Question about Dell PowerEdge 2550 Server
Scsi raid with battery backed memory for pweredge 2550 server
Im having problems with the server once I use this scsi card, it gives me a "scanning scsi devices" in white bold text that blinks...but it never boots anything after that. Do I have the system configured properly?
  • denelledavis Mar 24, 2009
    ULTIMITLOOZR
    first of all thanks for responding to my post! I am very new at working with servers and I am currently trying to repair the scsi drives for them. The system is a dell power edge 2550 and the particular scsi card I'm having an issue with is a Dell PERC 4/DC Raid Controller. I'm going to try to remove all scsi devices and try it again per your last email. Hopefully I can figure something new out. If you had any free time during the 7-5pm time I would like to possibly contact you and maybe get walked through it if you would not mind the inconvenience.
    Thanks!
  • ultimitloozr May 11, 2010
    Did you verify that all SCSI devices are using unique IDs and proper termination on the chain? Most common problems to cause hanging with SCIS devices. You may have to remove all SCSI devices in order to get the SCSI card to reset first.
  • 558 Answers
If my memory serves me correct i think this server uses a onboard (3di) card it is set in the bios to use the raid configuration, under integrated devices .make sure this is so ,as it boots press f2 key to enter.If this is so exit.next step is to shut the machine off pull the drives away from the backplain not completly out. Power up if it starts laoding the raid configuration,once the scan is complete it will give you a container not found error,now here is what you can do go in i think its control m or r,anyway look at the configuration and what raid you set it up for.write down the drive number 0-etc.ok the next move is the raid key a little device that sits on the motherboard beside the raid dimm reseat this,now you may want to replace the raid dimm or if you have a exact match for troubleshooting purposes you may try this.
Good Luck
Posted on Sep 03, 2009
  • wilfred graham
    wilfred graham Sep 04, 2009
    my email is graysandsolutions @yahoo.com
Using my Dimage Scan Dual 4 SW with Windows 7 gives me trouble. Have konica Minolta SW ver. 1.0.0 for windows XP. It works fine on the XP computer. But I have great difficulties loading the SW on
Have you right clicked on the .exe file of windows 7 executable for the Minolta scanner to select compatibility to switch it back to xp.Have you tried to use third party twain drivers for scan software such as silverfast or vuescan instead?
Jan 24, 2015 | Konica Minolta Dimage Scan Dual IV Film...
Hi got the following error message ... "ScanFile
I have many years repairing canon scanners so here is my suggestion to you.
First does the scanner power up? If so that's eliminates a internal power supply problem.
Second did anyone change the dip-switch settings on the back of the scanner? Ill assume no on that one.
Third when you first boot up your computer do you see a screen when the computer is in boot up mode that says Adaptec SCSI and then a number? If not here is a couple things to check. First I would check the SCSI cable is good. No bent pins in the connector and no exposed wires coming out of the connector. If you can try swapping a good known working cable with the problem scanner. Second try re seating the SCSI card if that doesn't work do you have another card that you know works that you can swap into the problem computer. After swapping the cable first test to see if the scanner scans, then if you replace the card again retest to see if the scanner scans.
Lastly and I have seen this happen, the drivers may get corrupted if new software is installed that relates to scanning. You may want to google DR 3020 drivers that should pull up Canon's web site and reinstall the drivers. Once you install the latest drivers then reboot the computer and test it to see if it now scans.
Im sure one of my suggestions should correct your problem. I hope this helps you out.
Mar 18, 2011 | Canon DR 3020 Path-Through Scanner
Hi.. please help... After installing scsci card im getting message as bios not installed. It says that scsi bios not installed and that in device manager both scsci card and tape drive are installed...
Hi when you start the pc and goes to the scsi utilities and scans for device its not finding the device attached to it sioit gives you this message you can see if the terminator connect to the device is properly connected and its in its place ,also press CTRL+A to get into the adapter setting and in the scsi utilities section scan the devices if it finds it then check the id of the device how much its set to it should not be the same of the scsi card id .by default scsi card id is 7 but be sure.
Dec 10, 2010 | Adaptec APD-29160 MAC 64 BIT PCI SCSI...
I have dell 4600 pe serveri want to install Server2003 os i have configured raid 1 on the machine every thing is fine but! on boot process it display message no Boot Device Found Press F1 to continue F2...
The hard drive needs to be set as the first SCSI ID device boot device..
The hard drive needs to have the jumper set to SCSI ID 0, the CD and FDD can be set to SCSI ID 1 and SCSI ID 2. No SCSI devices can have the same SCSI ID number unless it is on a different SCS controller.
Jul 01, 2010 | Dell PowerEdge 4600 Server
While i was formatting a TC2120 server, i used low level formatting with Ctrl+A option after that the server is not detecting the SCSI hard disk although i've tried to install the third party driver with...
This error message usually relates to the wrong third party scsi drivers being use.
Check what SCSI card you have installed and make sure you have the correct drivers and that you select the correct driver from the list at the appropriate time.
It is also possible that the SCSI card itself has a problem, but it is far more likely to be the wrong driver.
Jun 29, 2009 | HP Server Tc2120 (335874-001)
Error beep sound on server, conf:Intel server motherboard se7520bd2 2 gb ram scsi harddrive problum:long beep sound in LSI LOGIC CARD
I don't think SCSI card give beep error codes. If you listed this item, most likely this is the problem and your MB is telling u this. Your SCSI card is most likely damaged. Try to make sure it is inserted in the pci slot properly. If it is....buy a new one. We rarely use SCSI cards any longer as most Servers have plenty of HDD space and the Hot Swappable options make them easy to replace if they get damaged.
As a tech, I would first check the Mother Board (BIOS) Beep Error codes to determine exactly what the problem is. Those beeps tell u what hardware is malfunctioning.
Jun 06, 2009 | Intel Xeon, 3.6 GHz (bx80546kg3600ep)...
SCSI Devices not detected when posting ML530 Server.....
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
Jan 30, 2009 | HP Compaq ProLiant ML530 Server
Getting an Error Message when trying to scan
SCSI devices are detected as the computer is booting. If your scanner was powered on after your computer was already up and running, it may not have been identified by the SCSI card. Try leavinging the scanner connected and powered on and then reboot your computer. Also, the pins on the SCSI cable connectors are easy to bend; inspect the rows of small pins with a flashlight or just try a different cable if you have one.
Dec 01, 2008 | Office Equipment & Supplies
Unkown SCSI Problem
Hi Fatoil ,
Have you tried another SCSI port , another SCSI card , another SCSI drive , swopping if it is card problem or drive or both problem ?.
If you have a spare SCSI hd , plug it in to same port and see if it works . Swop to another port and see if the spare SCSI hd works. Swop to another SCSI card and see if spare SCSI hd works.
All this elimination will narrow down the problem .
SCSI cards are not expensive ,.
old working SCSI hds don't cost you anything if you have them.
Sending out the server for servicing will cost you.
I presume you don't have a maintenance contract for this server .
If you have , get them down to settle it .
If you don't , after you settle this matter , make sure you get a maintenance contract for all your critical servers / equipment.
Maint Contracts seem expensive when nothing breaks down. However , when they do , it makes every worry go away.
Good luck,
David
May 26, 2008 | HP CC3310 (a9863a) Server
Dell PowerEdge 2550 Server Logo
326 people viewed this question
Alun Cox
