Question about Toshiba 50HM66 52" Television
Toshiba 50HM66 I have wide vertical lines on my TV (like looking through an iron fence). These occur whether I am on cable or DVD. Anybody know what is causing this and how I can fix it?
  • 25 Answers
Try cable,rbg.or the yellow visual input if you still have the problem ,you may have a BAD GUN OR BULB.
Posted on Feb 06, 2009
Why would there vertical lines on my toshiba theater wide tv?
this sounds like a bad capacitor. If you want to fix it yourself and know how to solder on a pcb, then replace all of the electrolytic capacitors.
Nov 18, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Vertical lines on lcd toshiba tv
I'm sorry that the TV is displaying vertical lines on the screen. Please follow the troubleshooting steps and check the operation:
Please make sure that the connections are secure and proper.
Try connecting a different video source like DVD player or VCR and check the operation. If it works with another device, the issue might be with the input device currently.
Also try connecting the device to a different port in the TV if no other devices are available.
If the issue persists, try with a different cable.
Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
If the issue persists, after all above troubleshooting steps, service may be required. You can click hear to setup a service for the TV.
Also it would be good if you can come back with the model # of the TV to check whether the issue can be resolved with a firmware update.
Thanks for understanding. Please let me know if you require any clarifications/additional help.
Sep 26, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
My tv has two vertical lines whenever I hook up my dvd player or gaming console. tried all inputs. lines dont show up when I have my cable hooked up. I have HD
are they black bars on the left and right side of the video? if so then use remote to change the picture size. on the remote the button to look for would say "format" "wide" "aspect" "size" one of those
Dec 22, 2010 | Toshiba 65H82 65" Rear Projection...
How to program 50hm66 for cable tv
Are you hooked up to cable box or just straight cable line? You should be able to go into the menu, in setup, and auto program it in the cable mode.
Oct 13, 2009 | Televison & Video
MY toshiba tv MW27F11C only shows a white line when turned on
Hello uuka,
You have vertical collapse. This is most often caused by a defective vertical output integrated circuit, an open dropping resistor which feeds the supply voltage to the I.C., one or more defective electrolytic capacitors in the vertical circuit or something as simple as bad solder connections. The latter will usually manifest itself as an intermittent failure. Less likely, but stilla possibility is a defective yoke, but this a rare.
Unless you are handy with a soldering iron and have some experience this is definitely something I suggest that you refer to a qualified technician. Depending on the actual cure for the problem, this would typically be under $100 in my shop, but we are in a small town and prices are cheap. I would definitely recommend a repair on this since it can not be replaced. They don't make a TV/DVD/VCR combination any longer and the picture quality on these Toshiba/Orion combos has been very good over time.
Hope this helped and don't forget to rate...
Thanks!
The Wing Guy
Apr 29, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
My Toshiba 50HM66
i suggest checking the lamp. find you owners manual and go through the steps to "replace the lamp" if it is popped and you can see little pieces moving around inside than contact toshiba and they will send you a replacement with credit card numbers of course.
Mar 21, 2008 | Toshiba 50HM66 52" Television
Tv toshiba vertical problem
I had white lines 4" thick vertically for about a week, then one day powered the unit up and with in 3 seconds there was a loud pop from the rear or the unit. Any one know what needs to be replaced?
Jan 23, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba 50HM66 52" Television Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
