Question about Hotpoint Ultima WF860 Front Load Washer
Mouldy door seal on hotpoint ultima 14 months old
I discovered that my washing machine started to form mould on the door seal.over the past few months it has spread ,all around the door seal.I have looked for a drainage hole but there is not one. Is this the problem should it have a hole at the bottom of the door seal. as i have never had this with any other washing machine before.hope you can help because the mould has started to come off on to the washing many thanks
    Scholar:
  • 105 Answers
Like Maytags Neptune they had to change seal and door design to avoid mold and rust from water holding at seal, and check with your local dealer you should be under warranty still. And jack is correct, tooth brush with toothpaste or baking soda , Good Luck
Posted on Feb 05, 2009
  • 77 Answers
Hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
Mould on door seal
they sell tablets to put in the washer to treat this. also you gan wipe it down with a bleach and water mix. bleach kills the mold
Nov 14, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a front loader washing machine. The rubber inside is going mouldy. I have tried to clean same without success - any suggestions!
Unfortunately, once the door seal goes mouldy it is impossible to get clean. Only option is to replace seal. Once seal is replaced, you need to wipe it dry after each wash and leave door ajar to prevent reoccurence of mould.
Mar 09, 2010 | Maytag Washing Machines
The rubber section of my Hotpoint WF640P has gone mouldy
The problem is basically caused by doing too many low temp washes.
The scum you refer to is actually bacteria that is bulding up on the door seal.
To avoid this problem reoccuring, the best thing to do is to have the door seal replaced, and periodically do a high temp wash with powder in, but without clothes..
This is called a maintenance wash, and is recommended by most manufactures
Also, after each wash, clean and dry the door seal, this will help prolong it's life.
Hope this helps answer your question.
Please rate my solution.
thanks.
Dec 23, 2009 | Washing Machines
Changing door seal on hotpoint ultima washing machine
hello if you take the top off the washer and look down inside you should see a metal ring with long screw and nut unscrew this so it's loose you should be able to pull the seal off .then on the front of the washer where the next part of the seal is theres another rmetal thin bit of wire . unscrew the platic clip and the wire should come off. then just pull the seal out of the washer and when you put the new seal on fit it the same way you took it off good luck ps get back to me if you get stuck
shaun
Sep 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
Looking for a door seal for a Hotpoint Ultima 1200.
If you have not yet got door seal, then go to www.hotpoint.co.uk.
Thanks.
Jul 09, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint Washing Machine smells mouldy as has mould
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jul 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
SMELLY WASHING MACHINE
A mouldy smell is often a sign of trapped residual water stagnating somewhere in the machine often just inside the door seal at the low point or in the filter.
Providing there is nothing like a old sock trapped in the pump or filter then there is not much you can do other than to dry the door seal and powder dispenser after use.
Please remember to rate this solution.
Oct 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Changing the door gasket on Hotpoint Ultima WD860
Managed to work it out myself how to take the old door gasket off and attach the new one. Thanks. Machine working okay with no leaks or mould anywhere now.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Mouldy rubber seal
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Regarding the mould; keep your door open after yur washing is done, (means dont shut it tight) it will help to dry the insides & prevent moulding. Only see your cat is not inside before starting a new wash.
And pl rate me if helped.................
Jan 24, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Replacing door seal
Try washing the seal with jiff and a scouring pad in warm water.Depends on how well it is ground in.
You may have to replace with new seal.
slimjim1
Nov 25, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
809 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
