Question about HP OfficeJet 4215 All-In-One InkJet Printer
Setting up printer
Recently moved to new location and when i try to print, nothing happens a message saying phone off hook, but it's connected to a fax or phone , it's just for printing. Can someone help me
  • 1,602 Answers
THIS IN ON THE INTERNET PROVIDE I THINK IT IS SAY YOU ARE WORKING OFF LINE, AAL YOU HAVE TO DO IS GO TO FILE LOOK FOR WORKING OFF LINE AND REMOVE THE CHECK MARK AND EVERYTHING SHOULD WORK.
ROD
Posted on Feb 05, 2009
Will not print
more information please- have you tried re-installing the printer driver to test your data connection to the printer?
Jan 16, 2014 | HP Officejet 4622 Multifunction Inkjet...
I just moved apartments, reset up my printer/computer, now computer is not acknowledging the printer. When I try to print it will say "connecting, 78% completed) and then nothing actually comes out.
MAKE SURE YOU HAVE YOUR PRINTER SET ON DEFAULT AND THAT IT IS INSTALLED PROPERLY! OR YOU CAN ALSO TRY...UNHOOKING YOUR PRINTER, SHUT DOWN YOUR COMPUTER AND HOOK YOUR PRINTER BACK UP BEFORE RESTARTING TO LET YOUR COMPUTER INSTALL YOUR PRINTER.
IF YOUR COMPUTER DOESN'T RECOGINIZE NEW HARDWARE, SUCH AS YOUR PRINTER, THAN IT IS NOT SET AS YOUR DEFAULT PRINTER!
YOUR SOFTWARE MAY NEED TO BE CORRECTLY INSTALLED, MAKE SURE YOUR PRINTER IS NOT HOOKED UP WHEN INSTALLING SOFTWARE.
SOFTWARE HAS BE INSTALLED FIRST, AND RECOGNIZED...THEN RESTART COMPUTER WITH PRINTER (HARDWARE) HOOKED UP!
Aug 25, 2011 | Office Equipment & Supplies
Printer stopped
Try simply adding a printer. If you get an error when you select "add printer" then you may need to check your print spooler.
If there is no error when you select "add printer" then the driver is corrupt and you will need to uninstall and reinstall (make sure you are the admin).
Thanks,
Pat
May 20, 2010 | Brother MFC-8460N All-In-One Printer
Print want print
If you recently purchased it, just put it back in the box and take it back to the store for a replacement. I wouldn't bother tryng to fix it if you can get a brand new one that works the way it's supposed to.
Apr 02, 2010 | Brother HL 2140 Laser Printer
Every time I try to print something it says I don't have a default printer but the computer says it's already set as the default. And when it does attempt to print (saying so on the document) nothing shows...
I have had this problem before using Windows XP. I disconnected the printer and went to my computer then printer and faxes and deleted all the icons. I re-connected the printer and one printer popped up. I right clicked and set as default. It should say "ready" next to it. Deleting the Icon does not delete the printer driver. Hope this helps.
Mar 11, 2010 | HP DeskJet 712c InkJet Printer
Will not print
Make sure you select the printer has the default printer under the Printers and Faxes option on control panel.
Simply right click your printer and select the option "Set as the default printer"
To make sure it is solved, go to the printer properties under the right-click menu and hit "Print test page"
Good luck
Jun 21, 2009 | Canon BJC 80 InkJet Printer
Cannot send fax with a proper working phone line hooked up
I have exactly the same problem! did you find a solution or reason???
Mar 19, 2009 | Brother MFC-9440CN Laser Printer
My shared printer will only print a test page and nothing else!
Hi phall124
Have you made the new connected printer on 2 other PC's the default printer. Try selecting the printer in word by not just clicking on printer icon but using the following:
1.File
2.Print
3.Select printer from drop down box
4.Print
Regards
Go-Tech
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
59 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
