Question about NetGear WGR614 Wireless Router
MY LAPTOP DOSNT RECONISE MY ROUTER NEED TO CHANGE IP ADDRESS won't connect to laptop or wii
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 53 Answers
First things first we need to establish that the router actually connected to the internet... connect the laptop to the router via ethernet cord. if you can get online thats good if not you need to power cycle your model and the router (unplug it wait a 1-2 minutes plug it back in) let me know what happens ...
Posted on Feb 05, 2009
How do i connect my WG302 to my laptop using a console cable?
if Windows
go to dosprompt on p.c or start run cmd <press the enter key>
type in ipconfig <press the enter key>
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ?
note the ip address of the laptop and the subnet mask
If the ip address is not 192.168.0.210 then go into the network settings and set the laptop up with 192.168.0.210 and then make it a static ip address.
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ? (if not restart the laptop ) and check again
Next question how did you connect the wg302 directly to the laptop was it directly connected or was it through a network switch or network hub. Most likely the Cable router or DSL router has a DCHP server assigning different ip address lease range. You can either change the ip address of the access point device to one in the original current router lease range and assign it as static for the wireless access point device in the dchp lease table or assign the wireless access point with the second ip address as an example 10.0.0.2 and make sure the router dchp server allocates above 10.0.0.20 then temporarily connect router to laptop and temporily set laptop with 192.168.0.210 and then log into access point and change ip address to 10.0.0.2 for wireless access point device and turn off its dchp server. Then change laptop to use dhcp while connected into network hub or network switch with original router and restart laptop wired back into original normal network.
Dec 04, 2014 | NetGear WG302 802.11g ProSafe Wireless...
Tip
Nintendo Wii Error Code 52030 The most likely cause of error 52030 is that the...
Nintendo Wii Error Code 52030<br /><br />The most likely cause of error <b>52030</b> is that the router securityinformation was entered incorrectly on your Wii or that your router is unableto assign an IP address to the Wii.<br /><br />If this problem <b>just started</b>, and your Wii was working before, then tryto <b>power cycle</b> your equipment. Turn off the modem, router and Wii. After10 seconds turn on the Modem, after 30 seconds turn on your router, and after30 seconds turn on the Wii.<br /><br />If this does not work then continue below,<br /><br /><b>Make sure</b> your wireless <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>network<span>security</span></span></span></a> password and security typeis entered into your Nintendo Wii correctly. You can go into your routersconfiguration page to view the security key and view security type. If needed,you can change these. On most routers, you can access the configuration page byopening your Internet Browser and going to the router ip address(gatewayaddress) 192.168.1.1 This address may vary from router to router. Once you goto this address you should get a login page. Login and then go to your Wirelesssettings page to view the settings you need for your Wii. Once you verify thesecurity key and type, input these settings into your Wii and test theconnection. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> for my <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>tech</span></span></a> article on how to configureinternet settings on the Nintendo Wii.<br /><br />Tip - To view your gateway address in Windows do the following,<br />Go to Start &gt; Run and in the run box type "command" or"cmd". A black DOS window should open. In this window type"ipconfig /all" you should <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>now</span></span></a> see a gateway address.<br /><br />-<b>Most home networks </b>will use DCHP. What is DCHP? This is Dynamic HostConfiguration Protocol. In short, it means your router or <a href="/../support/r9300725-nintendo_error_code_52030"><span><span>server</span></span></a> will assign IP and DNSaddresses out automatically, with no intervention needed from you. If you aremanually using settings(not using DCHP) you will need to assign an IP/DNSaddress to your Wii.<br /><br /><b>To get </b>to the Wii settings to input an IP address and DNS address, dothe following,<br /><br />Access the Wii System settings and select "Internet" from Page 2.<br />Select "Connection Settings" and choose the connection file youcurrently use (will have a red border around it).<br />Select "Change Settings," and click the right blue arrow twice toreach "Auto-Obtain IP Address."<br />Click on "No" and select "Advanced Settings."<br /><br />Enter in your IP address, DNS address and subnet mask information.<br /><br />A Wii connection test should confirm the internet is now working. Again, mosthome networks use DCHP so you may not need to set an IP address.<br /><br />-<b>Interference</b> can also cause this issue. Try and make sure there are nowireless devices around the Wii and router and the Wii is in an open areawithout devices blocking it.<br />-<b>Change your router's channel</b> setting to 1 or 11. By default, mostrouters broadcast on channel 6, which overlaps with other channels and may beweaker.<br /><br />If you are still having trouble, you may want to reach out to NintendoTechnical Support at 1-800-255-3700<br /><br />-G33k<br /><br />Check out some of my other tech articles!<br /><a href="/../support/r9300521-nintendo_wii_error_code_51031">Nintendo Wii Error Code 51031</a><br /><a href="/../support/r9300387-tuneup_utilities_prefetch_data_deleted">Tuneup utilities prefetch data deleted</a><br /><a href="/../support/r9275311-computer_freezes_computer_stuck">Computer freezes, computer stuck</a><br /><a href="/../support/r9256225-disable_enable_microsoft_windows_startup">How to disable/enable Microsoft Windows startup programs</a><br /><a href="/../support/r9223119-garmin_gps_stuck_not_updating_no">Garmin GPS - stuck , not updating, no signal problems</a><br /><br />Keywords<br /><b>Nintendo Wii Error Code 52030, Wii error code 52030, Wii 52030, Nintendo Wiiinternet issues, Wii internet, Nintendo Wii internet</b>
on Jun 02, 2011 | Nintendo Wii Console
Laptop says i am connected to internet but it won't let me online
Limited connectivity
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Nov 06, 2011 | IBM ThinkPad T40 2373 Notebook
Error code 52230 - when trying to connect to Netflix. Unable to connect to the server for the last 2 days.
Unable to connect to your wireless network
Likely cause: Your router or Internet Service Provider is having difficulty assigning a DNS or IP address to the Wii.
How to fix: Manually assign an IP address and DNS to the Wii.
  1. Manually assign an IP address to your Wii console.
      Assigning an IP address to your Wii is easy!
    1. Access the Wii System settings and select "Internet" from Page 2.
    2. Select "Connection Settings" and choose the connection file you currently use (will have a red border around it).
    3. Select "Change Settings," and click the right blue arrow twice to reach "Auto-Obtain IP Address."
    4. Click on "No" and select "Advanced Settings."
    5. Now, click in the "IP Address" field to enter an IP address. Look at the brand of your router, and enter the IP address listed below into the field.
      • Linksys - enter: 192.168.001.140
      • Netgear - enter: 192.168.001.250
      • Belkin - enter: 192.168.002.090
      • D-Link - enter: 192.168.000.190
      • Apple - enter: 010.000.001.250
      • 2Wire - enter: 192.168.001.250
      • Actiontec - enter: 192.168.001.250
      • SMC Networks - enter: 192.168.002.190
      • Don't see your router brand listed? Click here for help with finding an IP address to enter.
    6. Once the IP address is entered, select "OK."
    7. Select the Subnet Mask box, then enter 255.255.255.0 and select "OK."
    8. Select the Default Router box. You will need to enter the defail gateway address for your router brand. Look at the brand of your router, and enter the gateway address listed below into the field.
      • Linksys - enter: 192.168.001.001
      • Netgear - enter: 192.168.001.001
      • Belkin - enter: 192.168.002.001
      • D-Link - enter: 192.168.000.001
      • Apple - enter: 010.000.001.253
      • 2Wire - enter: 192.168.001.254
      • Actiontec - enter: 192.168.001.001
      • SMC Networks - enter: 192.168.002.001
    9. Select "Confirm" but DO NOT select "Save."
    10. Tap the right arrow to reach the page ro "Auto Obtain DNS."
    11. Select "No" and then "Advanced Settings."
    12. Click into the "Primary DNS" field and enter: 008.008.008.008
    13. Click into the "Secondary DNS" field and enter: 008.008.004.004 Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
    14. Select "Confirm," and then "Save."
    15. Click on "Save" and then "OK" to perform a connection test.
    16. If the test was successful, then your Wii is now connected online. If you received error code 52130, please call 1-800-255-3700 so that we may assist you further.
  2. Other suggestions:
    • Did this connection used to work but has suddently stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the router back in. Wait a couple of minutes for it to initialize, and try to connect the Wii console online and test for proper response.
    • Check for wireless interference, which can affect the signal strength to the Wii console. To help minimize wireless interference, try the following:
      • Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Wii console is an open area without objects or electronics blocking the signal. (For instance, if the Wii is placed in a crowded entertainment center, try moving the Wii somewhere with more room.)
      • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
May 05, 2011 | Nintendo Wii Console
Someone has changed my IP address hacked into in my router
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jul 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin 54g Wireless DSL/Cable Router (DHF5D72304): Im trying to hook my wii up to the internet and it...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings change channel type to 3 or 6 or 11 and save so you get better signal.
Then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
May 17, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
2 Pc's with same IP
AT either desktop or laptop:
[Start]
[Run]
[cmd]
A dark "DOS" windows will appear
At the prompt, type: ipconfig
press [ENTER]
Note the "IP Address" (probably 192.168.1.2)
type: ipconfig /renew
press [ENTER]
Note the IP Address
If it has changed, then you are ok. Type: exit and press [ENTER]
If it did not change, then try this on the other computer.
If that didn't change either, the go to the Control Panel
[Network Settings]
Find the wireless or wired network adapter and Right-Click
Choose "Prpoerties"
In the Properties window, double-click "IP Address"
See the IP Address assigned? change the last digit by one number.
Example: if the IP Address is 192.168.1.2 then change to 192.168.1.3
[OK] [OK][OK]
It should work now...
Let us know!
Sep 17, 2009 | Linksys Wireless-G WRT54G Router
I cant get my wii to hook up to the router
Try resetting your router. Do this by having physical access to you router, and there should be a reset button (or hole) in the back of your router. You may need a pin or something very skinny to fit it through. Hold it for 20 or 30 seconds. After it is reset, type in your address bar 192.168.1.1. When a dialog box appears asking you for your username and password, leave the username field blank and type in admin for the password. The router configuration page should load up. Scroll down and change the Local IP Address to 192.168.2.1. Scroll down and click save settings. Atttempt to configure your Wii's wireless internet settings all over. Your Wii should be able to connect to the internet now.
Dec 28, 2008 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Assuming the laptop is running XP -
Open Control Panel
Open Network Connections
Right click on the network adapter and select Properties
Click on TCP/IP and then Properties
You can change the IP address here but it will probably work best if you have it obtain an IP address automatically.
Sep 28, 2008 | NetGear WGR614 54Mbps Wireless Router...
Laptops do not recieve IP address from the router
Carlos
I think the problem lies within the dhcp of your router. Make sure dhcp is on and change the lease time to 1440 minutes or higher that way once you have the ip address it will stay with your laptop longer. alternatively allocate the ip address on your laptop manually.
good luck
smeags
Jan 03, 2008 | Trendware TEW-452BRP Wireless Router...
NetGear WGR614 Wireless Router Logo
50 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
