This Kenmore AC is probably dead
I just want a confirmation before I go trying to get money and arrange an installation.
Kenmore AC, 8000 BTU wall-mount. Any time I turn it up past ''Fan'' it makes the infamous ''funny noise'' and pops the breaker for its outlet.
I need a new one, right ?
  • dontspammike Feb 06, 2009
    I don't have a multimeter, I'll put that on my "well-equipped server room" list. Thanks tho ken.
  • Ken Bledsoe May 11, 2010
    You might be right but if you have a multi meter you can check the compressor out to be sure. Let me know I can walk you through the check out. ken
    Problem Solver:
  • 17 Answers
Yep you would be better of getting a new one sounds like your compressor dead.
Posted on Feb 10, 2009
OuVery dissapointed and unhappy.
This is a 120volt unit,so I assume it is not the ac unit,try another plug in,in the house,and have the circuit checked that the ac unit was plugged into,there is not enough voltage most likely.
Apr 16, 2012 | Kenmore 8000 BTU Single Room Air...
With a Kenmore 8000 BTU ac window unit there is a green wire that runs from underneath the control panel. Where does that go?
Most of the time a green wire is a ground and should be attached to the metal frame using a existing screw or a self tapping sheet metal screw. Thank you.
Aug 26, 2011 | Kenmore 75080 Thru-Wall/Window Air...
How many BTU is Model#580.74085 580.74124
8000 BTU. I have one. I'm looking for the EER rating, although I see an energy star label on the front.
Jun 19, 2011 | Kenmore 75135 Thru-Wall/Window Air...
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
Does kenmore 8000 btu air coditioner thru the wall require a separate sleeve for installation
No you can install that unit directly through the wall and trim around it...just make sure most of the side vents are exposed outside...
Aug 21, 2010 | Kenmore 75085 Air Conditioner
Need sleeve for kenmore 70135 through wall air conditioner
does kenmore 8000 btu thru the walll air conditioner require a separate sleeve for installation
Jun 16, 2010 | Kenmore 75085 Air Conditioner
Thank you. I have an 11 year old Kenmore 8000 BTU window unit that has served me well. I am remodeling my apartment now and would like to have a service and maintenance check on this unit that might...
take it to a hvac shop and tell them what you want! or just telll an electrical shop what you want in the cord length---to straighten out the fins n the front coils with a fin coil brush at a hvac supply house,and remove the top/ side cover and fully clean the inside unit, drain lines--both front and back coils---on both sidesan oil the fan motor....TYVM!
Dec 03, 2009 | Kenmore 8000 BTU Single Room Air...
I have a single room 8000 btu kennmore air conditoner was making loud squealing noise when compressor kicks on and now it makes no noise and does not cool at all please help
sounds like the compressor may have died on you. the compressor isnt running you might as well trash it sorry for the bad news but it probably isnt worth trying to replace a compressor in a system like that it would drive you crazy and take forever if it could even be done.
Sep 17, 2009 | Kenmore 8000 BTU Single Room Air...
Haier 8000 btu thru the wall ac wont come on
try ot unplug for 2 minutes,,, and try again may have fuses inside also
Jul 03, 2009 | Haier hwr10xc6 Air Conditioner
2 Air Conditioner Problems
Whinny noise is probably motor which needs some motor machine oil (hardware store).
Freezing is probably caused by bad de-icing switch or poorly insulated de-icing switch.
If you want to further pursue, let me know.
Apr 30, 2009 | Heating & Cooling
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
