Question about Kenmore 22642 Top Load Washer
Kenmore washer My washing machine is not spinning the clothes dry, made a whining noise, thought maybe a belt going, not sure, I cant find my manual..was a gradual thing, I thought maybe washer got overloaded, so made the loads smaller and now it barely spins at all, enough so I have to wring clothes out when its done...
  • 5 more comments
  • Drackula2000 Nov 17, 2007
    i am having the same problem and im in the disassembly process however i am trying to remove the drum from the washer and cant get past taking the agitator off could you give me a simple way to do this? any help you could give would be much appreaciated
  • Anonymous Mar 25, 2008
    washer not spinning fast enough.
    clothes are still wet when finished spinning.
  • Anonymous Jun 04, 2008
    I have the same problem.. My machine spins but not fast enough to dry clothes. I did notice that there is oil splattered below the tub and gearcase and was not sure were it was coming from?
  • tlhamp0 Jun 14, 2008
    i'd have almost the same problem it whines through all the cycles and i'd can't figure out what wtong with it if any od you can tell what it is i'd appreciate it it get louder during the spin cycle
  • Anonymous Mar 19, 2009
    I have the same problem but it seems to be intermitent. Should I suspect the same as listed above?
  • Anonymous Mar 16, 2014
    washing machine isn't spinning enough water out so it takes 2-3 times as long to dry clothes
  • Anonymous Mar 25, 2014
    We using nord language on washing mashine so it's difficult to understand. On the screen we're seeing "pump ..." Maybe wring is blocked?
  • 5,911 Answers
If your washer is not spinning fast enough, or barely spinning at all, this is usually a symptom of any one or all of the following: 1. Bad gearcase (transmission). 2. Bad basket drive, with which the transmission couples to under the agitator. 3. Bad clutch/brake assembly. Which mounts on top of the gearcase under the basket drive. Usually a tell tale sign of a gearcase beginning to fail is the sign of an amber colored oil coated under the washer or inside the casing. I said, "usually". It doesn't always happen, but if you notice any signs of oil, the gearcase is shot. The basket drive and clutch assemblies are harder to diagnose and require some disassembly of the washer and the removal of the gearcase to inspect. Let me know if this helps.
Posted on Aug 02, 2007
  • Jeff Rockwell
    Jeff Rockwell Aug 03, 2007
    If you're going to rate my advice as "Not Helpful", it would be nice to know what you have done so far, so that I may try to assist you better. I work on these machines all the time, and have repaired many different problems with them. The advice I gave you is a "best guess solution" based on the symptoms you gave. It's often hard to determine a cause without being there, and not knowing more than the initial symptoms. Let me know if I can still help.
SOURCE:
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
Clothes don't ring out dry. I thought maybe a belt but how do I get at it?
from back you will have to take back off then the side then the belt will be located under tub.
Feb 16, 2011 | Kenmore 98702 Stacked Washer/Dryer
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Washer won't spin clothes dry enough
Dear Langley,
please do the following checks.
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
please rate this solution.Thank You Langley
Dec 16, 2008 | Kenmore 15944 Top Load Washer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washer will not spin sometimes
look under for the belt(s). Belts must be clean and dry, and in good shape, no oil or grease on them. If the machine is leaking on the belt, it will slip. Detergent will make the belt slip.
Apr 01, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer making noise in spin cycle
Is this unit new? I had a frigidaire that would really get to going on the spin cycle. Got the clothes really dry and sounded like a jet engine if no clothes were in it. Is it a whisling sound or screeching sound...The sound could be coming from the water pump. It may have something in it that is dragging. Some you can take the bottom off of and clean them out..
Feb 10, 2008 | Washing Machines
Kenmore 80 series washer not completly spinning clothes dry
Belt going..
A bit of a pain to replace, but doable..
Belt dressing will keep it going for a while..
Dont get your fingers caught in it..
Serious injury is possible, unplug the machine
and stand on the plug while moving the
belt to goop it..
(why? that way it cant get plugged in!)
Feb 07, 2008 | Washing Machines
Kenmore 22642 Top Load Washer Logo
236 people viewed this question
Sal De
fordexpert
yobo007
yobo007
