Question about Kyocera Mita KMR-1810P Laser Printer
Can not clear Error Code AP
After copying the error code AP flashed and I have not been able to clear it. I have opened every door to be sure there is not a paper jam. Can you help?
    Genius:
  • 2,120 Answers
You are out of toner...It means ADD POWDER
Posted on Feb 06, 2009
What is a C710 error code
Posted on Jun 22, 2010
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
Code 3514 keeps coming one
Error: "Rear access door open" (3514)
How do I resolve the error message "Rear access door open" (error code 3514)
To clear the "Rear access door open" error message:
  1. Remove the rear access door from the printer.
  2. Reinstall the rear access door on the printer and verify that both latches are securely engaged.
  3. Unplug the AC adapter from the printer.
  4. Plug the AC adapter back into the printer.
  5. Wait for the printer to initialize.
  6. Verify that the error has cleared.
Mar 18, 2011 | Kodak Office Equipment & Supplies
The orange "Alarm" light keeps
AP position error will trigger a 6A00 error code. An error occurred in the AP motor during purging operation. According to the service manual you will need to replace the sheet feed unit, logic board assy, purge unit.
Feb 22, 2011 | Canon PIXMA MP530 All-In-One InkJet...
It has stopped working and is displaying a flashing AP but it's full of paper. Sometimes it also flashes error code 400 any ideas?
Chek toner for Flashing AP
Error C400 polygon motor synchronization problem
1. poor contact in polygon motor connector terminals
2. defective polygon motor
3. defective power supply board or main pcb
Apr 18, 2010 | Kyocera KM-1510 Copier
Suddenly got an alrm flashing light, nothing works, no copy, no print, no fax. Error code 6A00
6A00 is AP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
System error E000 how do I fix it. I tried what it said in the instructions to turn it off for a while then turn it back on that didn't help. Canon NP6025 copy machine.
To delay the 3 second shut down and enable the technician to access service mode; open the front door and pull out the transport unit. Do not actuate front door microswitch. Press the service mode button, enter " * 4 * ", scroll to error clear and clear error code. Machine will automatically turn off power after clear. Power up machine and test.
If the power shuts down after error code has been cleared, the cause of the error has not been corrected. Correct cause of error code and clear error in service mode.
May 07, 2009 | Canon Office Equipment & Supplies
Copy Star 1505 error code
Toner empty.If You have new toner in Machine,and have AP error, call service because machine needs to be cleaned inside imaging Unit.
Nov 14, 2007 | Office Equipment & Supplies
"to test stapler, press staple button" ... Minolta di550 with FN-105 ... HELP !!!
First make sure that you do not have the collate and staple option checked on the printer menuing system or in the print setup on one of the local machines printing to it. Ensure that when auto-staple is not used that the error stops manifesting.
Then, I would check to make sure that you are installing the correct staples, length and width for the model.
Jan 23, 2007 | Minolta Di550 B&W Laser Printer
Kyocera Mita KMR-1810P Laser Printer Logo
588 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
NewYork kyocera HP...
Henry Gertcher
Soulvisitor
Soulvisitor
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
