Question about Zebra Z4M Printer
Out of Paper Error
Our Zebra willl print 2 labels then get the "Out of Paper" error and the label keeps moving to the right when printing (if you are standing in front of the printer it's the right)
  • tyndall_hewi Feb 05, 2009
    The issue appeared to be the Reflective Sensor (which is on a slide) needed moved to the right about 1/4 inch. this seems to have fixed the problem.
  • ROD GANDY May 11, 2010
    YOU MAY NEED TO PUT SOME PAPER UNDERNIETH THE LABEL FOR OR MAKE IT MORE STURIDY OR SWITCH MAYBE DEFFECTIVE OR DEVICE IS MALFUNCTIONING
    President:
  • 2,976 Answers
You get the error because the printer doesn't see any paper.
There are paper guides that need to be set for the size of the labels being printed. If you are switching from a 4" wide roll or sheet to a 3 1/2" label, you will have to move the slider in about 1/2". You will also have to calibrate the printer when you change label stock. If it won't calibrate, make sure the photoeye is hittint the break between labels. The photoeye is located where you insert the labels into the printhead path.
Posted on Feb 05, 2009
Zebra Z6m Error Paper Out
sensor not working or dirty in the feed path id suggest
Dec 27, 2017 | Zebra Z6M Plus Thermal Label Printer
I turn on the zebra z4m and it runs the labels even with no information sent to the printer. I can not use the cancel or pause button to stop. I runs for a minute and then error condition ribbon out. I...
1.Double check that the ribbon and the labels are routed correctly. 2.Make sure the media guide is holding the labels against the inside of the printer and not moving to the right away from the media sensor. If the labels are sliding to the right as they come out, increase the left side head pressure on top with a flat blade screw driver. Download the user manual at zebra.com .Check the media type and sensor type, and set for thermal transfer if using a ribbon.
Feb 24, 2011 | Zebra Z4M Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
LP2844 printer stops after one page with out of paper error
Did you try to reload the labels. Pull the labels out and clean the paper path
May 07, 2010 | Zebra LP 2844 Thermal Printer
Out of paper error in Zebra 110XiIII plus
There is a small thumb screw under the paper guide that has an adjustable stop to hold the paper. If you load it correctly, you should have one on each side to guide the paper into the printer. Also, the machine has either a roller or a bar to hang the labels on, correct? The bar has an adjustable stop to keep the roll from moving around while you print. You may want to setup the media sensor about 1 cm from the left of the printer to make it less subject to this type of error. They come from the factory very close to the edge of the paper to allow for some card printers to work well out of the box. Most people use labels and this is not necessary. I hope I have given you some helpful information.
May 06, 2009 | Zebra 110Xi III Plus Thermal Printer
Zebra 4M printer stopping due to error message
The printer is dirty sensor label or no label is calibrated. Turn off the printer and press FEED, CANCEL, PAUSE and turn on, release the keys to advancing the label, and let print be calibrated. Roberto Martinez Mexico bartech9@yahoo.com.mx
Feb 26, 2009 | Zebra Z4M Printer
Zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
Jan 16, 2009 | Zebra 105SL Thermal Label Printer
Inconsistent printing.
The sensor tag is not well calibrated, press FEED, PAUSE and CANCEL, turn on the printer and release the keys when you move the label to print and let the end be calibrated.
Roberto Martinez
Mexico
Oct 03, 2008 | Zebra Z4M Printer
Zebra TLP 2844 Desktop Printer
make sure you have selected the correct media in the printer driver. The tracking mode has 3 options, (1) Web Sensing (Cut Labels), (2) Mark Sensing (Black marks on back of liner) and (3) Continuous . In your case select continuous. It sounds like the printer is in the wrong media mode and is feeding labels looking for a mark or gap and when it doesn't find one it flags a media error.
Aug 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 4M Plus Pauses unexpectedly
try to run the manual calibratio from the setings.
run "manual calibration"
move the ribbon out from the sensor (with the print head open) and take out 3 or 4 labels from the rollar and put that blank label paper unther the sensors on the left,
say "ok"
wen appear "reload all"
put the ribbon and the normal labels on the correct possition, and say "ok"
try to run sext the sensor profile.
save data (twice on "setup button")
tur off, and on again.
Feb 12, 2008 | Zebra Z4M Printer
Zebra Z4M Printer Logo
480 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
