Question about IBM Wheelwriter 30 Typewriter
Cannot remove element-lever broken off top
The top lever is broken on the element - I cannot get it to release off the typewriter
  • ROD GANDY May 11, 2010
    IS IT RONUD BALL OR IS IT THE DASEYWHEEL
    TYPE OF CONNECTION
    CLARIFICATION PLEASE
  • 1,602 Answers
IF IT IS THE BALL THE BALL HAVE TWO 2 METAL LATCH LIKE OBJECT THAT HOLD THE BALL INPLACE AND YOU WILL NEED A SMALL SCREW DRIVER TO MOVE THEM APART AND LIFT THE BALL UPWARDS
ROD
Posted on Feb 05, 2009
How i can shift to arabic
You have to buy an Arabic printwheel and install it.
To insert the daisywheel:
1. Open the top cover.
2. Pull the lever toward you to release the daisy wheel lock.
3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear" on the top right.
4. Insert the desired cassette daisy wheel into the slot and press down gently.
5. Slide the lever back to its original position to lock the cassette daisy wheel into place. Make sure to press the lever firmly.
6. Close the top cover.
7. Press and hold the CODE key. While holding CODE press the Q key, this will move the carrier to the previous position.
Sep 11, 2013 | Brother SX-4000 Typewriter
Just received the typewriter and there is a spring that was not attached to anything. Paper will not feed correctly. The lever to loosen or tighten it does not do anything.
It is probably the paper release lever spring (gives tension to the rollers to hold the paper in place).
It attaches to the lever and then to the frame...the plastic hook on the frame is most likely broken...
If you are handy and can take the top of the machine cover off, you can drill a small hole in the frame and hook the spring in there...(have done this in the past when I was repairing typewriters for a living..lol)
Aug 15, 2013 | Brother GX-6750 Typewriter
Where is the lever that releases the carriage on the olivetti 32
There is a chrome lever on the right side of the carriage on top that should manually release the carriage by pushing down on it. If this works but there is no spring tension pulling the carriage to the left, then the drawband is probably broken. If pushing the lever down doesn't work then eithor the mechanism is broken or locked up or there is a carriage lock that need to be released. If there is a carriage lock it would be located under the carriage on the left or right side. It would be a small chrome lever sticking out the side.
Apr 15, 2013 | Office Equipment & Supplies
How to get rid of wheel release
Remove ribbon, pull the lever at the R. side towards you, lift out the P/W, check for bent or broken spokes, check P/W area for debris. Try it without the ribbon and correction tape.
DickyO
May 17, 2011 | Nakajima AE-740 Typewriter
Imb selectric iii, page will not advance.
If it dosen't feed by knob or return the release lever on the top R. of the T/W is probably forward, if it feeds by hand and not by index or return you probably have a broken or unhooked index link.
DickyO
Jun 16, 2010 | IBM Office Equipment & Supplies
I cannot remove the typing element on am IBM Selectric II typewri
Once the lever is broken you must either find a way to spread the spring that holds it on apart (not easy) or take a razor blade and slide it under the black plastic cap and cut it off.
DickyO
Mar 30, 2010 | Lexmark Wheelwriter 15 Series II...
How to replace ribbon on Royal Apollo 10 elec typewriter???
The cover either pulls up straight or there is a release lever in the front part of the cover that pushes.
Dec 15, 2009 | Royal Office Equipment & Supplies
We need to change the font on our swintec 640
  1. Remove ribbon
  2. pull printwheel release lever toward you
  3. remove and replace print wheel
  4. push printwheel release lever forward - away from you until it snaps in place
  5. replace ribbon
  6. adjust pitch selector on keyboard if needed.
Dec 08, 2009 | Swintec 7040 Typewriter
Wheelwriter 10 typewriter...typing thick file folders
There is no adjustment on Wheelwriters for thickness. Try pulling the release lever (top right) forward then putting the folder in then push the release lever back.
DickyO
Feb 11, 2009 | IBM Office Equipment & Supplies
DAISY WHEEL
typing "code" and "reset" sets it right to type
Mar 20, 2007 | Brother SX-4000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
112 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Toby
Toby
Level 1 Expert
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
