Question about Intel D845GVSR Motherboard
Screen in power save mod
Hi iv got an ibit is7 motherboard all up and ready to run but when i turn it on it says that the screen is in power save mode press any key or move the mouse iv tryed that but with no luck can u help plz les
    Master:
  • 474 Answers
What kind of video do you have? onboard? or a video card?
If a card, then you need to set the bios to whatever the slot type is such as AGP or PCI Express.
Posted on Feb 06, 2009
Abit is7-v2 cmos checksum error
Have you replaced the battery?
Mar 14, 2013 | Abit IS7-V2 Motherboard
I installed everything the CPU, RAM, and everything else. Connected all switches at the right places and the BIOS is on normal operation. I turn on the computer and its a blank screen nothing shows up....
ok, looking at the specifications All I can recommend is the following. double check the Video card to make sure it is properly seated and that it does not exceed the capabilities of the motherboard. 2 Disconnect everything from the motherboard except the CPU and case wiring/power supply and turn the computer on. If the system completes the post test, you will hear at least 1 beep and should hear several for the video card not being connected, then start installing components 1 at a time till you find the one causing the problem. Start with the Video card and then the ram as these are most likely where your problem is unless you have a faulty power supply which will be the problem if you don't get a completed post with nothing else connected.
Jun 18, 2010 | Abit IS7-V2 Motherboard
Abit is7-e2g shuttdown
observe the CPU temperature,
it could be a heat issue,
try to reseat your heatsink then wipe the old thermal paste and put a thin layer of thermal paste
hope this thing helps
Jan 31, 2010 | Abit IS7-E2G Motherboard
Hi! I have a pc with abit is7-e2 motherboard.. And when i start the pc a red led turns on the board... There is no picture on the screen. I already checked the video card but its working
Just how did you check the video card if you get no image on the screen?
Try another monitor with your computer. If you still get no image, then it's your video card or another component.
If your computer will not pass the POST (power on self test) then you will not get any video output.
Culprits can be the hard drive, the CD, the memory, the motherboard, or the CPU. I would disconnect everything but the CPU, memory, and video and try to start it to narrow the problem. But first, try another monitor.
I've even seen a bad power supply that seems to work keep the video from working.
Jan 16, 2010 | Abit IS7-E2 Motherboard
Sata harddrive max size for abit is7 e2?
hard drive can be as much you want does not have a max size ,anyway not the motherboard you have to worry about if you put bigger hard drive you shold change the power source .
Nov 13, 2009 | Abit IS7-E2 Motherboard
Abit IS7-E2 monitor wont display anything
is this a brand new motherboard?
do you have onboard graphics or a card?
without testing i couldnt say for sure but it sounds like you are not getting power to your graphics on motherboard.
this is usally a common issue for asus motherboards. not easy to fix.
if your motherboard is new i suggest a replacement from the seller.
Feb 24, 2009 | Abit IS7-E2 Motherboard
E153fp goes dark into power save mode after Windows start up
may be your power saving option have small time .
check in control panel power option check power shemes.set it to 20 minutes.
Nov 27, 2008 | Dell E153FP 15" LCD Monitor
Need help
if you have more than 1 device on the ribbon cable, make sure they are both on CS(cable select) or one is on master and one is on slave.
Next disconnect all the drives from the board and just hit the del key to enter the BIOS. Select advanced tab to make sure SATA is active, otherwise you will bypass any sata and go only to ide channels.
Once the sata is active, check boot sequence and select CD/DVD as 1st boot priority save and exit, on the reboot turn unit off and attach all cables to the board. Reboot.
Mar 19, 2008 | Abit IS7 Motherboard
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
