Question about Kodak EASYSHARE 5100 All-In-One Printer
Printer Problem on Multiple Printers: As if low ink on both
My Kokak 5100 All in One suddenly began printing as if there were no ink in the cartridges. I knew the color cartridge was just about out, so I changed it. That didn't work.
So I cleaned and calibrated. That didn't work.
I uninstalled and reinstalled the software and firmware. That didn't work.
So I hooked up an HP Deskjet 930c (old) and tried printing to that. Suddenly, a printer that once worked fine was printing as if it had low or no ink in both B&W and color cartridges. Just like the Kodak.
So I tried troubleshooting, cleaning, calibrating, reinstalling, etc. Nothing works.
Why would two different printers suddenly manifest the same problem? I've been through their properties and everything is set up correctly.
My only clue: I went to the Coricidin website to print a coupon, and that's when it startted. Has something attacked my PC?
  • 3 more comments
  • rdoyce Feb 09, 2009
    I have the same problems, I have bought new ink two times, cleaned the printing head 6 times, still not printing right.
  • Blue Topaz Feb 09, 2009
    Kodak has sent out a new printhead to me, free of charge. This must be very common is they are just sending out free printheads willy-nilly.
  • Anonymous Feb 10, 2009
    My Kodak Easyshare 5100 just stopped printing too, but I already replaced the print head once. Do I need another one?
  • rdoyce May 11, 2010
    Thanks, I did order a new printhead, but I also used a small pump with a drop of water to open the printhead up.
    Thanks for the information!
  • Aleta Albert
    Aleta Albert Apr 06, 2012
    Bought my first Kodak all in one printer in 2009. Same issues. Sent free printhead twice. Then a replacement "refurbished" printer. Same problems after several months. Sent me a new replacement printer. Same problems after six months. Now after contacting Kodak am told I can purchase a new printhead for thirty some dollars plus shipping or can have a coupon for 40% off a new Kodak printer. Gotta be kidding. I wouldn't take a fourth Kodak printer if they gave it to me (they're not offering to). The printhead is definitely a problem and eats a lot of ink.
The printhead has dried out and you need to contact kodak to get a replacement, they may do this under warranty. The same thing has happened twice now with my AIO 5500, I guess the problem is if you don't print very often, the ink dries out in the printhead itself, not the cartridges.
Posted on Feb 09, 2009
Hello, I have a Canon Pixma MX860 all in one copier printer that just began to display error #5100. All the ink cartridges are full. How do I reset the printer so that this error will not be displayed...
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps1
Dec 18, 2010 | Microscan MS-860 Fixed/Industrial Barcode...
My Printer won't print, Amber light won't stop flashing.
Install the new cartridge for permanent solution for this error.
Sep 17, 2009 | HP DeskJet 940c InkJet Printer
Prints real lite
ink is likely low OR if the cartrage is old the print jet heads might be clogged try cleaning with rubbing alcohol
replace the ink cartrage
Aug 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Flashing red "check ink" lights and nothing is wrong with ink
Is there a resume button on the printer? If so press this, often printers will allow you to bypass a low ink message and print for a while longer.
Jun 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer will print pictures, but won't print documents.
Sometimes this happens because the ink dries in the print head. If multiple cleaning doesn't improve it you can try cleaning the print head itself with alcohol or an electronic spay can type cleaner. This should fix the problem for you. Also resetting the cartridges in the slots sometimes improves the ink flow.
Mar 29, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Multiple probs w/ HP 5150
Try `driverguide` on the net.
Update your printer driver, this should solve your problem.
Also check the printer lead is ok
Feb 02, 2009 | HP DeskJet 5150 InkJet Printer
Won't print red color
push and hold the power button for 35 seconds this will reset the color fill it should work
Dec 19, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 black will not print
In the UK call 0870 2430270
Tell them, because they will ask you to:
You have removed and reseated Black Cartridge
Carried Out Printhead Cleaning
Carried Out Calibration Test, and Black is missing
Did a Test Print (Press Photo & Copy together) and NO BLACK
and they will send a New Print Cradle overnight.
I also complained about wasting ink on multiple tests and got a new pack of ink as well.
Dec 07, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Bought new ink but photos arent printing.
It is more than likely the print head itself. It seems to be a problem with these printers.
Dec 05, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EasyShare 5100 All-in-one printer will not print ink
you most likely need to run a head clean and alignment, which is needed after each cartridge replacement.
http://tinyurl.com/6qcpgy
Jun 24, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
114 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
