Question about HP Officejet Pro L7780 All-In-One InkJet Printer
HPoffice jet L7780 says printhead has problems, cant print anythi
My printer says printhead has a problems with KY(blk/yellow) I tried cleaning them as instructed, the printer is less than 1yr. and none of the bottons ie menu etc even work I called the PC store and he said to clean it and usually the print head never has to be changed this early HELP!!
  • 1 more comment
  • breaker1 Mar 04, 2009
    printhead has problems. I tried clning them as the instructions says and it does not work. This is the second time this junk is giving me a problem. The last time I called Hp, it was a waste of my time because they could not help me.
  • dbond714 Mar 05, 2009
    I had the same problem. I bought a new printhead cartridge and installed it and got the same message. I called HP and spoke with support at 1 800 474 6836. After 2.5 painful hours of troubleshooting with no luck they shipped out a new one. All HP printers have a 1 year warrenty on parts and labor.
  • Anonymous May 03, 2009
    HP Officejet Pro L7500/L7600/7700
    Printhead problems black/yellow. Help! nothing has worked.
Tinteiros
  • 85 Answers
SOURCE: HP L7780
Clogged Inkjets? Could they be white Lines in your prints? Assuming your inkjet printer worked OK before a period of non use? And you do not have any strange flashing lights, or an obvious electrical fault or malfunction?
Then most about 98% are more likely to be an ink clog which just needs to be unclogged using something like WARMED Magic Inkjet Flush
Basically, if a print head has been left unused for some time... moisture inside the ink begins to evaporate and instead of liquid ink, a thick inky jelly begins to form inside the print head.
When this occurs white lines appear in prints and most people not realising the problem, will replace their inks... But when that does not work. Some assume they have an electrical fault, and replace their print head, others will replace their printer !
But provided there is no obvious print head damage? In 98% of cases it simply needs a little patience and WARMED Magic Inkjet Flush injecting directly into the print head to dissolve the dried ink trapped inside. This will dissolve the clog and allow your expensive ink to flow once again. Most will then print as new.
Hope this helps to explain.
Posted on Jun 03, 2008
technotech
  • 183 Answers
SOURCE: HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
If reprinting did not help, try increasing the print quality mode.
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only)
If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Step four: Clean the printheads
If the print quality is still bad, clean the printheads.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Step five: Align the printheads
If the print quality is still bad, align the printheads.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed
If the print quality is still bad, calibrate the linefeed:
Open the printer Toolbox and select the Printer Services tab.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads
If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
Press the Setup button.
Press 1 and * simultaneously.
Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
If the Black block has lines – replace the KY printhead.
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
If the Red block has lines – replace the KY printhead.
If the Green block has lines – replace the KY printhead.
Posted on Nov 10, 2008
SOURCE: k550 air in ink feedlines
I have had this happen a couple of times and have cured it easily. It has only happened with the black with me. It seems to be caused by air in the ink feed line. With the printer switched on open the top cover and hold the resume button for 5 seconds. The printheads should move to the left and you may be able to see air in the pipe(s). Remove the printhead of the offending colour(s) then insert a syringe with the plunger fully down into the rubber that the printhead connects to. Draw up the syringe plunger to draw ink/air through until you can see no more air in the pipe. Replace the printhead and close the cover. The printer should now do a calibration with the offending colour hopefully now working.
Posted on Mar 29, 2009
yboyandrei
  • 828 Answers
SOURCE: Flashing KY. I cleaned the print heads and
this is the time the board of your printer short circuit. theres is not problem with your ink or even you replaced it is still there... try to look for technician.
Posted on Jun 16, 2009
SOURCE: HP k5400 KY printhead always reports bad on Monday morning
Remove the Printhead and clean the contacts on the back of the printhead and also in the where the printhead mounts.
Try leaving the printer turned on over the weekend as the fault maybe caused by the ink drying out.
Posted on Dec 08, 2009
Printer: HP OfficeJet L7780 All-In-One B/Y PrintHead First Installed: 03/26/2011 A few months ago, I purchased a brand new print head and the three pack of color ink. It worked fine for a few days...
Try reset your printer by following this procedure to reset it,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.This should fix the problem.
Jul 06, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
The following printhead has a problem black/yellow the printer will not print. These are new ink cartiladge
Hello and welcome to FixYa!
In the HP OfficeJet Pro L7780 the printheads are actually separate from the ink cartridges. In your case, it sounds like the black/yellow head has worn out and will need to be replaced. The good news is, this is a user replaceable part. The bad news is, the replacement heads are not cheap. Amazon has the HP 88 Black/Yellow printhead listed currently for about $61.
http://www.amazon.com/HP-Yellow-Officejet-Printhead-Packaging/dp/B000BO9L8M/ref=dp_cp_ob_e_title_0
YouTube has a nice video that explains how to install the printheads here:
http://www.youtube.com/watch?v=8Zl0LUxBSvg
I hope this helps!
Mar 02, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro K550 - Printhead Error Message on new printhead - cleaned printhead, contacts... tried all fixes... what now? Is it faulty?
I have the same problem. I replaced both printhead cartidges. The MC light stopped blinking, but the KY light kept blinking. I thought it was a faulty new KY ink cartridge. So I returned that cartridge and got a new one. Still the same issue. I called hp and they said the print head is bad now and all they focused on was trying to sell me a new printer. UG! I also heard wiping off the printhead with a dry cloth may help. Did you get yours to wokr?
Jan 27, 2011 | HP OfficeJet Pro k550 Printer
Magenta and cyan will not print on my hp officejet pro L7590 -- it started with a paper jam that was corrected - ever since then only the yellow and black will print on the paper -- printheads are good and...
Same thing happened to my printer hp L7590. Printed diagnostic, only black and yellow printed; diagnostic for printhead health Ky=good, MC= good. Only Hp products ever used. Uplugged, & discharged static, cleaned copper parts of printhead. Still no fix. On visual examination of floor of printhead compartment rectangular pad ( approx 1/4" by 1/2") is missing. I can only guess that during the paper jam, somehow the pad got caught up and went awol. Not sure what to do now.
May 26, 2010 | HP Office Equipment & Supplies
On my Test Pattern 2 the blue/light blue and green/yeallow have steeks in it. The documents that I print have streaks going across the page. I've cleaned everythign I can clean. The printer has 6,251...
SolutionFollow the given steps in the order presented to resolve the issue: Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Dec 21, 2009 | HP OfficeJet Pro L7580 InkJet Printer
I have three HP L7780 printers that have bad print heads black/yellow. replaced but same problem. ?????
take out printheads. unplugg power cable from back press adn hold down 6 and # buttons on pritner at same time while holding them down plugg it back in. then insert printheads one by one. first insert black/yellow shutt the door adn check for message on pritner screen. if it says printhead missing cyan/megenta it means it detected black/yellow printhead. do same with cyan/megenta adn check for message on screen. if you see no error mesage and both printheads were detected fine let the printheads alligned completely. then if u see same issue it is the pritner whgich need to be replaced.
Dec 15, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
L7780...had problems printing, took out the printhead to look at but now the printer says the printhead has a problem, help!!
check the lids from the printhead to the logic board. remove the ink and examine the nostril u could clean it with clean cloth soak in water. then if it persist replacement is best option
Aug 30, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
501 people viewed this question
Seeker5211
Seeker5211
