Question about Kenmore 23822 Top Load Washer
Won't drain and go into rinse cycle
When it finishes agitating it ticks a few times and then nothing happens
  • 1 more comment
  • Ben Presley Feb 05, 2009
    my washer has the same problem. just as soon as the washer finishes agitating it stops.
  • Anonymous Feb 06, 2009
    I have the same problem. I checked the lid latch and it is broke. My washer is Kenmore model 110; 92480200, serial # CE 3033462. Do you know where I might get a part, and how whould I replace it. I am a widow, so please be basic in instructions. Thank you so much.
  • jonimargaret Feb 06, 2009
    I also hav e the same problem. I checked the lid latch and it is broken. Where would I get the part, and how would I replace it. Please be basic in instructions. It is a kenmore model # 92480200, serial # CE 3033462. Thank you so much.
  • 5,911 Answers
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured.
I can also provide information on how to replace a lid switch and give advice on where to purchase a replacement (if needed).
Posted on Feb 05, 2009
  • Jeff Rockwell
    Jeff Rockwell Feb 10, 2009
    To all that have posted under this request,
    A replacement lid switch can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. All three sites offer competitive pricing, so shop all three for the best price. For instructions on how to replace a lid switch, you can refer to my profile and look under my "Tips and Tricks" for links for Replacing a Lid Switch. If you still need assistance, please contact me and let me know.
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
My washer's timer ticks and runs through the cycle, but nothing else happens....no agitation, no rinse, nothing. Prior to this, the agitation cycle would go so crazy that it would rock the entire machine ...
ok,,its the program bord gone wonky,,,,,to drain your washer take the outlet hose and lower it below the washer all the water in the drum should drain out then,,,
Nov 28, 2010 | Maytag Washing Machines
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Maytag SAV5910aww will not always drain. Fills and agitates fine but will go through entire cycle without draining. Will sometimes give end of cycle buzz sometimes not. If I am in the room and lift the lid...
"I have found spinning the timer back to begining of rinse cycle first helps". The timer only rotates clockwise; counterclockwise rotation can destroy it.
May 18, 2017 | Maytag SAV5910 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Mar 10, 2008 | Washing Machines
No agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Dec 01, 2007 | Washing Machines
Kenmore 23822 Top Load Washer Logo
89 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
