009 | Konica Minolta DiALTA Di200 Copier
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Error code F-46-11 in my photocopier konica minolta 7035
A 46-11 code indicates a communication failure between the A/D converter board and the main control board. Likely a bad or poorly seated ribbon cable. Try to reset the machine by turning off the main power switch on the side of the machine for 10 seconds and re-powering up. If the problem persists you will need to call a technician.
Feb 04, 2009 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Di251 error code
most popular solution is you resigin your job hahahah
Jul 11, 2008 | Konica Minolta DiALTA Di200 Copier
Copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Feb 09, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
258 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
