Question about Yamaha Music
Loose AC connection to electronic piano
I have a cheap synthesizer (Kwai MS710) whose AC connector has come a bit loose. When I jiggle the adapter plug up and down I can often get power to the device (but that's obviously not a long term solution). When I opened up the box I can't see any obvious broken connection under the connector's plastic housing but, again, jiggling it does get results. Any ideas how to go about repairing it? I've never soldered anything before, but I'm certainly game to give it a try.
  • dbclin Feb 06, 2009
    Thanks for your reply.
    The cable is definitely not the problem as we've tried more than one adapter with the same results.
    Your suggestion about redoing the soldering does make a lot of sense. Where would those soldering points be, though? Should I just solder away blindly under the plastic connector casing? Is it possible to pull the whole casing off of the circuit board?
    I've attached a photo of the device with the AC connector circled.
    I appreciate your help!
    David
    Aha. That's what I needed to know.
    Thanks a million.
Your problem is most likely a broken cable in your ac cable. Try to replace the cord first (a place like Radio Shack will have replacements). If it's not the cable, then you might have a broken soldering point inside your keyboard. It might be too small of a crack to see, but redoing the soldering points should work.
Posted on Feb 06, 2009
  • weissmueller Feb 06, 2009
    You have to take the entire circuit board off, the soldering points are underneath. Do not try to pry the connector housing off, it will break. There should be screws holding the board. Be careful to detach all the little wire connectors and re-connect everything properly when you're done. Try not to touch anything on the board and hold it by the edges only.
Need AC adapter for Hohner 760 HDP electronic piano
Which country, part of the world= look at the manual, how many volts and ampere. Go to a electronic shop. with a picure of the plug or connection.
Jan 01, 2018 | Hohner Music
My korg micro-x synthesizer gets hot at the ac power input on the keyboard
hot connections indicate a short or bad connection ( like an arc welder )
loose wires or solder dry joint or broken wires creating a high resistance and heat in this area
Aug 06, 2016 | Korg Music
Ac adapter polarity
AC adapters usually have the polarity marked on the case. What you need to know is whether the tip or sleeve is positive as required by your synthesizer
May 14, 2013 | Korg Dynamic Percussion Synthesizer...
I have a Casio Privia PX-130 and I tried to turn it on and it wouldn't turn on. I have noticed lately that when I would be playing a song that when I pressed a certain key that it would make this...
Test the adapter with a meter... Most probable cause is a bad power connector. Often the solder at the input power connector breaks loose is only problem. If you are not electronically adept, best to take it to a shop.
Jun 27, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
Place where the ac adapter goes in that piece is loose.the keyboard dosent stay on unless sometimes i find a good position tomove the piece.the problem is internal(not the plug).
Likely the soldering of the connector to the circuit board has come loose. Take it to a shop or repair the unit yourself if electronically competent... the cost will be minimal... there are a lot of screws to take out to access the connector... be careful of the ribbon cables and connectors when opening.
Here is your service manual:
http://elektrotanya.com/korg_pa50_sm.rar/download.html
Scroll down to the link on the page "Get Manual" click on it to download.(nearly 18Mb pdf file, 27 compressed pages)
You will find the power jack on the PA-14.pnd drawing as "DJ1" It has three soldered connections.
Apr 22, 2011 | Korg PA50 61 Key Professional Arranger...
I have an allen and heath Xone 22 Mixer. Its great, except due to the lack of a power switch I pulled the ac adapter/power cord out too many times and now it has a really bad, loose connection. It works,...
Usually the connector that is board mounted is the problem. I would OPEN the unit as there may just be broken solder at the connector inside. If the connector requires replacement, find one at Digikey.com by searching for "power connector coaxial".
Hint: In the future install one of those little lamp switches that are in a little plastic box with knurled knob sticking out the sides. ONLY break ONE wire from the adapter to avoid getting the connections reversed. Since the wires are smaller than lamp cord, tack solder the wires to the piercing points of the switch .
Apr 11, 2011 | Allen & Heath Xone-22 2 Channel Dj Mixer
Our brand new Korg SP170 worked great for several days. Today all the C keys and all the E keys quit making any sound. We checked all cords and connections, turned it off a bit and back on, with it plugged...
There probably is a cable or connection inside that is loose... The keys are scanned as a matrix so some connections are in common...
HOWEVER: Since you have had it several days DO NOT delay, call for warranty service. This is not a DIY repair unless you are adept and comfortable with electronics.
Dec 10, 2010 | Korg SP170BK 88-key Digital Slab Piano...
The input for the ac adapter is loose and cuts outt all the time.
Connector is probably damaged. If you can open the unit you can get replacement connector from DigiKey.com and Mouser.com. You need to compare dimensions of the barrel AND the pin to insure you get the correct part. Also the pins that go through the board. One could go through Williams, but they may not have a parts dept.
Aug 11, 2010 | Williams Encore Digital Piano
Piano nova digital piano wont switch on. Green light is on on adapter but power switch does nothing.
Verify the cord from the adapter to the piano is not broken (common occurance) using a voltmeter at the connector.
Then verify the connnector is seated in the piano.
Apr 24, 2010 | Music
I have just aquired a Roland E-20 synthesizer which I am very pleased with, however, it doesn't have acoustic piano in the tone settings. Is it therefore possible to programme 'acoustic piano' onto the...
They use pre-programed chips. You will have to use the midi out feature to control another midi capable sound module or midi in to a computer and use the internal sound card.
Oct 24, 2009 | Music
Music Logo
371 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
