Question about HP Officejet 9110 All-In-One InkJet Printer
Error message When turned on receiving a "printer motor stall" message
  • 1,602 Answers
HP OFFICEJET 9110 PRINTER MOTOR STALL ERROR
ENTER
ROD
Posted on Feb 05, 2009
I received a new printer today, I installed the software and ready to test print page. I get error message that the carriage is stalled. I found a procedure on HP web site that to fix problem, but it...
The printer may be faulty. I suggest you return it to the supplier to have it fixed or replaced under warranty. If you try to fix it yourself you may void your warranty.
Jul 14, 2011 | HP H470 InkJet Photo Printer
I am getting error message--Print cartridge in right stall not supported. I have cleaned the cartridge and still receive error message, Any ideas on how to remove this message?
Are you sure that the cartridge is the right cartridge for your printer?
here is a link that would eliminate possible causes why you are having that error message.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00427221&cc=us&lc=en&dlc=en&product=441240&tmp_track_link=ot_search
that should solve the problem.
Mar 06, 2011 | HP Photosmart 2575 All-In-One Printer,...
Just Purchased A Hp Office Jet Pro 8500A. The printer says Pump Motor Stalled. What to do ?
You mentioned this is brand new printer purchased and gives "Pump motor Stalled" Error. Since this is new unit, my suggestion would be to contact HP Tech support regarding this issue as your printer is In-warranty and if needed, the printer will be replaced without any cost.
OR,
If you have purchased the printer from a store like bestbuy, Costso, Walmart etc. you can return the printer to them and get another one exchanged ( Check their return policy )
HP Contact # - 1800-474-6836
Before you contact HP or return the printer to store, you can try few things to check if it works as "Pump Motor Stalled" generally is Hardware Issue.
Open the Printer front access door.
Remove the Cartridges and Printheads ( Printhead is that holds the cartridges, loosen the latch to remove it )
Clean the contacts ( Electrical or Golden contacts ) using lint free cloth. ( Cloth damped with few drops of water, squeezed properly )
Put the Printhead and Cartridges back and Turn off the printer and turn on.
If should not display the error. If it does, it is your choice whether to take the printer to store and get exchanged or contact HP.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | HP Photosmart C6180 All-In-One InkJet...
Ribbon Stall
Printer errors are various messages displayed on the LED display of printers. ... We also carry a lot Lexmark Toner & Ribbons for your one stop shopping experience. ... ERROR 54 - Duplex Feed Error (IID/IIID) or Main Motor Stall 2686 A/D ..... Sharp Printer Supplies, TallyGenicom Printer Supplies, Texas Instruments ...
www.printersupplies.com/errors.html
Dec 03, 2009 | Office Equipment & Supplies
Error Message: Pump Motor Stalled. Please advise
Try partial reset and semi full reset of the printer, this is error message is a hardware error, if the issue is still not resolved contact HP, they would replace the printer if it is under warranty.
Sep 28, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Carrier Stall is the error
Please do the following..
To check the cartridge carrier:
  1. Unplug the printer.
  2. Move the cartridges to the left by hand and then take them out.
  3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
  4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
  1. Remove any other devices attached to the USB/LPT port.
  2. Uninstall the Lexmark printer.
  3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
  4. Reinstall the printer.
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
Waste Motor Error message on Samsung CLP-500
This error is caused by the Waste Toner Motor 'stalling' - usually as a result of the Waste Toner Full message being ignored for too long, and the waste system becomming overful.
Usually best to replace the Waste Toner Motor assembly.
They are for sale on auction websites from time to time.
Sep 12, 2008 | Samsung CLP-500 Laser Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Lexmark x83 carrier stall
    http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
    Use the above link to trouble shoot the problem.
    Error: "Carrier Stall" ID:470
    Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
    Optra 642 series
    Is it only that document or from any OTHER doc source, word, excel etc.....
    Nov 13, 2007 | Lexmark T642 Laser Printer
    HP Officejet 9110 All-In-One InkJet Printer Logo
    244 people viewed this question
    Seeker5211
    Seeker5211
