Question about Clarion VRX485VD Car DVD Player
Preset radio how to you get the unit to save the radio station? holding the preset button after finding the station only kicks the ststion back to the factory default station.
The best way to do this is to be very patient. find the station you want to preset and simply touch and hold the number you want to save it at on the touch screen. the station will pause for a split second and then you will see it on the display of the presets
Posted on Feb 06, 2009
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
How do I set the clock & preset the stations. I bought the radio 5/4 /11 & there was no brochures or warrantee in box.
Setting the Clock 1. Press and hold the CLOCK button until the hour begins to flash 2. Use the left arrow and right arrow buttons to change the hour. 3. Press the CLOCK button again. Use the left arrow and right arrow buttons to change the minutes. 4. Press the CLOCK button again to save.
PRESET Stations the PRESET stations: 1. Tune to desired station. 2. Press and hold the PRESET button until the PRE-SET indicator on the display begins to flash 3. Use the left arrow and right arrow buttons to select the PRESET location for the station. Ten locations (0-9) are available. 4. Press the PRESET button to save the location. To tune a PRESET station: Press and release the PRESET button to step through the PRESET stations.
http://www.northerntool.com/downloads/manuals/142796.pdf
May 06, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
antenna.
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
station
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
[Yes].
»» The radio automatically tunes radio
stations and saves the frequencies to
presets.
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
seconds.
EN
Jan 09, 2011 | Philips GoGear ViBE Digital Media Player
I need to set the clock on a CD/cassette radio in a 1999 Ford E 450...also how do I set preset stations too?
Station Pre Set:
You can save 4 pre sets on this radio (1-4) tune the radio to the station you want to save then PUSH and HOLD one of the pre set butons until the sound returns, the station is saved to that pre set. Repeat for the 3 presets.
Clock:
Hour: Push and hold the CLK button and at the same time push the SEEK button to adjust. < decrease hours > increase hours.
Minute: Push and hold the CLK button and at the same time push the TUNE button the adjust. < decrease minutes > increase minutes.
Jul 14, 2010 | 1999 Ford Super Duty F 450
Radio for Sandisk model SDMX1
Press the AB button to toggle between Audio Play, Radio, and Voice Record. Use the left/right scroll to highlight Radio. Then press the center button or play/pause button once to select radio.
You will see FM Radio in the upper left corner of the display. Under that you will see either Preset followed by a number OR Channel. If it is on Preset, you can use the left/right scroll to switch between preset stations. If you press and hold the AB button, the player will scan through all frequencies to find the strongest stations in your area and set those as the default preset stations. When on a particular station, press and hold the record button to delete that station from your presets.
Press the center button once to switch to Channel (or back to Preset). Under Channel, you can manually scroll through the frequencies yourself. Push left or right and hold for about a second to find the next available station.
Press the play/pause button once to toggle between Mono and Stereo.
Those are all the functions I've found so far. Hope it helps.
Good luck,
vw
May 26, 2009 | SanDisk SDMX1-1024-E18 MP3 Player
I can't preset radio stations
this is how i preset my stations, im not sure if you have done this before.
fm can save 20 stations and am can save 12
1] chose your desired station
2] press & hold the play/memory button until P01 pops up and flashes
3] to save the station, press & hold the play/memory button
if you'd like to save another station, then repeat steps 1 & 2,
then press the play/memory button again until P02 pops up,
repeat step 3.
to listen to your preset station, all you have to do is press the play/memory button.
hope this helps
Mar 12, 2009 | Starlite Next Play Clock Radio with iPod...
2003 Lexus ES300 How does one save Radio Statio presets? Going to the station and holding the button to save does not work.
Holding the button is supposed to work. This from owner's manual: PRESETTING A STATION:
  1. Tune in the desired station.
  2. Push one of the station selector buttons (1-6) and hold it until a beep is heard. This sets the station to the button and the button number (1-6) appears on the display.
Each button can store one AM station and two FM stations. To change the preset station to a different one, follow the same procedure. The preset station memory is cancelled when the power source is interrupted by battery disconnection or a blown fuse.
Jan 08, 2009 | 2003 Lexus ES 300
Radio presets?
select radio station then select which number you want to preset station to and press and hold until you hear the unit beep,also preset station will flash once aswell as the beep,station should be preset into your headunit,goodluck.
Nov 29, 2008 | Pioneer Car Audio & Video
Set Radio Station Presets
Try just holding the button of choice down. In my Audi, when I had a factory head unit, to set for example, preset 2, I'd just tune to the station I wanted to program, and then hold down the number 2 preset button until the display stopped blinking. It was then preset.
Oct 09, 2008 | 2001 BMW Z3
Tuning DAB radio
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
Dec 27, 2007 | Audio Players & Recorders
Clarion VRX485VD Car DVD Player Logo
182 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
