Question about JVC FS-2000 Shelf System
Cd lid will not open when I press the button. I have to pry it open manually. Otherwise it works fine. Can anyone help?
  • 1 more comment
  • Teresa Weber-Freeman
    Teresa Weber-Freeman Feb 06, 2009
    There is a sign on the back "risk of electric shock -- do not open". I know it seems silly but is it ok to open? It's all unplugged so there shouldn't be any electricity running through it and I guess no tube like the tv... I open my computer to fix. If you could answer then I will go ahead and try your fix. Thank you so much...
    Teresa Weber-Freeman Feb 07, 2009
    I took all the screws out but could not get the unit open to check the belt. Is there a trick to opening the unit? If I cannot open, where do you recommend for repair -or- is it worth it? I just wanted to save a bit of money by fixing it rather than purchasing new. thank you again.
    Thanks. I cannot even figure out how to get under there so I will look into having it repaired.
    Brigadier General:
  • 8,619 Answers
Hi!
There is a belt inside your player that is used for this mechanism. The belt is off its place or is broken, if you can then change the belt or visit a technician to get it done.
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Posted on Feb 05, 2009
  • Rylee Smith
    Rylee Smith Feb 06, 2009
    The risk of electric shock is always there as it has certain components which even in off condition stores electric charges and if touched can prove fatal. If you haven't done this before then i will not suggest you to do this.
  • Rylee Smith
    Rylee Smith Feb 07, 2009
    The belt is under the cd lid, attached to the motor which opens the lid, in your jvc it is hidden just under the lid. If you are not able to figure it out then get it repaired. As its a small repair and won't cost you that much.
    If you need to know a place from where you can get it fixed then please see this link--
    Repair Links
    Do rate the solution if you find this helpful.
    Thanks
    Rylee
Gas door will not open. Fuse is ok.
it is difficult to open but when you get it open there is a spring at the hinge of the door that is broken or missing
they are easy to replace and cheap from the spare parts department of the dealer spares
press the button and have some one press the lid closed to easy the tension on the latch then try to pry the lid open
Nov 04, 2015 | Cars & Trucks
The cd player will not open when you press the open close button
unfortunatly the mechanism is jammed up for one reason or the other reason #1 a cd is stuck inside #2 the gear just wore out and or it was forced closed by hand instead of pushing the eject/load button..you can try to gently pry this door open while pressing open/eject button that works 40% of the time..if it does not work? it can then be deemed broken out of order.
it's worth a shot trying to pry it open but beware this could either work or really destroy the door/mech/player comes down to this "do you feel lucky" sadly? that's where we're at with this one.
Mar 20, 2014 | Electro Brand Nostalgic Stereo CD Music...
How do I open? In the directions it says "press to open disc". no button to press.
The entire lid over the disc compartment functions as a button. GENTLY press down on the lid.
Jun 25, 2013 | GPX PD908BU Portable DVD Player - 9 inch...
Drawer wont slide and dishwasher does not work
please provide the model number of the dishwasher so that I can identify the type of lid seal it is using. Usually the lid seal actuator motors are stuck and prevent drawer from opening. You could force it open with a slight tug. Otherwise turn the mains power off and on and see if it makes any difference. Need to check the lid seals for damage otherwise it may leak in future and cause flood switch to trip.
Dec 07, 2012 | Fisher and Paykel Dishwashers
The Open/close does not work. Power is on and it
First try resetting the player. Unplug for 1/2 hour-1hr., press and hold power button for 3 seconds, wait 1/2 hour, plug back in and it should work. Otherwise you can pry open the door with a paper clip. Slowly pull door as far back as it will go, then press eject button and see if everything aligns itself back on track.
Nov 23, 2009 | Panasonic DVD-RV31 DVD Player
Left hinge busted
Dunt open and close lcd too muh otherwise it will damge your lcd cover and lcd bezel than it will cost u more. Remove all lcd screw cap and remove screws than slowly pull out lcd bezel and check is really hinges is gone or screw is loose. For Key u have to check it that any of latch of behind key is broken or fine. If its fine than just put that parallel to other keys and press it. it will seat back on jumper.
Jul 28, 2009 | HP Pavilion dv4000 Notebook
1995 jaguar xj6 dead battery and can't open trunk. please help,
I simply opened the bonnet. Connected the battery charge positive to the + feed on the back of the alternator, connected the negative to the body. Turned it on, immediately the interior light comes on. Turn on the ignition press the cabin boot switch and it opens the boot. Charge battery as normal. Easy Peezy
Feb 16, 2009 | Jaguar XJR Cars & Trucks
2003 Gran Cherokee CD Changer
Hi
I don't know if anyone's helped you with this yet, but to find the CD changer, open the rear door, and if you look just below the rearmost right window you'll see a hatch with a release button. Press the button, lift the lid, and there's your CD changer. Hope this is helpful. Good luck!
Aug 02, 2008 | Cherokee Jeep Grand CD Changers - 10-Disc
CD drawer won't open
hi, try opening up the cover lid, and manually give a mild push to the tray, must be some small jam, or the eject belt or gear,.let me know
Dec 28, 2007 | Teac GF-300 CD Shelf System
JVC FS-2000 Shelf System Logo
356 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
