Question about HP LaserJet 4 plus Printer
Mac laptop hooked up to HP laserjet 4 plus gets error message:
Error message:  W2 invalid pers
  • gethealthy Feb 05, 2009
    What is and where do I get a postscript personality module 4M or 4M plus for my HP Laser jet 4 plus
You have two choices:
1) Purchase and install a Postscript SIMM or Cartridge.  This will allow you to use the standard Apple driver which is Postscript (likely the one you are presently trying to use)
2) Simply use the generic PCL driver included in your list of drivers on your Mac.  The driver name is "HP Laserjet Series PCL 4/5, 1.3" This will allow you to print using PCL the native page decription language of your printer.
The error "W2 Invalid Pers" means that you are sneding a print job in Postscript whne the printer only "speaks" PCL.
Posted on Feb 09, 2009
    Novelist:
  • 155 Answers
This printer will not work with a Mac - it has no postscript.
The only laserjet 4's that work with Macs all have an "M" in their name - 4M, 4M Plus etc.
You might be able to get a Postscript personality module for the printer to effectively upgrade it to the "M" version.
Posted on Feb 05, 2009
Invalid pers error, but it used to work fine: is this a memory problem
Dear master. I have a lapos VeriFone VX 680. when i open there are one maggage **security alarm** tampering detected [000C10] please reboot -
Feb 25, 2014 | HP LaserJet 4 Printer
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
then select 4:PlotsOff.
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
I have an envelope feeder that came with my old LaserJet 4 many years ago. I replaced the LJ 4 with an LJ 4-Plus and tried to use the envelope feeder on it. I get an immediate error message "EE...
My suspiction is there is a tab on the tray that triggers a switch telling the printer what type of tray has been inserted. Your old tray is likely different from the Plus 4 tray and the printer knows it.
Jun 04, 2010 | HP LaserJet 4 plus Printer
W2 invalid pers
The job needs the correct language i.e., Postscript, PCL 5 or 6 installed.
You're trying to print a job in a particular language that isn't installed on your printer. You need to load the correct driver.
Dec 28, 2009 | HP LaserJet 4 plus Printer
ERROR MESSAGE 40 MIO
Seems like you need an Error Code Chart.
So here's a complete chart of all error codes.
Hope it helps.
http://www.fixyourownprinter.com/reference/errorcodes/hp
Nov 15, 2009 | HP LaserJet 4 plus Printer
57 service error message. Wht does that mean? We
A fan failure was detected.Printer fan or Duplex fan.
1. Check the fan’s connector and make sure the fan is not blocked.
2. Replace the fan.
On older style printers this is often caused by a bad main motor. (Older style printer being printers with halogen heating elements in the fuser - 4, 4+, 5, 4si, 5si, etc).
Oct 19, 2009 | HP LaserJet 4 plus Printer
DISPLAYS ERROR MESSAGE: W2 INVALID PERS. WHAT DOES THIS MEAN AND HOW DO I GET IT TO PRINT?
FROM THE SERVICE MANUAL
W2 INVALID PERS:
The job was not printed because the requested personality,
such as PostScript, was not installed. Install the language in
which the files are sent, together with enough memory to
support that language.
I SUGGEST CHECK IF YOU GOT THE POSTSCRIPT INSTALLED
May 04, 2009 | HP LaserJet 4 plus Printer
Error Messages
All you can do is look at the manual provided or go to the manufactor website.
Rate 4 diamonds
Mar 02, 2009 | HP LaserJet 4 plus Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
REPAIR
Yemmitty,
According to the HP LaserJet 4 plus service guide. Your error code of 57.1 indicates the following;
1) The printer's gears are siezed
2) The DC controller or main motor is defective.
Nov 10, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
291 people viewed this question
Ben Johnson
