Question about Panasonic SD-YD250 Bread Maker
The pan is stuck in my Sunbeam bread machine
How do I get the pan out of the machine?
    Problem Solver:
  • 10 Answers
I just had the same problem. What the manual either does not tell you or hides quite well is that you have to TWIST the pan before lifting it out. I don't know why this was listed under the Panasonic bread machine when it clearly refers to the Sunbeam bread machine.
Posted on Jun 08, 2009
I agree with Sol #2 by Apprentice Zaivalananda. You wiggle or carefully twist the pan first. Then it comes out easily. Another tip: when the buzzer buzzes, turn off the machine at the wall, open the lid and wait for about 3 minutes to allow the machine to cool down before donning mitts to twist the pan. Then like magic, out it comes! Voila! Next turn pan upside down & grasp the cross piece & twist it both left and right about a third of an inch to loosen the bread.
Posted on Jul 11, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
There would be an opening in the bottom of your machine. Try opening that lid.
Do rate the solution if you find it helpful
Thanks
Rylee
Posted on Feb 05, 2009
How do I get a manual
http://kitchen.manualsonline.com/manuals/mfg/sunbeam/5891_1_2.html
Dec 25, 2015 | Sunbeam 5891 Bread Maker
I have a Sunbeam Convection Bakehouse model BM005 and the bread pan sticks all the time so badly that is it impossible to get the loaf out without mutilating it. What can I do?
We have one and used it for years. What we found works is to take the kneading plate out before it starts cooking. Do this after the beeps to let you know when to add fruit, and the kneading has finished.
This also saves bread as you do not loose a bug chunk in the bottom. Our pan is not very good any more, but we can still get the loaf out without any problems. Just need to let it cool for about 10 minutes out of the machine before attempting to take the loaf out if it is stuck.
Nov 24, 2010 | Sunbeam Kitchen Appliances - Others
Model 5891 Breadmaker. The gasket for the mixing shaft at the bottom of the bread pan has deteriorated and ingredients leak through. Can I replace the gasket and/or bread pan?
hi sonotim, Here is website that shows the pan that would replace yours as the first item. I think locating just the little gasket would be difficult. It looks like the site will probably redirect you to ebay. There are a lot of parts for bread machines on ebay. If you feel this is helpful please rate/rank/vote for me on fixya....Thanks!
http://www.bizrate.com/breadmakers/sunbeam-bread-machine-parts/
Oct 19, 2010 | Sunbeam 5891 Bread Maker
Looking for a replacement rubber gasket for my Sunbeam 5891 Bread Maker. It goes between the bread pan and the machine itself, and my current one is split.
Hi..If you are referring to the gasket that sits on the bottom of the bread pan and is part of the sealed bearing assembly , then that gasket can not be replaced. Hank
Sep 22, 2010 | Sunbeam 5891 Bread Maker
Where can I get a new bread pan for my Betty Crocker Bread Machine Model BCF1690
Try this link. BCF1690 is same as Betty Crocker ( at least the last time I checked).
http://www.amazon.com/Oster-Sunbeam-102529-000-000-Bread-Pan/dp/B000PJBFDW/ref=cm_cr_pr_pb_i
It will cost you about $30.00 with shipping.
You can get a new one here for only $56.00 warranted for 1 year.
http://www.amazon.com/Sunbeam-5891-2-Pound-Programmable-Breadmaker/dp/B00067REBU
Hank
Jul 14, 2010 | Betty Crocker BCF1690 Bread Maker
The paddle will not stay in the machine and the water leaks out
The sealed bearing at the bottom of your bread pan has failed. There is no fix for it. You will need to hunt around for a new bread pan. Check ebay. (My pan failed also, and the pans on eBay were about $30.00. I bought a brand new Sunbeam at Walmart for just under $50.00. Oster and Sunbeam are the same). Good Luck...Hank
Dec 12, 2009 | Oster Kitchen Appliances - Others
I love my bread machine, model 5890, but with every loaf of bread the kneading blade stays inside the bread. The bread is also difficult to take out of the pan. This has led to scratches in the pan as...
I usually take the paddle out of the machine at the end of the kneading cycle and before the rise cycle. (Do this with the pan out of the machine..just in case). You don't want to use anything in the pan that will scratch it. Usually a few quick taps of the bread pan on the cutting board will free the bread.
Dec 05, 2009 | Sunbeam 5890 ExpressBake Bread Maker
Kneading blade stuck
The little bearing that turns the paddle is frozen. You will need to get a new bread pan. This happened to me after 7 years of use. If under warranty have them replace it. It was about $25.00 for a used bread pan on ebay, so I just bought a new machine at Wally World (Walmart) for $52.00.
Hank
Aug 03, 2009 | Sunbeam Kitchen Appliances - Others
Banana bread recipe for sunbeam 5895
I have made the following recipe in my West Bend machine with great results. I just got a Sunbeam 5895 at a garage sale - it works great - just wanted a different "shape" loaf! I'm going to use this recipe in my Sunbeam - don't see why it won't work!
Here's the recipe!
1/2 cup softened butter, cut into small pieces for good blending
1 cup mashed ripe banana (personal note: if my ripe bananas don't measure up to 1 cup, I add enough milk to make it 1 cup. Seems to be okay)
2 eggs, large, slightly beaten
1/2 cup chopped nuts (optional)
2 cups all purpose flour
3/4 cup sugar
1 teaspoon baking powder
1/2 teaspoon baking soda
1/2 teaspoon salt
Grease inside of pan and knead bar generously with vegetable shortening (I just spray with Pan Spray). All all ingredients in order listed above to pan. Lock pan into bread machine. Program for quick bread. After a few minutes of mixing, I usually take a rubber spatula and scrape down the sides and stir in any flour that has not been completely mixed. I didn't do this once and ended up with a loaf that had flour coated corners!
Good Luck! Enjoy!
May 31, 2009 | Sunbeam 5895 ExpressBake Bread Maker
Panasonic SD-YD250 Bread Maker Logo
296 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Oloyede Monsuru
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
