Question about Panasonic KX-TG1033S Cordless Phone
I have static on all three handsets yet the landline has none
I have noise filters in to base unit can not get rid of static even with no other electric devises running
    Problem Solver:
  • 5 Answers
Sorry dont know if it was sent so i will do it again, i had same problem on a network and was advised to cut out the yellow resister in bt point ( only if a trailing socket NOT the main bt incoming socket), also have you got broad band modem ? if this is not on incoming bt socket this can cause problems? dont plug it in a extension lead use a proper cable and box on wall and plug modem direct into socket with no adsl filter ! next plug all your telephones into bt sockets through the adsl filters make sure you havent got to many phones plugged in this inclueds sky box which is a phone ?and needs adsl filter ? hope this helps leighton
Posted on Feb 05, 2009
At&t dect 6.0 all 4 handsets say no line
check base unit .
Check phone line is plugged into base and wall
Check base unit has power going to it
If it all looks ok try plugging a normal landline phone into the base unit locations phone line to see if there is dial tone .
Jan 28, 2017 | AT&T Lands Phones
My uniden phone is not working. All hand sets say Check Tel Line. Will not make or receive calls. Will a dead battery in one handset make all handsets malfunction? Are batteries available?
batteries are available from e-bay
one dead battery will not affect any others
all hand sets make calls and receive calls through the base unit that is connected to the landline
base unit is connected to the landline and operates any hand set that is picked up
make sure all handsets have the end call button pressed as one not pressed after use may keep a line open
call your provider to check the land line to your premises
borrow a neighbours phone and plug it into the socket and see it you get a line on their phone
Oct 30, 2016 | Uniden Lands Phones
These phones have worked well for a long time . However, all of a sudden I hear static noise on all of the handsets. Is it possible to get rid of the static noise short of replacing the units?
Check your phone line or have it checked by your phone company. Three phones do not all go bad at the same time, do they?! Of course not!
Hook up another phone and see if it also does the same thing. If so definitely the line. If not, then it is the base unit of the three some that has an issue.
Sep 21, 2015 | Panasonic KXTGA101S 3 Handset KX-TGA101S 3...
Static noise
Time to purchase new phones. It is not worth repairing the electronic parts that are failing.
Sep 21, 2015 | Lands Phones
Additional handsets will pick up calls from mobile phone but not landline calls
Try registering your older handsets with your new base station per the manuals instructions. Also your new base station might be transmitting on a different frequency or some other coded transmission is not recognized by your old handsets. Did the manufacture say the older handsets would work with the new system? They might not even if they did say so.
Jan 09, 2014 | Avaya 3920 Phone
My handset on the display window is flashing "base" i cannot use my landline even though my landline is connected because my internet is working
You didn't include the name and model of your phone - so I can only offer generic help with this problem. Typically, when a cordless phone handset indicates "base" it means that it has lost its link with the radio in the base unit. You should simply place the handset in the base charger for a few seconds and the handset will re-establish a link with the base. The loss of link can happen if you separate the two too far from each other or if the battery drains to deeply. If you still have problems, please provide the name and model of the phone system you have.
Lastly, you can lose phone service even if your internet is still working. Many cable systems use dedicated cables for phone service that are independent of the TV signals and internet. DSL from your phone company is a separate service that is "piggy-backed" on the wire with dial tone. These services can have one service working even if the other has failed. If you have VOIP service however, this would NOT apply as VOIP is dependent on internet connectivity only.
If this was helpful, please rate it "4 thumbs up" Thanks!
Aug 02, 2011 | Audio Players & Recorders
Have static on both phones and need to know to change the phone channel to move static.
I had the same problem with my uniden 5.8 ghz phone. After placing a filter (from the phone company) into the wall jack and plugging the phone into that filter the static noise was eliminated completely. Hope this helps.
Sincerely,
Paul
Sep 20, 2008 | Uniden Lands Phones
My landline phone does not work. I tested it outside on the company's jack and the phone works. I have 3 jacks in the house and it will not work on any of them, including the one I get the internet. The...
One of the phone handsets of the Panasonic KX-TG563 trio gives me static w/ dial tone and then shuts down or it gives me the message that "System is busy/Line in use" with no dial tone. If I get closer to the base unit it seems to work but w/ alot of static. The base unit phone works good and the other handset works ok too. The battery shows fully charged however, when I take the battery out to try a reset when I put it back in the battery indicator show very low. I tried switching batteries w/ the othe hand sets it doesn't help.
Thanks
Jun 07, 2008 | Lands Phones
Panasonic Phone KX-TG6700B base unit Problem
FROM PAGE 38 of the manual:
If "No link to base. Move closer to base, try again" is displayed, even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit..
HAVE BOTH THE HANDSET AND THE BASE UNIT NEARBY DURING REGISTRATION.
FOLLOW STEPS 1 AND 2 LISTED BELOW. YOU HAVE ABOUT 1 MINUTE TO COMPLETE THEM.
1-Base unit:
Press and hold [HANDSET LOCATOR] until the CHARGE indicator flashes.
2-Handset:
Press and hold [FLASH/CALL WAIT] until "Handset Registering" is displayed.
-When registration is complete, a beep sounds from the handset.
-Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
If... the handset beeps three times and "ERROR!" is displayed, an error occurred. Try again from step 1.
You can stop registration by pressing [OFF] on the handset, and pressing [HANDSET LOCATOR] on the base unit.
Jan 10, 2008 | Lands Phones
Base does not charge handset
If all 3 handsets fail to charge on the base unit that leads one to the conclusion that the charger with-in the base unit has gone bad and I really don't know of any fix. Thank You. Jerry
Dec 28, 2007 | Uniden Cordless Phone
Panasonic KX-TG1033S Cordless Phone Logo
348 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
